HiSky protocol - HCP100S HCP100 out of sync
09 Feb 2015 04:30 - 13 Feb 2015 03:35 #28482 by jimqjp
Recently I brought a HCP100S and a HCP100. Use HiSky protocol can bind both of them.
However, both not stable:
From time to time, HCP100S lose control for a short time (sticky servo), left side LED blinks at the same time
HCP100 has shudders in all channels occasionally - cyclic has burst movements, the tail has sudden shakes.
Tried with a radio came with a V922, it flys the HCP100 perfectly. Though cannot fly HCP100s, once linked, the servo never sticky and the LED never blinks.
I also have a V922 bought more than one year ago, it can be controlled perfectly.
It looks like the Deviation HiSky protocol may not fully compatible to HiSky protocol, TX and RX out of sync once in a while?
Unlike the new HCP100, V922 does not shudder at all with both WLtoys radio or 7E. I guess either the firmware updated or my V922 and HiSky are different in firmware versions.
Last edit: 13 Feb 2015 03:35 by jimqjp.
09 Feb 2015 16:35 #28493 by mikemacwillie
Replied by mikemacwillie on topic HiSky protocol - HCP100S HCP100 out of sync
Which version of Deviation are you running?
11 Feb 2015 13:07 - 11 Mar 2015 23:13 #28562 by retiredfist
Replied by retiredfist on topic HiSky protocol - HCP100S HCP100 out of sync
I seem to agree.
I was given an MCPX with a blown board so replaced it with a Hisky HCP100 board.
Binds ok with Deviation on 7e but servo movement moves are weird (delayed & incorrect) so will not take off.
I then purchased a brand new HCP100, once arrived binded it to the Devo 7e & again weird behaviour.
I am running Deviation 4.01
So I'm stuck with a brand new HCP100 that doesn't fly and a HCP100 board that behaves erractivally
Last edit: 11 Mar 2015 23:13 by retiredfist.
11 Feb 2015 17:24 #28570 by mikemacwillie
I have an HCP100 that worked fine with the nightly builds last time I tried it, and an HCP100S which I haven't tried yet. I'll give them a shot in the next couple of days and see how they behave.
11 Feb 2015 22:10 #28575 by Mmon77
Replied by Mmon77 on topic HiSky protocol - HCP100S HCP100 out of sync
I have an HCP100 and fly it with a 7e with nightly build 4.0.1-2e82bal. No issues with servo movement at all. I bought the HCP100 April of 2014 I believe. Don't know if that matters or not. Strange that some are having issues and some aren't.
Have you tried re-binding with the tx almost touching the heli? I know HiSky has had some issues in the past with laggy servos that were resolved by following that process.
12 Feb 2015 14:39 - 12 Feb 2015 14:41 #28597 by retiredfist
I bought my HCP100 mid January 2015, not sure if Hisky updated the firmware then.
I tried it on the Devo 7e.
Will try it on my Devo 8S sometime next week if so see if it makes any difference when I find the time.
That's a funny solution but will give that "touching Heli" rebind. Normal rebinding has made no difference
Last edit: 12 Feb 2015 14:41 by retiredfist.
13 Feb 2015 04:54 #28621 by jimqjp
Replied by jimqjp on topic HiSky protocol - HCP100S HCP100 out of sync
mikemacwillie wrote: Which version of Deviation are you running?
I am using default 4.01 build 92e1705. The file hisky_nrf24l01.c does not have functional changes since the V4.01 release.
13 Feb 2015 05:00 #28622 by jimqjp
Mmon77 wrote: I have an HCP100 and fly it with a 7e with nightly build 4.0.1-2e82bal. No issues with servo movement at all. I bought the HCP100 April of 2014 I believe. Don't know if that matters or not. Strange that some are having issues and some aren't.
Yes, I did re-binding very closely, that did not help.
The PCB of my old V922 seems exactly the same as my new HCP100 PCB, but my v922 never has problem.
14 Feb 2015 00:47 #28650 by mikemacwillie
Just tested out my HCP100, it's also working fine with the nightlies. Haven't had a chance to try the HCP100S yet.
14 Feb 2015 15:27 #28669 by ahmadie
Replied by ahmadie on topic HiSky protocol - HCP100S HCP100 out of sync
I am also having range problem where the left led of hcp100s flashes around 15 feet away from transmitter. I did not try to fly heli bcz risky
18 Feb 2015 02:19 #28775 by fox
ahmadie wrote: I am also having range problem where the left led of hcp100s flashes around 15 feet away from transmitter. I did not try to fly heli bcz risky
where is this problem? board? or deviationtx?
18 Feb 2015 14:52 #28814 by ahmadie
I am not sure. i fly my v977 heli with KN protocol with no range problems but when i try to fly hcp100s the range is short. actually only me and one other person at rcgroups reported this problem.
18 Feb 2015 17:36 - 18 Feb 2015 17:38 #28837 by jimqjp
I am very confused:
1. TX seem no problem. Same as what you get, I can fly KN and a old V922 with HiSky protocol, no problem at all at 10mW settings.
2. Next guess is half deaf RX. However, the same 100S PCB can be controlled by the old V922 TX with no problem (no blink LED).
3. Protocol problem? HiSky protocol works fine with my old V922. It can bind 100s. The sticky servo (LED blink) is intermittent, some time can be as long as one minute without sticky problem.
4. Only left is that 100s uses different protocol from the old V922, and it is compatible to V922 controller and not Dev HiSky protocol. However, not all Dev user report the problem.
Still no clue!
Last edit: 18 Feb 2015 17:38 by jimqjp.
18 Feb 2015 18:03 #28841 by victzh
Replied by victzh on topic HiSky protocol - HCP100S HCP100 out of sync
You can try to change your TX id for the model in question. Also, the power during bind procedure is intentionally lowered so as to exclude accidental bind of someone else's model. It can pose a problem sometimes. Try to put the model and TX as close as possible during binding.
18 Feb 2015 18:26 - 18 Feb 2015 18:32 #28844 by jimqjp
Hi victzh,
Glad you join the discussion!
I tried lots of things.
High and low power settings. All at almost touch range to bind. Not help.
Different hopping frequency patterns (for test, hard coded, no relation to TX ID) 20 different ones, repeat every 10, every 5, and every 4. Hope that when out of sync, the repeat patterns can get recovery sooner. Not help though.
Not sure what happens at RX side when a packet is lost. It stop hopping or continue to next frequency?
In the first case, it may need 20 * 9ms = 0.18 sec to get another packet, or pause for 0.18s
In the second case, 9ms timeing become very important. RX uses slightly shorter period?
Do you know whether V922 controller use all 20 hopping frequencies?
Wish I can access a frequency analyzer to see the transmission.
Last edit: 18 Feb 2015 18:32 by jimqjp.
18 Feb 2015 19:57 #28848 by victzh
James (HiSky_Official) from RCGroups promised to send me the details of the new HiSky protocol as soon as he's back from Chinese New Year: www.rcgroups.com/forums/showpost.php?p=30783572&postcount=6599
We will know soon!
19 Feb 2015 17:39 #28896 by jimqjp
That is great!
26 Feb 2015 23:50 #29152 by retiredfist
Has anyone purchased a hcp100 anyone this year (2015) and got it all working with a Devo 8S?
If so please can you share your model's ini file.
Got my Devo 8A back now so I would like to try and see if it makes a difference or if it still behaves erratic & won't fly just as the Devo 7.
Although I still believe there's done compatibility issues with the newer hcp100 boards.
I may be stuck with another useless hcp100 heli that won't fly :(
05 Mar 2015 21:11 #29375 by prd
I bought my HCP100 this year and does not work with my old V922 TX.
It is the same that was reported above:
Difficult to bind it, short range, throttle and servo movement moves are weird (delayed & incorrect).
12 Mar 2015 00:00 #29579 by Daryoon
Replied by Daryoon on topic HiSky protocol - HCP100S HCP100 out of sync
Sounds like the classic bad binding problem.
I am flying my HCP100S and all my HiSky heli with my modded Devo 7e without any problem that I can detect.
Time to create page: 0.891 seconds
