Dumb question
24 May 2015 12:35 #32919 by gatonini
Dumb question was created by gatonini
If you copy a protocol folder from a nightly build into 4.01 will they function or is there more to the process. What I am trying to do is to get syma put into the 4.01 build without loading the whole nitely
24 May 2015 13:59 #32926 by mwm
Replied by mwm on topic Dumb question
It almost certainly won't work. While you might be able to get away with taking a protocol from one nightly back a a build or two, we don't test that, and assume that you're going to install the protocol folder with the DFU. And by "won't work", I mean anything from "won't bind" to "will brick your Tx in the middle of a flight."
24 May 2015 14:15 #32929 by Durete
Replied by Durete on topic Dumb question
@Gatonini.
If you are talking of protocol folder, we can assume you are using a 7e.
I tried once on my 7e and it didn't work. In fact the TX becomes unresponsive until I flashed a valid build or change protocol folder to the correct one.
BTW, I think at this moment nightly builds are as safe to use as 4.0.1
24 May 2015 14:37 #32930 by gatonini
Replied by gatonini on topic Dumb question
Thank You
25 May 2015 13:25 #32956 by mwm
Durete wrote: BTW, I think at this moment nightly builds are as safe to use as 4.0.1
Well, maybe. Depends on the build. I noticed that my V323 is unflyable with the latest nightly build, but works fine if I go back to 4.0.1 (well, actually, I copied the V202 protocol source to the nightly tree, tweaked it so it built, and fly that, but you get the idea).
So I recommend not going to the nightly build unless you need something it's got that 4.0.1 doesn't have. Needing a new protocol is a perfect example of a good reason to go to the nightly build.
25 May 2015 14:49 #32961 by PhracturedBlue
Replied by PhracturedBlue on topic Dumb question
Is there a bug report on that mwm?
25 May 2015 15:37 #32963 by mwm
PhracturedBlue wrote: Is there a bug report on that mwm?
deviationtx.com/mantisbt/view.php?id=613
25 May 2015 16:32 #32966 by Durete
mwm, I have flown for months at least 6 different v2x2 Quadcopters (v636 x 2, jxd385, jjrc jj1000 x 3) almost every day using almost all nightlies, and never noticed any problem with v2x2 protocol. I have a Devo 7e with nRF24L01+ module from Banggood.
Could be something related with your nRF24L01 module?
25 May 2015 17:11 #32971 by victzh
Replied by victzh on topic Dumb question
I don't have V323 - I'm aware of bug report but need to think what can be done for remote debugging. The most cruel (for mwm) method of dichotomy of releases and finding one which has this defect is apparently unsustainable - too many releases to build. We just did this at work and it worked perfectly, but I can't request this in clear conscience ;-).
25 May 2015 19:30 #32973 by mwm
Well, a linear search would be a problem, but a binary search looking only at changes to the V202_nrf24l01.c file shouldn't be to bad. Since it didn't fail for you, I can try that.
Also, did you test with one of the larger outdoor WLToys - V262/V393/V666/etc? I'd expect a problem with the V323 (which is basically a hex version of the v262) to be more likely to show up in that than in the indoor micro & nano quads.
26 May 2015 15:23 #33002 by mwm
Ok, I've isolated a single patch that causes the problem. Details (including a patch that backs out the break) in the issue.
28 May 2015 14:46 #33121 by victzh
@mwm, I just came back from a trip, can look into it now.
Can you tell me the module you use in your Devo, is it nRF24L01+ or Beken?
28 May 2015 15:33 #33125 by mwm
nrf24L01. Actually, I have two of them that fail the same way, and both work with the patch. One is this thing from amazon:
www.amazon.com/gp/product/B007ZZANPA?psc...ui_search_detailpage
I still have the second one, and could send it to you if it would help. PM me for details.
The other is the nrf24l01 ufl linked from the module list page.
Time to create page: 0.097 seconds
