MoonTop M9916
04 Sep 2015 18:43 - 04 Sep 2015 18:50 #37445 by goebish
Replied by goebish on topic MoonTop M9916
Yes, it was the same result with the YD-829, for some people it works better with lower power, I guess it has something to do with the xn297 emulation (if I remember well, victzh told there was a slight offset between xn297 / nrf24l01 frequencies,I doubt we can do something better) or antenna length or crystal frequency or something else... I lack expertise.
Last edit: 04 Sep 2015 18:50 by goebish.
04 Sep 2015 18:59 - 04 Sep 2015 19:00 #37447 by IKKI
Replied by IKKI on topic MoonTop M9916
It is normal that the same problem also reflected for the Protocol fy326 and cx 10 green, which I use on a model 3015-2
Last edit: 04 Sep 2015 19:00 by IKKI.
27 Jan 2016 20:33 #42289 by barrymossel
Replied by barrymossel on topic MoonTop M9916
Seems to work with the M9912 for me. Just need a good working model.ini so I can figure out how to change the rates.
05 Feb 2016 09:54 #42623 by goebish
Last round of tests before pull request:
Devo 7e
Devo 10
Select MT99xx protocol and MT9916 format option.
21 Mar 2016 18:29 #44934 by Multirotor Go
Replied by Multirotor Go on topic MoonTop M9916
goebish wrote: Hi,
Devo 7e
Devo 10
how can I upload the mt99xx to my devo 7e? I copy pasted mt99xx on my devo protocol folder but when I look on the model set up it does not show up on the protocols :( is there a model built with flips and rates somewhere for the M9916
21 Mar 2016 18:30 #44935 by goebish
Copying the .mod file is not enough, you also have to flash the .dfu, as you did the first time to install Deviation.
21 Mar 2016 18:41 #44936 by Multirotor Go
goebish wrote: Copying the .mod file is not enough, you also have to flash the .dfu, as you did the first time to install Deviation.
it was so long a go I don't remember, but I will search frequentflyerrc's video, but I downloaded the latest nightlybuilds and inside I don't see a protocol folder? should I use that build?
21 Mar 2016 19:03 #44938 by Multirotor Go
Ok I did it and is working :) How can I get Highers rates it seems to have lower rates then the stock transmitter.
21 Mar 2016 19:05 #44939 by goebish
click the protocol name on the TX then set format option to mt99xx or H7.
21 Mar 2016 19:27 #44940 by goebish
Also for those who are reading this thread, this protocol was not merged into trunk because it breaks the 7e auto nightly build (not enough flash space).
I've to understand why it didn't work when I removed the xorout tables so we should be able to save quite a few bytes of memory ...
21 Mar 2016 22:11 - 21 Mar 2016 22:33 #44942 by Multirotor Go
that i why now it says missing protocol modules when I try to fly other protocols?
the m9916 flies with it but the rates are super low :( I tried H/ but is even lower
Now I get but missing protocol modules all the time in all my models :(
Last edit: 21 Mar 2016 22:33 by Multirotor Go.
21 Mar 2016 22:41 #44943 by goebish
Have you copied all the .mod files from my test archive ?
Regarding rates I'll check what's wrong, I thought it was working but maybe that's not the case...
21 Mar 2016 22:45 #44944 by Multirotor Go
I re flushed my old DFU and the other protocols are working again, but now I can't fly the moon top again :( Also I didn't found a DFU on the latest nightly build How can I flush the latest one with out messing my modules?
21 Mar 2016 22:49 - 21 Mar 2016 22:50 #44945 by Multirotor Go
Nop :ohmy: only the m99xx I will try it now :S
Last edit: 21 Mar 2016 22:50 by Multirotor Go.
21 Mar 2016 22:49 - 21 Mar 2016 22:52 #44946 by goebish
Your "old" dfu probably doesn't include the MT99xx protocol as it is only in test builds, not in the nightly.
Try with hexfet's combo build, maybe it has all the protocols you're using:
www.deviationtx.com/downloads-new/catego...exfet-protocol-combo
... or just wait that I fix this problem with the 7e build then it will be merged with trunk, I'll try work on that during the week.
Last edit: 21 Mar 2016 22:52 by goebish.
21 Mar 2016 22:53 #44947 by Multirotor Go
ok I will wait but were I can find it when its ready? because I downloaded the latest nightly build bit id does not include a dfu
21 Mar 2016 23:11 #44948 by goebish
Just subscribe to this thread, I'll post a test build when it's done.
Download the latest nightly from here:
www.deviationtx.com/downloads-new/category/13-nightly-builds
I just checked the 7e version and it has a dfu ...
21 Mar 2016 23:42 - 21 Mar 2016 23:46 #44950 by Multirotor Go
Ok I will
Thank you goebish for all the work you put in this community I really appreciate it and thoroughly enjoy the results :)
Oh I downloaded this instead the one you linked there. deviation-emu_devo7e-v4.0.1-f5d851e :blink: That's the one I said it didn't have the dfu
Last edit: 21 Mar 2016 23:46 by Multirotor Go.
22 Mar 2016 12:46 - 22 Mar 2016 14:04 #44977 by goebish
Hmmm, can someone make a SPI capture of a MT9916 to check "rate" flag ?
The first link in the first page has an invalid capture, and the 2nd link is dead ...
Last edit: 22 Mar 2016 14:04 by goebish.
29 Mar 2016 20:42 #45398 by Jj30
Replied by Jj30 on topic MoonTop M9916
Hi I'm sorry interrupt in the middle of your convo - I'm new to all this and trying to learn
Website is great btw and I been trying to figure out how to bind my gin h7 to devo 7e
I have the NRF and A7105 modules but I don't see MT99 as one of the options on my Tx to bind with - I downloaded the nightly builds few weeks ago - did I miss something or do I have to download something again ? Thanks in advance for any advice
Time to create page: 0.121 seconds
