WLToys Q282G micro hexa 5.8G FPV
03 Sep 2015 05:50 #37395 by SeByDocKy
Replied by SeByDocKy on topic WLToys Q282G micro hexa 5.8G FPV
I think this protocol is the same also for the second revision of the V686G and probably for some recent JJRC models as well
04 Sep 2015 00:04 #37417 by dc59
Replied by dc59 on topic WLToys Q282G micro hexa 5.8G FPV
SeByDocKy wrote: I think this protocol is the same also for the second revision of the V686G and probably for some recent JJRC models as well
Hope this protocol could be deviated soon! :woohoo:
22 Sep 2015 00:01 #37941 by dc59
Any chance to develop this protocol?
28 Sep 2015 01:39 #38131 by hexfet
Replied by hexfet on topic WLToys Q282G micro hexa 5.8G FPV
The CSV files can't be used because the MISO and ENABLE lines are swapped in the spi decoder. If you don't mind fixing that I will take a look (don't have time to re-export them).
Looks maybe similar to CX10 but has 21 byte packet length.
28 Sep 2015 11:13 #38157 by dc59
hexfet wrote: The CSV files can't be used because the MISO and ENABLE lines are swapped in the spi decoder. If you don't mind fixing that I will take a look (don't have time to re-export them).
What a good news is it !! :woohoo:
I swapped MISO and ENABLE, please check it out !
www.mediafire.com/download/pci4wja1f1k41...wQ282G-SPI-01-03.zip
www.mediafire.com/download/7oam90aahhjll...wQ282G-SPI-04-06.zip
www.mediafire.com/download/1i8gkki28tyeb...wQ282G-SPI-07-09.zip
Thank you very very much.
29 Sep 2015 01:29 #38190 by hexfet
It's very close to CX10. Will try to make it an option on that protocol.
The video capture is strange - two bits are changing in byte 14. Was more than one button push involved? Here's the sequence - how does the timing match what was happening during the capture?
Time [s]	Diff [ms]	Packet ID	MOSI
0.000121	0	                2	A0 55 A4 1E 36 95 DC 05 DC 05 E8 03 DC 05 03 00 10 10 AA AA 00 00
0.971602	971.481	             3262	A0 55 A4 1E 36 95 DC 05 DC 05 E8 03 DC 05 03 21 10 10 AA AA 00 00
1.18021	        208.608	             3962	A0 55 A4 1E 36 95 DC 05 DC 05 E8 03 DC 05 03 01 10 10 AA AA 00 00
2.506299	1326.089	     8412	A0 55 A4 1E 36 95 DC 05 DC 05 E8 03 DC 05 03 20 10 10 AA AA 00 00
2.625486	119.187	             8812	A0 55 A4 1E 36 95 DC 05 DC 05 E8 03 DC 05 03 00 10 10 AA AA 00 00
29 Sep 2015 12:47 #38217 by hexfet
I added a test build for devo 7e and 10. It's a protocol option to CX10. No video or pic support until we get more info on that capture. Channel 5 is light control when Q282 option is selected.
29 Sep 2015 13:22 - 29 Sep 2015 13:24 #38219 by dc59
hexfet wrote: I added a test build for devo 7e and 10. It's a protocol option to CX10. No video or pic support until we get more info on that capture. Channel 5 is light control when Q282 option is selected.
This test build works great! :cheer:
Need to set reversed on AIL & RUD , light control (ch5) works fine, different FixID test OK ,I don't have time to do more test today,sorry!
Regarding video function , I captured SPI again, please check it .
www.mediafire.com/download/8v6m708o67s9y...Video_On_Off-New.zip
Edit : Video function is triggered by one pressed left top button.
Last edit: 29 Sep 2015 13:24 by dc59.
29 Sep 2015 15:33 #38221 by hexfet
Forgot to mention that this version uses a hardcoded txid and rf channels for the Q282 to match your capture. The rf channel algorithm is not the same as CX10, so we need some captures from other stock transmitters for the Q282.
The new video capture shows the same pattern. It's something like bit0 means on/off, and bit5 means "switch to what bit0 says". I'll try to implement something for that.
I verified the test build still works with my Blue-A CX10, but setting the Green or DM007 options causes issues. Need to find what I broke.
29 Sep 2015 19:07 - 29 Sep 2015 19:11 #38229 by hexfet
Test builds are updated. Video support added (pictures should work too). As with some other protocols, you'll need to set channel 8 > 0, then back to < 0 to start recording. Then same again to stop recording. Putting the control on a momentary trim switch works well.
Aileron and rudder are reversed from what they were.
Hoping the bug is fixed too, but can't test at the moment.
Last edit: 29 Sep 2015 19:11 by hexfet.
29 Sep 2015 21:42 #38232 by hexfet
Bug is fixed. Blue-A still works. Any volunteers to test Green and DM007 options?
29 Sep 2015 22:49 #38238 by dc59
Hi Hexfet,
The Second test build 7cb832a works perfect, All functions work fine! :cheer:
It makes Q282G easier to fly , thanks a lot!
But I can't find MJX / Bayang protocols in this build, would it be possible to build a "SUPER COMBO BUILD"? :lol:
30 Sep 2015 01:39 #38245 by hexfet
I added the updated CX10 protocol to the protocol_combo test build. You're welcome :)
30 Sep 2015 03:48 #38251 by dc59
hexfet wrote: I added the updated CX10 protocol to the protocol_combo test build. You're welcome :)
:lol: Thanks !! :lol: :cheer:
I'll give it a try later today!
30 Sep 2015 05:38 #38262 by SeByDocKy
Clap CLap :)
30 Sep 2015 09:39 #38269 by Durete
Replied by Durete on topic WLToys Q282G micro hexa 5.8G FPV
hexfet wrote: Bug is fixed. Blue-A still works. Any volunteers to test Green and DM007 options?
I can test Green option in a few hours.
BTW, Good job Hexfet! :)
30 Sep 2015 20:32 #38291 by Lynxie
Replied by Lynxie on topic WLToys Q282G micro hexa 5.8G FPV
Thanks :) with new v686g works well. But i dont found X and Y calibration.
5 - lights
6 - flips
7 - photo
8 - video
9 - headless
10 - RTH
30 Sep 2015 20:59 #38292 by Durete
Tested Green option. No problem at all, working right :)
30 Sep 2015 23:09 #38296 by hexfet
Durete wrote: Tested Green option. No problem at all, working right :)
Thanks for testing :)
Time to create page: 0.195 seconds
