SKEYE mini drone
- ppisljar
12 Sep 2015 19:50 - 13 Sep 2015 14:45 #37698
by ppisljar
SKEYE mini drone was created by ppisljar
I just got one of this. after opening remote up i can see RF module (i'll upload picture later). however with the black dot on it, so i cannot read its name (any idea how to remove that in a clean way ? )
i am guesing its nrf24l01 (or something compatible).
i connected logic analyzer and tried to decode the SPI.
init:
07 00 29 00 28 00 27 77 26 22 25 10 24 00 23 03 22 00 21 00 20 4E 1D 00 50 73 07 00 50 53 20 40 4B 01 E2 21 C0 4B 00 00 22 D0 FC 8C 02 23 99 00 39 21 24 D9 96 8A DB 25 24 06 0F B6 26 00 00 00 00 27 00 00 00 00 28 00 00 00 00 29 00 00 00 00 2A 00 00 00 00 2B 00 00 00 00 2C 00 12 73 00 2D 36 B4 80 00 2E 41 20 08 04 81 20 CF F7 FE FF FF 07 00 50 53 00 00 30 AB AC AD AE AF
after init process is complete transmiter keeps sending this until stick is moved up and down:
25 XX A0 A1 F4 30 57 47 AA AA BB B1 D4 (8 times)
25 XX A0 0A 1A 2A 3A 12 22 32 42 B1 46 (8 times)
xx: keeps changing
binding:
07 00 29 00 28 00 27 77 26 27 25 10 24 00 23 03 22 00 21 00 20 4E 1D 00 50 73 07 00 50 53 20 40 4B 01 E2 21 C0 4B 00 00 22 D0 FC 8C 02 23 99 00 39 21 24 F9 96 8A DB 25 24 06 0F B6 26 00 00 00 00 27 00 00 00 00 28 00 00 00 00 29 00 00 00 00 2A 00 00 00 00 2B 00 00 00 00 2C 00 12 73 00 2D 36 B4 80 00 2E 41 20 08 04 81 20 CF F7 FE FF FF 07 00 50 53 30 47 57 30 F4 A1
then the regular packet starts being transmitted :
25 XX (this is sent first, XX is changing)
A0 UP FB RR LR CC FM FL TR CRC1 CRC2
where:
UP: 0-FF (going up)
FB: 0-7F forward
90-FF back
RR: 0-7F: rotate left
80-FF: rotate right
LR: 0-7F left
80-FF right
CC: 0x40 : capture foto
0x80 : start/stop video
FM: 0x40 : normal flight mode
0x80: fast flight mode
<--- trim for forward/backward is also included (ORed with the above byte)
FL: 0x40: flip
TR: trim for left/right
CRC1 & CRC2 : crc bytes
so its 13 byte package.
does deviationTx already support some similar protocol ? (nrf24l01 with 13 byte packet, ordered as above ... i am hoping this quad is using some protocol already supported by deviationTX
any idea what the first two bytes do ? (why second byte keeps changing ? )
i hope some somebody can help me out with this.
init:
xx: keeps changing
binding:
where:
UP: 0-FF (going up)
FB: 0-7F forward
90-FF back
80-FF: rotate right
LR: 0-7F left
80-FF right
FL: 0x40: flip
Last edit: 13 Sep 2015 14:45 by ppisljar.
- Richard96816
12 Sep 2015 20:39 #37699
by Richard96816
A wooden tool might be safer.
Replied by Richard96816 on topic SKEYE mini drone
Epoxy will usually succumb to a little heat. Go to youtube and search for 'remove epoxy from circuitboard'. There are a number of examples there. A little heat and some judicious prodding with a knife or some such. Try not to damage the surface you're trying to read.ppisljar wrote: I just got one of these. after opening remote up i can see RF module (i'll upload picture later). however with the black dot on it, so i cannot read its name (any idea how to remove that in a clean way ? )
- ppisljar
13 Sep 2015 09:21 #37709
by ppisljar
Replied by ppisljar on topic SKEYE mini drone
packet is transmitted every 5ms
Hmm ..... seems i have a bad connection with SPI .... any idea what should be the responses ?
i saw response bytes 0E and 2E .... but then sometimes it all goes crazy and i get response bytes 07, 17, 47 ...
i am guesing 2E is the right one ... and when i start getting others i try moving the wires a bit .... most of the time i can get back to 2E responses.
or could it be that just my SPI decoder is messing it up? what do you use for decoding SPI ? (i am using usbee AX test pods logic analyser with builtin SPI decoding)
anyway i recorder the poweron sequence again (i think it was wrong in the previous post)
this is the start of it : ( i recorder this part 5 times and it seems to be always the same )
SDO: 07 00 29 00 28 00 27 77 26 22 25 10 24 00 23 03 22 00 21 00 20 4E 1D 00 50 73 07 00 50 53
SDI: 0E 0E 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 00 0E 0E 0E 00
and then this comes:
20 40 4B 01 E2
8E 00 00 00 00
21 C0 4B 00 00
8E 00 00 00 00
22 D0 FC 8C 02
8E 00 00 00 00
23 99 00 39 21
8E 00 00 00 00
24 D9 96 8A DB
8E 00 00 00 00
25 24 06 0F B6
8E 00 00 00 00
26 00 00 00 00
8E 00 00 00 00
27 00 00 00 00
8E 00 00 00 00
28 00 00 00 00
8E 00 00 00 00
29 00 00 00 00
8E 00 00 00 00
2A 00 00 00 00
8E 00 00 00 00
2B 00 00 00 00
8E 00 00 00 00
2C 00 12 73 00
8E 00 00 00 00
2D 36 B4 80 00
8E 00 00 00 00
2E 41 20 08 04
8E 00 00 00 00
(first line output, second line input)
20 40 4B 01 E2
8E 00 00 00 00
21 C0 4B 00 00
8E 00 00 00 00
22 D0 FC 8C 02
8E 00 00 00 00
23 99 00 39 21
8E 00 00 00 00
24 D9 96 8A DB
8E 00 00 00 00
25 24 06 0F B6
8E 00 00 00 00
26 00 00 00 00
8E 00 00 00 00
27 00 00 00 00
8E 00 00 00 00
28 00 00 00 00
8E 00 00 00 00
29 00 00 00 00
8E 00 00 00 00
2A 00 00 00 00
8E 00 00 00 00
2B 00 00 00 00
8E 00 00 00 00
2C 00 12 73 00
8E 00 00 00 00
2D 36 B4 80 00
8E 00 00 00 00
2E 41 20 08 04
8E 00 00 00 00
- ppisljar
13 Sep 2015 09:22 - 13 Sep 2015 14:33 #37710
by ppisljar
i wrote some comments based on :
dl.dropboxusercontent.com/u/2248531/blog/HCD/HCD_init.txt
07 00 // read status
29 00 //-Write to carrier detect ??
28 00 //-Write to packet counter ??
27 77 // clear status register
26 22 // NRF24_REG_06_RF_SETUP = NRF24_PWR_m12dBm | NRF24_RF_DR_LOW
25 10 // set base rf chan ?
24 00 // retransmit rate ?
23 03 // 5 byte data length
22 00 // ?
21 00 // disable auto Ack ?
20 4E // NRF24_REG_00_CONFIG = NRF24_MASK_RX_DR | NRF24_EN_CRC | NRF24_PWR_UP
1D 00 // -read NRF24_REG_10_TX_ADDR ?
50 73 // -ACTIVATE: R_RX_PL_WID, W_ACK_PAYLOAD, W_TX_PAYLOAD_NOACK
50 53 // select register bank 1
20 40 4B 01 E2 // same as HCD_init
21 C0 4B 00 00 // same as HCD_init
22 D0 FC 8C 02 // same as HCD_init
23 99 00 39 21 // same as HCD_init
24 D9 96 8A DB // gets different from here on
25 24 06 0F B6
26 00 00 00 00
27 00 00 00 00
28 00 00 00 00
29 00 00 00 00
2A 00 00 00 00
2B 00 00 00 00
2C 00 12 73 00
2D 36 B4 80 00
2E 41 20 08 04
22 00 // ?
25 24 06 0F B6
26 00 00 00 00
27 00 00 00 00
28 00 00 00 00
29 00 00 00 00
2A 00 00 00 00
2B 00 00 00 00
2C 00 12 73 00
2D 36 B4 80 00
2E 41 20 08 04
Last edit: 13 Sep 2015 14:33 by ppisljar.
- ppisljar
13 Sep 2015 14:39 #37715
by ppisljar
bind procedure seems to be almoust the same is init ... the only difference is the TX address that is set on the end (and two other small differences)
07 00
29 00
28 00
27 77
26 27 (init: 26 22)
25 10
24 00
23 03
22 00
21 00
20 4E
1D 00
50 73
07 00
50 53
20 40 4B 01 E2
21 C0 4B 00 00
22 D0 FC 8C 02
23 99 00 39 21
24 F9 96 8A DB (init: D9 96 8A DB)
25 24 06 0F B6
26 00 00 00 00
27 00 00 00 00
28 00 00 00 00
29 00 00 00 00
2A 00 00 00 00
2B 00 00 00 00
2C 00 12 73 00
2D 36 B4 80 00
07 00
50 53
30 47 57 30 F4 A1 (this is different from init)
07 00
29 00
28 00
27 77
26 27 (init: 26 22)
25 10
24 00
23 03
22 00
21 00
20 4E
1D 00
50 73
07 00
50 53
20 40 4B 01 E2
21 C0 4B 00 00
22 D0 FC 8C 02
23 99 00 39 21
25 24 06 0F B6
26 00 00 00 00
27 00 00 00 00
28 00 00 00 00
29 00 00 00 00
2A 00 00 00 00
2B 00 00 00 00
2C 00 12 73 00
2D 36 B4 80 00
07 00
50 53
- ppisljar
13 Sep 2015 16:10 - 13 Sep 2015 16:11 #37720
by ppisljar
i tried to update gooblish code for CX-10 to work with my quad .... ::
pastebin.com/A0zsL0cJ
i am able to get the same output on SPI (i have logic analzer connected to confirm i am sending the right thing) as transmitter is sending
- init section decodes to same bytes
- i skip the section between init and bind (seems its broadcasting its address? )
- bind section decodes to same bytes
- i keep sending normal package every 5ms
one thing that is different is the SPI frequency. one period on my transmiter is 3.5us ... but on my arduino its 1.2us ... however that should not affect what nrf24l01 transmits ... its just getting the info faster.
the other thing is that 5ms between packets is a bit too much ... on transmiter its a bit shorter ... 4.4ms or sth like this. (in my opinion this is not game breaking either ?)
however binding is not succesfull. i have no idea how to debug this further ? (as i am already getting same bytes on SPI ... i tought thats it ... it will work
) any tips would be most welcome.
maybe someone who already decoded some similar protocol could help ?
thanks
thanks
Last edit: 13 Sep 2015 16:11 by ppisljar.
- ppisljar
13 Sep 2015 17:23 #37722
by ppisljar
i updated the code to also transmit the part betwen init and bind ... i think its transmitting its address .... and i added channel hopping.
pastebin.com/SE43Ck5G
my quads batters is empty ... will test in 30 minutes. but i dont think it will work. i am thinking:
the chip is not nrf24l01 ... its the BK2421 ( i guess this based on this "magic value part" transmitted over SPI, which is almoust identical to the symax_nrf24l01 driver )
i am trying to send exact copy of what transmiter is sending. but since i am working with nrf24l01 i need to do something different ? (like i could leave the "magic" thing out ... ? )
- ppisljar
- ppisljar
13 Sep 2015 18:55 #37725
by ppisljar
i still have one problem. how to correctly calculate crc code ? (not the CRC send over the network ... but CRC byte inside the packet itself)
any tip would be greately appreciated.
- ppisljar
13 Sep 2015 19:07 #37726
by ppisljar
actually i found out how to calculate checksum (same as symax_nrf24l01)
updated code: pastebin.com/90q7dKKU
however i still dont get past binding process. (instead of sending empty packet i start sending full speed up ... no movement)
- ppisljar
- ppisljar
14 Sep 2015 17:26 - 14 Sep 2015 17:27 #37765
by ppisljar
it works ... but not 100% correct.
what i see is that its VEEERY unresponsive. when i move my pot it takes anywhere from 0.1 to 1seconds to actually take effect.
any idea what could be wrong ? i tried disabling frequency hopping but i more or less same result. (my guess was freq. hopping because it looks like every 10th command is registered by quad ... ) ... was thinking something is wrong with CRC ... but have no way to validate it ?
Last edit: 14 Sep 2015 17:27 by ppisljar.
- ppisljar
15 Sep 2015 08:41 #37776
by ppisljar
was just another bug in my code. now its actually working as it should.
28 Sep 2015 02:08 #38132
Replied by hexfet on topic SKEYE mini drone
Nice work. Were the differences from CX10 small enough that you could add an option to that protocol to support the SKEYE?
- ppisljar
02 Oct 2015 06:45 #38343
by ppisljar
could probably work, yes.
Time to create page: 0.375 seconds
- SKEYE mini drone
