flysky bug?
- xxx
13 Sep 2015 07:41 #37707
by xxx
silverxxx
flysky bug? was created by xxx
I had to implement a (second) flysky rx today in order to test my A7105 module and code, and I noticed there were a couple of channels not receiving.
I found 2 of the channels in the hopping table are incorrect, at least for my transmitter. I use the turnigy i6 ( flysky FS-i6 rebranded).
The new hopping table looks like:
The changes are on the second to last row, index 2 and 5. With the new values the rx receives all packets, except for some random drops.
static const byte tx_channelsxx[16][16] = {
{0x0a, 0x5a, 0x14, 0x64, 0x1e, 0x6e, 0x28, 0x78, 0x32, 0x82, 0x3c, 0x8c, 0x46, 0x96, 0x50, 0xa0},
{0xa0, 0x50, 0x96, 0x46, 0x8c, 0x3c, 0x82, 0x32, 0x78, 0x28, 0x6e, 0x1e, 0x64, 0x14, 0x5a, 0x0a},
{0x0a, 0x5a, 0x50, 0xa0, 0x14, 0x64, 0x46, 0x96, 0x1e, 0x6e, 0x3c, 0x8c, 0x28, 0x78, 0x32, 0x82},
{0x82, 0x32, 0x78, 0x28, 0x8c, 0x3c, 0x6e, 0x1e, 0x96, 0x46, 0x64, 0x14, 0xa0, 0x50, 0x5a, 0x0a},
{0x28, 0x78, 0x0a, 0x5a, 0x50, 0xa0, 0x14, 0x64, 0x1e, 0x6e, 0x3c, 0x8c, 0x32, 0x82, 0x46, 0x96},
{0x96, 0x46, 0x82, 0x32, 0x8c, 0x3c, 0x6e, 0x1e, 0x64, 0x14, 0xa0, 0x50, 0x5a, 0x0a, 0x78, 0x28},
{0x50, 0xa0, 0x28, 0x78, 0x0a, 0x5a, 0x1e, 0x6e, 0x3c, 0x8c, 0x32, 0x82, 0x46, 0x96, 0x14, 0x64},
{0x64, 0x14, 0x96, 0x46, 0x82, 0x32, 0x8c, 0x3c, 0x6e, 0x1e, 0x5a, 0x0a, 0x78, 0x28, 0xa0, 0x50},
{0x50, 0xa0, 0x46, 0x96, 0x3c, 0x8c, 0x28, 0x78, 0x0a, 0x5a, 0x32, 0x82, 0x1e, 0x6e, 0x14, 0x64},
{0x64, 0x14, 0x6e, 0x1e, 0x82, 0x32, 0x5a, 0x0a, 0x78, 0x28, 0x8c, 0x3c, 0x96, 0x46, 0xa0, 0x50},
{0x46, 0x96, 0x3c, 0x8c, 0x50, 0xa0, 0x28, 0x78, 0x0a, 0x5a, 0x1e, 0x6e, 0x32, 0x82, 0x14, 0x64},
{0x64, 0x14, 0x82, 0x32, 0x6e, 0x1e, 0x5a, 0x0a, 0x78, 0x28, 0xa0, 0x50, 0x8c, 0x3c, 0x96, 0x46},
{0x46, 0x96, 0x0a, 0x5a, 0x3c, 0x8c, 0x14, 0x64, 0x50, 0xa0, 0x28, 0x78, 0x1e, 0x6e, 0x32, 0x82},
{0x82, 0x32, 0x6e, 0x1e, 0x78, 0x28, 0xa0, 0x50, 0x64, 0x14, 0x8c, 0x3c, 0x5a, 0x0a, 0x96, 0x46},
{0x46, 0x96, 0x41, 0x5a, 0x50, 0x29, 0x3c, 0x8c, 0x28, 0x78, 0x1e, 0x6e, 0x32, 0x82, 0x14, 0x64},
{0x64, 0x14, 0x82, 0x32, 0x6e, 0x1e, 0x78, 0x28, 0x8c, 0x3c, 0xa0, 0x50, 0x5a, 0x0a, 0x96, 0x46},
};The changes are on the second to last row, index 2 and 5. With the new values the rx receives all packets, except for some random drops.
silverxxx
- SeByDocKy
13 Sep 2015 07:49 #37708
by SeByDocKy
Replied by SeByDocKy on topic flysky bug?
Interesting ....
Are you working on the orignal FLySky protocol ? or the new one (2-way ...) ?
- xxx
13 Sep 2015 10:34 - 13 Sep 2015 10:34 #37711
by xxx
silverxxx
Replied by xxx on topic flysky bug?
I haven't got the tools to do the new one sadly, this is the old one.
silverxxx
silverxxx
silverxxx
Last edit: 13 Sep 2015 10:34 by xxx.
- skretchmer
13 Sep 2015 14:31 #37714
by skretchmer
Replied by skretchmer on topic flysky bug?
... Just wondering if this could be related to the jerky servo movement issue a few on here have seen with the v911 and A7105-D03?......
- midelic
13 Sep 2015 17:05 - 13 Sep 2015 17:10 #37721
by midelic
Replied by midelic on topic flysky bug?
No,...very hard to believe this we;ll cause jerkiness.
The data on flysky is updated every ~1500us One or 2 frames missed it will not be noticed.I would say that this is not even relevant,
To see jerkiness, data should be skipped on more than 22000us(22ms).
For comparison
on Frsky data is updated every 9000us.
on DSM2 every 22000/11000us
and mostly on nrf chips every 4000/8000us.
I believe that jerky movementt with V911 most probably is caused by the RF power output settings. It may be set to maximum.Try reduce RF power and test again
For comparison
Last edit: 13 Sep 2015 17:10 by midelic.
- flysky bug?
