CC2500
- petr512p
28 Oct 2015 16:35 - 28 Oct 2015 16:36 #39307
by petr512p
CC2500 was created by petr512p
Hi, everybody. At once I will tell that I use PROMT Translator. Excuse for mistakes.
I ss2500 bought www.banggood.com/ru/CC2500-PA-LNA-Romote...F24L01-p-922595.html
I connected truly, but the module consumes to 0,59 A thus is heated a little. The DEVO 7E screen flickers a little.
Last edit: 28 Oct 2015 16:36 by petr512p.
- Deal57
28 Oct 2015 17:49 - 28 Oct 2015 17:51 #39314
by Deal57
I just placed an order for one of these but I won't have it for a while. I'd need more info to be of help, so if you've already covered these questions, let me know. Does the power consumption go down when you reduce the TX power (like from 150mw to 10mw)? Are you running it at 3.3v? Is the module grounded to the CYRF module pin 7, and if not, where is your ground?
Replied by Deal57 on topic CC2500
petr512p wrote: Hi, everybody. At once I will tell that I use PROMT Translator. Excuse for mistakes.
Last edit: 28 Oct 2015 17:51 by Deal57.
- petr512p
28 Oct 2015 19:03 - 28 Oct 2015 19:28 #39317
by petr512p
Replied by petr512p on topic CC2500
I connected as on this scheme
I minus now on other perepayal that from CYRF6936 that from the lower minus, consume 0,59.
0,46А 1
0,50А 3
0,55А 30
0,56А 100
0,59А 150
s020.radikal.ru/i706/1510/ae/b6cc43ae6924.jpg
0,46А 1
0,50А 3
0,55А 30
0,56А 100
0,59А 150
Last edit: 28 Oct 2015 19:28 by petr512p.
- aMax
28 Oct 2015 19:23 - 28 Oct 2015 19:39 #39318
by aMax
Replied by aMax on topic CC2500
Check if your antenna wire has any short to GND.
No suitable antenna at hand?
Edit: Even with your NRF it is too much power consumption.
There must be a different bug with your 7e.
Last edit: 28 Oct 2015 19:39 by aMax.
- petr512p
28 Oct 2015 19:30 - 28 Oct 2015 19:42 #39319
by petr512p
I made the antenna of 32 mm, with the connector isn't present near at hand but if to unsolder it nothing changes.
The top part where an anntena, most of all is heated.
I checked the antenna for GND doesn't close, everything is normal.
Last edit: 28 Oct 2015 19:42 by petr512p.
- aMax
- petr512p
- aMax
28 Oct 2015 20:05 - 28 Oct 2015 20:33 #39322
by aMax
If I were in your position, I would start from zero and do a recheck without any modules.
...sorry, I not able to upload photos of any size.
Last edit: 28 Oct 2015 20:33 by aMax. Reason: no upload..-(
- petr512p
28 Oct 2015 20:10 #39323
by petr512p
Most likely simply module not serviceable.
I have NRF24L01 and regular CYRF6936.
It is possible to throw a photo here: This email address is being protected from spambots. You need JavaScript enabled to view it.
At me 03:00 nights I am compelled to go to sleep
- petr512p
- RedSleds
29 Oct 2015 09:02 #39341
by RedSleds
Replied by RedSleds on topic CC2500
To me, there appears to be an obvious cold solder joint on the Csn pad as viewed from both sides of your CC2500 module.
Also a possible mini solder ball that may be shorting the ground and antenna pads under the u.FL connector. At least I can see a strange little solder ball next to your red antenna wire that may extend under the connector.
I don't know if this could be the cause, or not. Just some things that I noticed from your pictures.
Good luck!
Good luck!
- petr512p
- aMax
09 Nov 2015 15:41 - 10 Nov 2015 12:34 #39773
by aMax
How did you manage this...200mA?
But to be honest, if this is your first module, I would never trust it anymore.
You powered it several times without antenna, your antenna wire was soldered to GND...
The Hirose U.FL connector has only one hot connection and this is on the side where the edge is cut for orientation.
Last edit: 10 Nov 2015 12:34 by aMax. Reason: mW>mA...lol
- anansi22
- petr512p
- aMax
10 Nov 2015 20:41 - 10 Nov 2015 20:52 #39854
by aMax
But the problem is, he never used some kind of an antenna...so the T212( or what ever is used as PA/LNA) may be already dud.
anansi22 wrote: Get a proper antenna for the module. Soldering wire is not going to work. You need a low SWR antenna, or one designed for the frequency. Your module will heat up if you put antenna that isn't impedance matched on there.
Last edit: 10 Nov 2015 20:52 by aMax.
Time to create page: 0.366 seconds
- CC2500
