The New Hubsans
- goebish
- NRF Weirdo
16 Jan 2016 01:08 - 22 Jan 2016 17:51 #41806
by goebish
Yes, I think I got it
It's pretty similar to existing HiSky protocol, except it operates @ 250kbps instead of 1Mbps, carries extra failsafe packets and has different timing (frequency hop every 5ms, send 3 packets during those 5ms).
Also, stock transmitter sends bind packets at regular interval, at lowest RF power possible after disabling the PA, that's something we can't do with deviation (at least with the nrf24l01+PA / LNA breakouts most people are using...). That may be a problem so I think I'll only send bind packets when BIND button is pressed in Deviation.
edit: test build available
www.deviationtx.com/forum/protocol-devel...100-and-xy3000#42086
Replied by goebish on topic The New Hubsans
Fernandez wrote: Certainly if you have figured out the protocol, lets add it, thats the full power of deviation one tx for anything !!!
HK310 TX and Robitronic TL-3C
Last edit: 22 Jan 2016 17:51 by goebish.
- goebish
- NRF Weirdo
17 Jan 2016 13:10 - 17 Jan 2016 15:32 #41868
by goebish
Here's a new test build for H501S, please check each features:
CHANNEL5, Leds
CHANNEL6, Altitude Hold
CHANNEL7, Still camera
CHANNEL8, Video camera
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
Devo 7e
Devo 10
sources
Aren't some features mutually exclusive, like RTH or GPS HOLD ? Might be better to have them a on 3 positions channel (No GPS, GPS Hold, RTH) ?
CHANNEL5, Leds
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
Devo 7e
Devo 10
sources
Last edit: 17 Jan 2016 15:32 by goebish.
- delta75
17 Jan 2016 13:19 - 17 Jan 2016 16:19 #41869
by delta75
Replied by delta75 on topic The New Hubsans
oh Good..
sorry i have some mistakes
Ch5 LED works
Ch6 Altitude mode works
Ch7 photo works
Ch8 Video Works
Ch5 LED works
Ch7 photo works
Ch8 Video Works
Last edit: 17 Jan 2016 16:19 by delta75.
- goebish
- NRF Weirdo
17 Jan 2016 16:27 - 17 Jan 2016 16:35 #41871
by goebish
Ok, I'll try to understand why 9 10 and 11 don't work, at least you can disable altitude hold
Last edit: 17 Jan 2016 16:35 by goebish.
- delta75
17 Jan 2016 16:34 - 17 Jan 2016 16:37 #41872
by delta75
i don't test other function.
here is midnight AM 1:30
i will test tomorrow and tell you
now, i tried to mod devo 10
Last edit: 17 Jan 2016 16:37 by delta75.
- goebish
- NRF Weirdo
17 Jan 2016 16:35 - 17 Jan 2016 16:36 #41873
by goebish
Ah OK I understand 1:30AM is not fine to test GPS features, good night then
Last edit: 17 Jan 2016 16:36 by goebish.
- goebish
- NRF Weirdo
17 Jan 2016 20:46 - 17 Jan 2016 20:46 #41883
by goebish
Take care when testing GPS ... looks like some people already had fly-aways, with stock TX
Last edit: 17 Jan 2016 20:46 by goebish.
- delta75
18 Jan 2016 01:04 - 18 Jan 2016 01:17 #41889
by delta75
ok, i know
newest firmware is very unstable
i don't upgrade firmware
it seems to be non official firmware
my firmware version : 1.1.7 , 1.1.6
Last edit: 18 Jan 2016 01:17 by delta75.
- delta75
18 Jan 2016 06:22 - 18 Jan 2016 07:27 #41893
by delta75
analyzed Gps count
146623 R_REGISTER(05_FIFO_DATA) E7 9 E6 0 30 FF CD 0 0 0 0 0 0A 4C 0A CE
data[14] = 0x0A = 10
40361 R_REGISTER(05_FIFO_DATA) E7 3 95 0 7 0 0 0 0 0 0 FF FE 4B 0C 26
data[14] = 0x0C = 12
today is very cold windy , snow
Last edit: 18 Jan 2016 07:27 by delta75.
- goebish
- NRF Weirdo
- goebish
- NRF Weirdo
18 Jan 2016 12:34 - 18 Jan 2016 12:51 #41901
by goebish
Last edit: 18 Jan 2016 12:51 by goebish.
- delta75
18 Jan 2016 13:03 - 18 Jan 2016 13:04 #41902
by delta75
Last edit: 18 Jan 2016 13:04 by delta75.
- goebish
- NRF Weirdo
18 Jan 2016 13:04 - 18 Jan 2016 13:05 #41903
by goebish
Ah, it's +10°C here in France, and I find it's already too cold
Last edit: 18 Jan 2016 13:05 by goebish.
- SpeedGeek
19 Jan 2016 04:08 #41930
by SpeedGeek
Replied by SpeedGeek on topic The New Hubsans
Please forgive me if this was discussed already - I have a Devo7 (not Devo7e) with the upgrade cable. Would I still be able to bind this to my Hubsan x4 plus FPV using this awesome 7e Hubsan mod you've created? Or can this only be done on a 7e not a 7? It was difficult to search for just Devo7 without the "e"
Thanks in advance for any info you can provide.
- delta75
19 Jan 2016 04:14 #41931
by delta75
devo 7 do not support.
- SpeedGeek
19 Jan 2016 04:41 #41932
by SpeedGeek
Thanks for the quick reply - If I can get a Devo 10 for a good price I may pick one up and rebind all my quads to that
I see Devo10 is supported.
- delta75
19 Jan 2016 16:28 - 19 Jan 2016 16:38 #41951
by delta75
v4.0.1-1379648 version
somtimes bind disconnect and reconnect
i return ebed853 version
Last edit: 19 Jan 2016 16:38 by delta75.
- goebish
- NRF Weirdo
19 Jan 2016 16:29 #41952
by goebish
Ah Ok, I'll revert my last commits then. I'll clean it up later.
- delta75
19 Jan 2016 16:58 - 20 Jan 2016 17:08 #41953
by delta75
i tested in door, (not test outdoor, i cannot test outdoor because weather)
RTH works
GPS works
h501s has changeable back side LED color
in GPS mode : bink Green color
in no GPS mode : blink RED color
in GPS + RTH mode : blink blue color
TX power off : blink magenta color
same works original TX
i upload my ini
Fmode : altitude hold on/off
AIL D/R : gps hold on/off
Mix : video start/stop
gear : photo start
ELEV D/R : RTH on/off
RUDD D/R : headless on/off
CHANNEL5, Leds
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
RTH works
GPS works
i upload my ini
gear : photo start
Last edit: 20 Jan 2016 17:08 by delta75.
- delta75
20 Jan 2016 05:10 - 20 Jan 2016 17:09 #41963
by delta75
ebed853 version works Good!!!
but my model.ini need reverse Rudder D/R
i will upload again today
i uploaded new model ini
Last edit: 20 Jan 2016 17:09 by delta75.
Time to create page: 1.095 seconds
- The New Hubsans
