The New Hubsans
- HappyHarry
24 Mar 2016 18:30 #45107
by HappyHarry
Replied by HappyHarry on topic The New Hubsans
ok that build works, and I also reflashed the nightly and it now works also :/ who knows. thanks again for your help and also the work on the protocols
- goebish
- NRF Weirdo
24 Mar 2016 18:31 #45108
by goebish
Replied by goebish on topic The New Hubsans
Weird, but I'm glad that you fixed it
- goebish
- NRF Weirdo
24 Mar 2016 18:38 #45109
by goebish
Regarding the H501S I think I'll make a pull request without telemetry for now as it needs to be reworked but controls work fine.
- HappyHarry
24 Mar 2016 21:49 #45122
by HappyHarry
yeah i'm not sure what was up, the only thing i changed between non working and working was to set the video frequency on the 7e to one of the proper available settings (5.845), though i've tried changing it back to a non available one and it still binds ok. so it may have a flashing issue, or something else entirely but who knows lol
goebish wrote: Weird, but I'm glad that you fixed it
- serapis
14 Apr 2016 03:37 #46466
by serapis
Replied by serapis on topic The New Hubsans
I'm greatly interested in H501S firmware with my Devo7e.
Is this firmware released?
- goebish
- NRF Weirdo
14 Apr 2016 11:45 #46486
by goebish
Yes, it's in the nightly, it has no telemetry except battery voltage tho.
- Xanderzt
24 Jul 2016 21:17 #52106
by Xanderzt
Replied by Xanderzt on topic The New Hubsans
Hi, new to forum, found this image on first page of this topic, but on it only 4 from 8 pins are marked. I'm planning to use Hubsan TX module with naze32, will this 4 pins be enough to fully control this TX module? maybe some one know what are for other pins?
- goebish
- NRF Weirdo
25 Jul 2016 12:22 #52131
by goebish
I don't know what you're trying to do, but I think those pins will be useless to you, they were only useful to connect the logic analyzer to understand the protocol.
The 4 other pins are unconnected.
- Xanderzt
25 Jul 2016 12:45 #52134
by Xanderzt
Thank you for reply. I have Hubsan RX board and Hubsan Remote transmitter and i plan to connect Hubsan RX with arduino and send commands to it. And to do this i'm searching what are the pins of RX board and how connect them to other device to read/write messages.
- Xanderzt
25 Jul 2016 18:03 #52148
by Xanderzt
As i understand 4 connected pins are just SPI pins and if i will connect module with SPI i will be able to RX/TX the data?
- thearne3
26 Jul 2016 14:43 #52169
by thearne3
Replied by thearne3 on topic The New Hubsans
Hi!
Very interesting thread!
I have the Spy Hawk H301S - I think the only member of the 'New Hubsans' not mentioned so far. Many of the same features as the H501S, excluding Follow Me, of course. I've ordered a Logic Analyzer, but wanted to ask if anyone has already done any work on this?
My guess is that much of the work on the 501 will be useful, once the binding protocol is identified.
Thanks for all the work done so far!
- goebish
- NRF Weirdo
26 Jul 2016 15:24 #52171
by goebish
Try with the H501 protocol option, there's a good chance it's using the same protocol.
If not I'd be happy that you post captures
- thearne3
26 Jul 2016 16:20 #52175
by thearne3
I tried my 107c X4 protocol (not the new one) and successfully bound to the plane. Rudder, Elev, Ail and Throttle work. No telemetry (battery was the only one on the X4). Can't risk flying with not control of RTH!
I need to update the FW to Deviation 5 and download an ini file to test the 501, but my guess is that it won't work...
Thanks, again. Will be a few weeks before I have the logic analyzer.
- thearne3
26 Jul 2016 16:25 #52176
by thearne3
Also, I have a Devo 6s, rather than the 7e. As far as I can tell it's a 7e with a nicer touch screen... Which build would you suggest?
- goebish
- NRF Weirdo
26 Jul 2016 16:26 - 26 Jul 2016 16:45 #52177
by goebish
You can take the 5.0 release version or nightly.
Channel mapping:
CHANNEL5, Leds
CHANNEL6, Altitude Hold
CHANNEL7, Still camera
CHANNEL8, Video camera
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
Channel mapping:
CHANNEL5, Leds
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
Last edit: 26 Jul 2016 16:45 by goebish.
- thearne3
26 Jul 2016 19:19 #52182
by thearne3
Sorry - where do I find the H501 protocol option? I see only the *hubsan4 in the User Manual.
- goebish
- NRF Weirdo
26 Jul 2016 19:21 - 26 Jul 2016 19:22 #52183
by goebish
Select the Hubsan4 protocol then "click" the protocol name, that will open a dialog where you can select H107 or H501 format, vTX frequency and telemetry on/off settings.
Last edit: 26 Jul 2016 19:22 by goebish.
- thearne3
26 Jul 2016 19:40 #52184
by thearne3
When I click the name Hubsan4, only the VTx frequency and ON/OFF appear. I have the Devo 6 Version 5 build. Perhaps your protocol is only in the 7 and 10?
- goebish
- NRF Weirdo
26 Jul 2016 20:04 #52185
by goebish
Ah, I thought it was in 5.0 but maybe I'm wrong, get the nightly then.
www.deviationtx.com/downloads-new/category/13-nightly-builds
- thearne3
26 Jul 2016 20:20 #52187
by thearne3
Is the 501 branch in ALL Devo model builds? I have the Devo 6s.
Tom
Tom
Time to create page: 0.495 seconds
- The New Hubsans
