The New Hubsans
16 Jan 2016 01:08 - 22 Jan 2016 17:51 #41806 by goebish
Replied by goebish on topic The New Hubsans
Fernandez wrote: Certainly if you have figured out the protocol, lets add it, thats the full power of deviation one tx for anything !!!
HK310 TX and Robitronic TL-3C
Yes, I think I got it ;)
It's pretty similar to existing HiSky protocol, except it operates @ 250kbps instead of 1Mbps, carries extra failsafe packets and has different timing (frequency hop every 5ms, send 3 packets during those 5ms).
Also, stock transmitter sends bind packets at regular interval, at lowest RF power possible after disabling the PA, that's something we can't do with deviation (at least with the nrf24l01+PA / LNA breakouts most people are using...). That may be a problem so I think I'll only send bind packets when BIND button is pressed in Deviation.
edit: test build available ;)
www.deviationtx.com/forum/protocol-devel...100-and-xy3000#42086
Last edit: 22 Jan 2016 17:51 by goebish.
17 Jan 2016 13:10 - 17 Jan 2016 15:32 #41868 by goebish
Here's a new test build for H501S, please check each features:
CHANNEL5, Leds
CHANNEL6, Altitude Hold
CHANNEL7, Still camera
CHANNEL8, Video camera
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
Devo 7e
Devo 10
sources
Aren't some features mutually exclusive, like RTH or GPS HOLD ? Might be better to have them a on 3 positions channel (No GPS, GPS Hold, RTH) ?
Last edit: 17 Jan 2016 15:32 by goebish.
17 Jan 2016 13:19 - 17 Jan 2016 16:19 #41869 by delta75
Replied by delta75 on topic The New Hubsans
oh Good..
sorry i have some mistakes
Ch5 LED works
Ch6 Altitude mode works
Ch7 photo works
Ch8 Video Works
Last edit: 17 Jan 2016 16:19 by delta75.
17 Jan 2016 16:27 - 17 Jan 2016 16:35 #41871 by goebish
Ok, I'll try to understand why 9 10 and 11 don't work, at least you can disable altitude hold ;)
Last edit: 17 Jan 2016 16:35 by goebish.
17 Jan 2016 16:34 - 17 Jan 2016 16:37 #41872 by delta75
:woohoo:
i don't test other function.
here is midnight AM 1:30
i will test tomorrow and tell you :lol:
now, i tried to mod devo 10
Last edit: 17 Jan 2016 16:37 by delta75.
17 Jan 2016 16:35 - 17 Jan 2016 16:36 #41873 by goebish
Ah OK I understand 1:30AM is not fine to test GPS features, good night then :)
Last edit: 17 Jan 2016 16:36 by goebish.
17 Jan 2016 20:46 - 17 Jan 2016 20:46 #41883 by goebish
Take care when testing GPS ... looks like some people already had fly-aways, with stock TX ;)
Last edit: 17 Jan 2016 20:46 by goebish.
18 Jan 2016 01:04 - 18 Jan 2016 01:17 #41889 by delta75
ok, i know
newest firmware is very unstable
i don't upgrade firmware
it seems to be non official firmware
my firmware version : 1.1.7 , 1.1.6
Last edit: 18 Jan 2016 01:17 by delta75.
18 Jan 2016 06:22 - 18 Jan 2016 07:27 #41893 by delta75
analyzed Gps count
146623 R_REGISTER(05_FIFO_DATA) E7 9 E6 0 30 FF CD 0 0 0 0 0 0A 4C 0A CE
data[14] = 0x0A = 10
40361 R_REGISTER(05_FIFO_DATA) E7 3 95 0 7 0 0 0 0 0 0 FF FE 4B 0C 26
data[14] = 0x0C = 12
:S
today is very cold windy , snow :(
Last edit: 18 Jan 2016 07:27 by delta75.
18 Jan 2016 11:38 #41898 by goebish
Russia ?
18 Jan 2016 12:34 - 18 Jan 2016 12:51 #41901 by goebish
Can you check this build please ?
I did some cleanup and I'd like to make sure I didn't break anything before I start to add telemetry.
Doesn't need to check everything, just that it binds, controls work, vTX frequency change works, leds on/off works.
Devo 7e
Devo 10
Last edit: 18 Jan 2016 12:51 by goebish.
18 Jan 2016 13:03 - 18 Jan 2016 13:04 #41902 by delta75
Russia ?
:lol: south korea
very cold :S
i will test newer firmware tomorrow
i hope sunny day
Last edit: 18 Jan 2016 13:04 by delta75.
18 Jan 2016 13:04 - 18 Jan 2016 13:05 #41903 by goebish
Ah, it's +10°C here in France, and I find it's already too cold :p
Last edit: 18 Jan 2016 13:05 by goebish.
19 Jan 2016 04:08 #41930 by SpeedGeek
Replied by SpeedGeek on topic The New Hubsans
Please forgive me if this was discussed already - I have a Devo7 (not Devo7e) with the upgrade cable. Would I still be able to bind this to my Hubsan x4 plus FPV using this awesome 7e Hubsan mod you've created? Or can this only be done on a 7e not a 7? It was difficult to search for just Devo7 without the "e" :)
Thanks in advance for any info you can provide.
19 Jan 2016 04:14 #41931 by delta75
devo 7 do not support.
19 Jan 2016 04:41 #41932 by SpeedGeek
Thanks for the quick reply - If I can get a Devo 10 for a good price I may pick one up and rebind all my quads to that :) I see Devo10 is supported.
19 Jan 2016 16:28 - 19 Jan 2016 16:38 #41951 by delta75
v4.0.1-1379648 version
somtimes bind disconnect and reconnect
i return ebed853 version
Last edit: 19 Jan 2016 16:38 by delta75.
19 Jan 2016 16:29 #41952 by goebish
Ah Ok, I'll revert my last commits then. I'll clean it up later.
19 Jan 2016 16:58 - 20 Jan 2016 17:08 #41953 by delta75
CHANNEL5, Leds
CHANNEL9, Headless
CHANNEL10, RTH
CHANNEL11, GPS Hold
i tested in door, (not test outdoor, i cannot test outdoor because weather)
RTH works
GPS works
h501s has changeable back side LED color
in GPS mode : bink Green color
in no GPS mode : blink RED color
in GPS + RTH mode : blink blue color
TX power off : blink magenta color
same works original TX
i upload my ini
Fmode : altitude hold on/off
AIL D/R : gps hold on/off
Mix : video start/stop
gear : photo start
ELEV D/R : RTH on/off
RUDD D/R : headless on/off
Last edit: 20 Jan 2016 17:08 by delta75.
20 Jan 2016 05:10 - 20 Jan 2016 17:09 #41963 by delta75
ebed853 version works Good!!! :)
but my model.ini need reverse Rudder D/R
i will upload again today
i uploaded new model ini
Last edit: 20 Jan 2016 17:09 by delta75.
Time to create page: 0.693 seconds
