CX10-C camera button captures
- Edwin
21 Nov 2015 13:50 #40270
by Edwin
CX10-C camera button captures was created by Edwin
Hi all,
My cx10-c flies great with the cx-10 blue-A protocol, I just cannot figure out how to control the camera with my devo 7e. As I understand it the specific control has not been implemented yet in the protocol.
I have made three spi captures on the stock transmitter with my new logic analyser :
- binding of cx10-c to stock transmitter
- 3 times pressing the camera button (takes a snapshot to sd card)
- 4 times pressing the video button (alternately starts and stops the video recording)
the files are here : drive.google.com/file/d/0Bxf-446WD7Euand...OVE/view?usp=sharing
I do not have the skill to figure the protocol out but hope that someone can use these files.
Please note that is the first time using this logic analyser so if something is wrong please let me know.
21 Nov 2015 18:00 #40279
Replied by hexfet on topic CX10-C camera button captures
Please export from the SPI decoder. The csv file should look like
Time [s] Packet ID MOSI MISO
0.112485 0 0x3F 0x0E
0.112519 0 0x4C 0x00
0.112553 0 0x84 0x00
0.112587 0 0x67 0x00
0.112622 0 0x9C 0x00
0.112656 0 0x20 0x00
0.112692 1 0x3E 0x0E
0.112725 1 0xC9 0x00- goebish
- NRF Weirdo
- Edwin
22 Nov 2015 22:06 #40299
by Edwin
Replied by Edwin on topic CX10-C camera button captures
Thanks for the feedback, just re-exported the files and also added the .logicdata saved files.
The files are here : drive.google.com/file/d/0Bxf-446WD7EuZVp...TUE/view?usp=sharing
- goebish
- NRF Weirdo
23 Nov 2015 12:27 #40311
by goebish
Replied by goebish on topic CX10-C camera button captures
Thanks, I'll have a look at that, shouldn't be difficult
- goebish
- NRF Weirdo
23 Nov 2015 13:37 - 23 Nov 2015 19:50 #40312
by goebish
Here's a test firmware for 7e, based on latest nightly:
www.dropbox.com/s/n7z2gdxtqrezjqk/deviat...0.1-053a053.zip?dl=0
source: bitbucket.org/goebish/deviationtx/branch/CX10A#diff
There's a new CX10 protocol format option: "C", channel 7 controls snapshot, channel 8 controls video recording.
Please report
Please report
Last edit: 23 Nov 2015 19:50 by goebish.
- Edwin
23 Nov 2015 15:31 #40314
by Edwin
wow, that's fast.
I will test it tonight and report back.
- Edwin
23 Nov 2015 19:36 #40318
by Edwin
hi goebish,
just tested your build, set the protocol to type C and assigned channel 7 and 8 to a switch
- video on channel 8 works great it works both for toggling video on/off if pressed for a short time or it will record as long as the button is pressed for a longer time and stops when you let go.
- snapshot on channel 7 does not seem to do anything unfortunately...
- goebish
- NRF Weirdo
23 Nov 2015 19:38 #40319
by goebish
ok, I'll try to understand why snapshot doesn't work.
- goebish
- NRF Weirdo
23 Nov 2015 19:49 #40320
by goebish
try this one, should be good:
www.dropbox.com/s/3ps266s588kx2kn/deviat...0.1-ce934b9.zip?dl=0
- Edwin
23 Nov 2015 22:28 - 23 Nov 2015 22:29 #40325
by Edwin
Now the snapshot works as well, nice job! It does seem to lvc sooner but that just might be from all the testing
I will fully charge the quad and check once more
Last edit: 23 Nov 2015 22:29 by Edwin.
- goebish
- NRF Weirdo
23 Nov 2015 22:29 #40326
by goebish
LVC has nothing to do with tx, it's only on rx side.
- Edwin
23 Nov 2015 23:14 - 23 Nov 2015 23:16 #40327
by Edwin
Correct, just tested it and it still does 2:30 - 3:00 of continuous video from full to flashing from low voltage (which also stops the video recording). That's the same as with stock tx.
thanks a lot !
thanks a lot !
Last edit: 23 Nov 2015 23:16 by Edwin.
- goebish
- NRF Weirdo
23 Nov 2015 23:15 - 25 Nov 2015 12:39 #40328
by goebish
Last edit: 25 Nov 2015 12:39 by goebish.
- goebish
- NRF Weirdo
25 Nov 2015 12:38 - 26 Nov 2015 20:35 #40376
by goebish
Hi, I noticed that I made a mistake, I updated an old branch of mine instead of hexfet's latest one with q282 and mouldking protocols ...
Here's a correct one, can you test it please ?
www.dropbox.com/s/cz9bez799imn041/deviat...0.1-093e68f.zip?dl=0
source: bitbucket.org/goebish/deviationtx/branch/protocol_q282
I removed "C" protocol format option, it's useless, just use "Blue-A" protocol, I checked that the new flags don't disturb the "old" blue.
Last edit: 26 Nov 2015 20:35 by goebish.
- Edwin
26 Nov 2015 20:27 #40409
by Edwin
Hi, just updated and set the protocol to blue-a, the quad flies but ch 7 and 8 do not seem to do anything anymore
- goebish
- NRF Weirdo
26 Nov 2015 20:29 #40410
by goebish
ah ok, I see my mistake... I'll fix it.
- goebish
- NRF Weirdo
26 Nov 2015 20:34 #40411
by goebish
Sorry, should be ok now:
www.dropbox.com/s/vb34z9iouo7guv5/deviat...0.1-804fa92.zip?dl=0
- Edwin
26 Nov 2015 20:39 #40413
by Edwin
Cool, now it works as before. Thanks !
Time to create page: 0.086 seconds
- CX10-C camera button captures
