L6052 Lishitoys Déviation Tx ?
07 Jan 2016 19:12 #41482 by DJDavid33
L6052 Lishitoys Déviation Tx ? was created by DJDavid33
Hello everyone .
Can tell me if the L6052 Lishitoys can operate deviation TX?
Protocol which it uses?
Thank you
12 Jan 2016 19:16 #41685 by Cereal_Killer
Replied by Cereal_Killer on topic L6052 Lishitoys Déviation Tx ?
Doesn't work (I have one), it uses some strange rf chip (that's supposedly somewhat compatible with the NRF24L01+).
12 Jan 2016 19:29 #41689 by DJDavid33
Replied by DJDavid33 on topic L6052 Lishitoys Déviation Tx ?
OK thank you I hope soon because the receiver board and cheap;)
I already nRF24L01 the PA on my Devo7E.
07 Mar 2016 17:46 #44225 by victzh
Replied by victzh on topic L6052 Lishitoys Déviation Tx ?
It uses LT8910, unfortunately with data rate specific to it - 62.5kbps - which is not supported by nRF24. It is probably possible to emulate it with CC2500 - it's much more flexible, but it is considerable effort.
07 Mar 2016 19:35 - 07 Mar 2016 19:37 #44230 by DJDavid33
ok thank you I will soon add the CC2500 on my devo 7E
how I could make it work?
the price of the card is really cheap great for making small machine
www.gearbest.com/rc-quadcopters-parts/pp_160082.html
Last edit: 07 Mar 2016 19:37 by DJDavid33.
07 Mar 2016 21:36 #44237 by victzh
You can study the protocol - I already reverse engineered it, and write an emulator for LT8910 62.5kbps mode for CC2500, not unlike I did for XN297 (with huge help from @goebish).
These boards are not that great - first version of L6052 was without Holding Head but much more lively, they say.
08 Mar 2016 00:21 #44240 by DJDavid33
thank you but I have not really understood
I know something not asser.
I'm french translation that's not it.
08 Mar 2016 15:31 #44270 by victzh
Briefly, if you can't program - you can do nothing.
25 Mar 2016 12:23 #45149 by goebish
Replied by goebish on topic L6052 Lishitoys Déviation Tx ?
victzh wrote: I already reverse engineered it, and write an emulator for LT8910 62.5kbps mode for CC2500
Cool ! I was thinking it should be possible to emulate the A7105 with a CC2500 as well.
25 Mar 2016 16:45 #45162 by victzh
May be, but why? LT8910 is a late newcomer with limited support and obscure datasheet. They can stop producing it or modify arbitrarily at any moment, not unlike what they've done with LT8900.
A7105 is a very well-known chip with many people having extensive experience with it. To save on the number of chips? Then there is better one, ADF7242, I'm still working on it. It potentially can replace everything except CYRF6936. Out of interest? Yeah, it can be interesting project.
One more thing - I just re-read my words in your quote and feel that I was misunderstood - it was my suggestion to DJDavid33 that he can write an emulator. It looks like I already did - I did not (yet). I plan to, time permitting.
So many things to do, so little time.
25 Mar 2016 16:48 #45163 by goebish
Yes, that was to save a chip.
Ah OK, I misunderstood and thought you had emulation working.
I received a CC2500 breakout some time ago but didn't have a chance to play with it yet.
25 Mar 2016 18:45 #45172 by victzh
CC2500 is more complicated but much more flexible, with almost every aspect of it tunable and with desktop application allowing you to get the recommended registers for your specific usage - SmartRF. It's also very well documented.
26 Mar 2016 18:18 #45238 by DJDavid33
3 euros Receiver Board ca be top to finally bind a deviation;)
28 Mar 2016 02:10 #45322 by victzh
Hate to disappoint you but this is not the best board. When it started and before they introduced headless mode into it people tested it and said it is almost best in class. But the second (I suspect, current) release is much more tame than the first one.
Going there slowly - I have L6052, but also have many more projects in the queue :-)
Time to create page: 0.106 seconds
