Flysky AFHDS 2A, protocol as used i10, i6, iT4,
31 May 2016 08:42 #49618 by dc59
goebish wrote:
dc59 wrote: I have ST-Link USB , but I don't know to update firmware by ST-Link, and where can I download v1.6 FW?
I'll extract it when I receive it then make an utility program to change the RX ID.
:woohoo: :woohoo: :woohoo: Many thanks!
31 May 2016 11:07 #49624 by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
My receiver www.banggood.com/Flysky-2_4G-6CH-FS-iA6B...s-Port-p-978603.html
In order to bind it this Rx, I must connect, signal pin to Gnd (VCC port next to channel 6) then power the receiver. The led on Rx will indicate the bind status flashing.
There is a push button on the Rx, but do not know where it is used for, I couldn't get Rx into bind by pushing the buttton and powering etc.
31 May 2016 11:09 - 31 May 2016 11:36 #49625 by goebish
The update button is not used for binding, to my understanding it only resets the RX so it can enter bootloader mode for FW update over the air. (it connects reset pin of the MCU to GND when pressed).
Last edit: 31 May 2016 11:36 by goebish.
01 Jun 2016 00:34 #49690 by dc59
Evil Pusher wrote: @dc59
- what will happen, if you downgrade your i6 TX to "default" firmware?
Bad luck as same result as hacked firmware,it cannot update. :(
01 Jun 2016 12:17 #49733 by Evil Pusher
Replied by Evil Pusher on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
@dc59 :(
- sorry, for the moment - no idea.
:cheer:
This morning the big brother of my devo 6 arrived. Y E S :) Devo 12s - only 249,90 inkl. shipping within germany - incl. case and RX1202 asf. - brand new - waranty .... GREAT deal.
deviation 5.0.0 installed (a little tricky....calibrating screen bug - but works now). Tested with RX1202 and oRX920 (s.bus version).... works incl. telemetry. NICE
But the 3in1 modul is still not here. Also I just ordered only one - so I have to make a decision. Hope you can help.
What do you think? Do we have more devo 6 or more devo 12s users? I would start testing - if the 3in1 modul is here - by using the TX having the bigger community.
Let me know. THX.
D.I.Y. or die
02 Jun 2016 00:38 #49794 by dc59
As I know so far , mwm has DEVO 6 !
03 Jun 2016 08:32 #49856 by Alexandro
Replied by Alexandro on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
im Testing the new Build,
where can i find the Failsave Menu ?
greetings Alex
03 Jun 2016 08:36 - 03 Jun 2016 09:30 #49857 by goebish
Hi Alexandro,
Failsafe is set per channel:
Model menu -> Mixer -> 1-ELE (for example) -> Fail-Safe (click ENT to enable then set a value)
Evil Pusher, I just received your RXs, thanks, I'll have a look at that during the week end :)
Last edit: 03 Jun 2016 09:30 by goebish.
03 Jun 2016 08:57 #49859 by Fernandez
Goebish that is great!
What would be really nice feature would be a button "use current", all boxes are filled with current values of channels depending on sticks and switches.
03 Jun 2016 08:59 #49860 by Alexandro
Thanks.
On Devo8s Failsave works good, Volt1 and RSSi is Ok.
Restart does very fast Rebind, all looks good !
only 1 Problem with the Deviation itself, on Power cycle of the TX some of the Telemetry Boxes are jumping back to Disable.
I think there is a Bug inside the Power Off Routine ?
greeting Alex
03 Jun 2016 09:06 - 03 Jun 2016 09:07 #49862 by goebish
Fernandez wrote: What would be really nice feature would be a button "use current", all boxes are filled with current values of channels depending on sticks and switches.
Maybe you could suggest that in the development forum, not sure how it could be well integrated into the UI though.
Alexandro wrote: only 1 Problem with the Deviation itself, on Power cycle of the TX some of the Telemetry Boxes are jumping back to Disable.
Next test build should have a few issues fixed, if there's still problems then check the bug isn't already in the bug tracker then open a ticket for it ;)
Last edit: 03 Jun 2016 09:07 by goebish.
03 Jun 2016 09:28 #49864 by goebish
Next steps:
- Help people updating their RXs to the latest firmware version without an actual transmitter (via ST-Link)
- Store RX ID somewhere else than in protocol options
- Write AFHDS 2A telemetry type
- Add missing telemetry sensors
... then my work here should be over :)
03 Jun 2016 11:40 - 03 Jun 2016 11:44 #49867 by john
If I don't confuse , maybe this is first firmware about Rx on deviation. Enough feature
Can not believe a7105 with telemetry and full range .
Enjoy
Last edit: 03 Jun 2016 11:44 by john.
03 Jun 2016 17:30 #49888 by irishobo
This will great for us Turnigy i10 transmitter users that cannot currently update our flysky receivers. Thanks for you hard work!
04 Jun 2016 08:25 #49907 by goebish
Can someone take close pictures of the Flysky iA6 and iA10 RX, I want to make sure that's the same hardware than the Turnigy's before we try to flash them.
04 Jun 2016 12:07 #49915 by goebish
Sorry, but I may not be very active here this week-end as I just got some new toys :p
File Attachment:
File Attachment:
04 Jun 2016 12:18 #49916 by Evil Pusher
MAN - now you are able, to cut the hairs in your nose - fly inside and cut it - - - - quaint petit toy :)
Enjoy it ;) - I also will go outside and give myself a reason to buy some new airplan.
D.I.Y. or die
04 Jun 2016 12:34 - 04 Jun 2016 12:35 #49917 by HappyHarry
Replied by HappyHarry on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
nice purchases, though the inductrix is a little tame if you already know how to fly, they should have included an agility mode
also that hack rf1 looks like a great piece of kit!
Last edit: 04 Jun 2016 12:35 by HappyHarry.
05 Jun 2016 14:30 #49953 by stinkydiver73
Replied by stinkydiver73 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Flysky / Turnigy is same, but iA6 is with some 8bit MCU, iA6b (v2) is STM32.
Can you send me an updated fw bin?
05 Jun 2016 14:43 #49954 by goebish
Here it is:
www.dropbox.com/s/ykrm7av00g1ueyc/iA6B_1.6.bin?dl=1
Backup your firmware first, just in case ;)
You'll have to rebind after flashing as this will change your RX ID.
Note that I take no responsibility of what could happen :p
Please report !
Time to create page: 0.403 seconds
