Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- dc59
31 May 2016 08:42 #49618
by dc59
Many thanks!
Replied by dc59 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
goebish wrote:
I'll extract it when I receive it then make an utility program to change the RX ID.dc59 wrote: I have ST-Link USB , but I don't know to update firmware by ST-Link, and where can I download v1.6 FW?
- Fernandez
31 May 2016 11:07 #49624
by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
My receiver
www.banggood.com/Flysky-2_4G-6CH-FS-iA6B...s-Port-p-978603.html
In order to bind it this Rx, I must connect, signal pin to Gnd (VCC port next to channel 6) then power the receiver. The led on Rx will indicate the bind status flashing.
There is a push button on the Rx, but do not know where it is used for, I couldn't get Rx into bind by pushing the buttton and powering etc.
- goebish
- NRF Weirdo
31 May 2016 11:09 - 31 May 2016 11:36 #49625
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
The update button is not used for binding, to my understanding it only resets the RX so it can enter bootloader mode for FW update over the air. (it connects reset pin of the MCU to GND when pressed).
Last edit: 31 May 2016 11:36 by goebish.
- dc59
01 Jun 2016 00:34 #49690
by dc59
Bad luck as same result as hacked firmware,it cannot update.
Evil Pusher wrote: @dc59
- what will happen, if you downgrade your i6 TX to "default" firmware?
- Evil Pusher
- D.I.Y. or die
01 Jun 2016 12:17 #49733
by Evil Pusher
D.I.Y. or die
Replied by Evil Pusher on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
@dc59
- sorry, for the moment - no idea.
This morning the big brother of my devo 6 arrived. Y E S
Devo 12s - only 249,90 inkl. shipping within germany - incl. case and RX1202 asf. - brand new - waranty .... GREAT deal.
deviation 5.0.0 installed (a little tricky....calibrating screen bug - but works now). Tested with RX1202 and oRX920 (s.bus version).... works incl. telemetry. NICE
But the 3in1 modul is still not here. Also I just ordered only one - so I have to make a decision. Hope you can help.
What do you think? Do we have more devo 6 or more devo 12s users? I would start testing - if the 3in1 modul is here - by using the TX having the bigger community.
Let me know. THX.
Let me know. THX.
D.I.Y. or die
- dc59
02 Jun 2016 00:38 #49794
by dc59
As I know so far , mwm has DEVO 6 !
- Alexandro
03 Jun 2016 08:32 #49856
by Alexandro
Replied by Alexandro on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
im Testing the new Build,
where can i find the Failsave Menu ?
greetings Alex
greetings Alex
- goebish
- NRF Weirdo
03 Jun 2016 08:36 - 03 Jun 2016 09:30 #49857
by goebish
Last edit: 03 Jun 2016 09:30 by goebish.
- Fernandez
03 Jun 2016 08:57 #49859
by Fernandez
Goebish that is great!
What would be really nice feature would be a button "use current", all boxes are filled with current values of channels depending on sticks and switches.
- Alexandro
03 Jun 2016 08:59 #49860
by Alexandro
Thanks.
On Devo8s Failsave works good, Volt1 and RSSi is Ok.
Restart does very fast Rebind, all looks good !
only 1 Problem with the Deviation itself, on Power cycle of the TX some of the Telemetry Boxes are jumping back to Disable.
I think there is a Bug inside the Power Off Routine ?
greeting Alex
Thanks.
greeting Alex
- goebish
- NRF Weirdo
03 Jun 2016 09:06 - 03 Jun 2016 09:07 #49862
by goebish
Maybe you could suggest that in the development forum, not sure how it could be well integrated into the UI though.
Next test build should have a few issues fixed, if there's still problems then check the bug isn't already in the bug tracker then open a ticket for it
Fernandez wrote: What would be really nice feature would be a button "use current", all boxes are filled with current values of channels depending on sticks and switches.
Alexandro wrote: only 1 Problem with the Deviation itself, on Power cycle of the TX some of the Telemetry Boxes are jumping back to Disable.
Last edit: 03 Jun 2016 09:07 by goebish.
- goebish
- NRF Weirdo
03 Jun 2016 09:28 #49864
by goebish
Next steps:
- Help people updating their RXs to the latest firmware version without an actual transmitter (via ST-Link)
- Store RX ID somewhere else than in protocol options
- Write AFHDS 2A telemetry type
- Add missing telemetry sensors
... then my work here should be over
- john
03 Jun 2016 11:40 - 03 Jun 2016 11:44 #49867
by john
Replied by john on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
If I don't confuse , maybe this is first firmware about Rx on deviation. Enough feature
Can not believe a7105 with telemetry and full range .
Enjoy
Enjoy
Last edit: 03 Jun 2016 11:44 by john.
- irishobo
03 Jun 2016 17:30 #49888
by irishobo
Replied by irishobo on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
This will great for us Turnigy i10 transmitter users that cannot currently update our flysky receivers. Thanks for you hard work!
- goebish
- NRF Weirdo
04 Jun 2016 08:25 #49907
by goebish
Can someone take close pictures of the Flysky iA6 and iA10 RX, I want to make sure that's the same hardware than the Turnigy's before we try to flash them.
- goebish
- NRF Weirdo
04 Jun 2016 12:07 #49915
by goebish
- Evil Pusher
- D.I.Y. or die
04 Jun 2016 12:18 #49916
by Evil Pusher
D.I.Y. or die
MAN - now you are able, to cut the hairs in your nose - fly inside and cut it - - - - quaint petit toy
Enjoy it
- I also will go outside and give myself a reason to buy some new airplan.
Enjoy it
D.I.Y. or die
- HappyHarry
04 Jun 2016 12:34 - 04 Jun 2016 12:35 #49917
by HappyHarry
Replied by HappyHarry on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
nice purchases, though the inductrix is a little tame if you already know how to fly, they should have included an agility mode
also that hack rf1 looks like a great piece of kit!
Last edit: 04 Jun 2016 12:35 by HappyHarry.
- stinkydiver73
05 Jun 2016 14:30 #49953
by stinkydiver73
Replied by stinkydiver73 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Flysky / Turnigy is same, but iA6 is with some 8bit MCU, iA6b (v2) is STM32.
Can you send me an updated fw bin?
- goebish
- NRF Weirdo
05 Jun 2016 14:43 #49954
by goebish
Here it is:
www.dropbox.com/s/ykrm7av00g1ueyc/iA6B_1.6.bin?dl=1
Backup your firmware first, just in case
You'll have to rebind after flashing as this will change your RX ID.
Note that I take no responsibility of what could happen
Please report !
Please report !
Time to create page: 2.208 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
