Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- joloebig
26 Jun 2016 10:07 #51092
by joloebig
Replied by joloebig on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
yes, after upgrade the tgy tx to 1.0.8 and and upgrading rx telemetry was lost.
after the restore to 1.0.? (was the file from you dropbox and also downgrade tx to 1.0.7 is working.
later on i will test it with devo 12
- goebish
- NRF Weirdo
26 Jun 2016 10:09 - 26 Jun 2016 10:12 #51093
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
That's mind blowing, I don't understand why they would have removed telemetry from the latest version (EU regulation ?).
Also, that's good to know the TX firmware can be downgraded, I thought it wasn't possible.
FIY my iA10 firmware backup is the one that goes with TGY-i10 1.0.7.
Last edit: 26 Jun 2016 10:12 by goebish.
- joloebig
28 Jun 2016 18:23 #51153
by joloebig
don't think so, i guess iti is a bug....
the tx can be downgradevia the gui on the tx, but not the rx.
anyhow, it workts for me.
can i support the further devolepment for the telemety with external sensors?
i have some voltage, rpm(optic) and iirc one temp sensor with i10 plugs workless in my box.
if this will help, pm me you adress.
btw. greart firmware.
king regards
jo
king regards
jo
- goebish
- NRF Weirdo
03 Jul 2016 09:34 #51273
by goebish
I should have some free time in the next few days to complete telemetry, I *think* I already understand how multiple sensors of the same kind works so if you've 2 or 3 external voltage sensors for example you should be able to check if I'm right.
- joloebig
03 Jul 2016 09:58 #51274
by joloebig
yes, i can do this.
reg
jo
reg
jo
- ketsa
11 Jul 2016 18:44 #51557
by ketsa
Replied by ketsa on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Just to make sure before I order a FS-ia6B :
Will I be able to add this protocol in my devo 7E (non ultimate)?
I have A7105 installed and tested.
Thanks.
Thanks.
- goebish
- NRF Weirdo
11 Jul 2016 18:46 #51558
by goebish
Yes, it works on the 7e.
Note that you may have to update the iA6b if you want RSSI:
www.rcgroups.com/forums/showthread.php?t=2677694
- ketsa
11 Jul 2016 18:58 #51559
by ketsa
Great !
And I have an ST-Link if needed.
Thanks a lot for the amazing job btw.
- Bacchanal
18 Jul 2016 14:44 #51829
by Bacchanal
Replied by Bacchanal on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hi guys, first post!
First of all I'd like to thank all the developers of deviationtx and its protocols - you have given me hours of fun flying quads. Being an engineer myself I can really appreciate the complexity of the work you guys have put in. Keep up the good work, it is appreciated!
I've tried Devo 7E build posted a few pages ago and it works great in pwm mode with my recently bought unmodified Flysky FS-iA6B. I'd like to use ppm to free up a uart port on my flip32 running the newest cleanflight.
Is this possible with the current state of the deviation software? I've tried connecting CH1 from the receiver to CH1 on the Flip32 and set cleanflight to PPM. I also tried different settings in the /Model setup/PPM In/ menu on the Devo 7E. Changing that setting sometimes prevents me from getting back to the "main view". Is this a bug or - probably more likely - user error?
I guess the main question is: Is what I'm trying to do possible?
- goebish
- NRF Weirdo
18 Jul 2016 14:49 - 18 Jul 2016 14:50 #51830
by goebish
This is a bug in Deviation, maybe it's been fixed since I built this version...
I'll try to post an updated version tonight, not sure it fixes this issue tho.
But yes, what you're trying to do should work, at least it's working with Devo 10 + iA10, just enable PPM in protocol settings dialog to enable PPM on output #1, I haven't tried with a iA6B but I suppose it works the same..
Last edit: 18 Jul 2016 14:50 by goebish.
- Bacchanal
18 Jul 2016 14:56 #51831
by Bacchanal
Thanks for the quick reply! I'll continue trying. Must have made a mistake somewhere along the way.
- Arise
18 Jul 2016 15:47 #51835
by Arise
Replied by Arise on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Just curious, is there any difference between this AFHDS 2A and the old AFHDS? Like in reliability/strenght/whatever?
Also what exactly makes this system "telemetry aware", is this dependent on the dual antenna system or is a dual antenna system used only to get the best signal via diversity?
- goebish
- NRF Weirdo
- dropax
24 Jul 2016 10:15 #52077
by dropax
Replied by dropax on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hello goebish!
Trying to bind an Eachine iA6 (rebranded FlySky, 6 channel park flyer PWM RX) to a 7e with A7105 module and your latest build - no joy.
LED on the RX (in bind mode) goes from fast blinking to slow blinking and stays slowly blinking with bind plug removed. Tried channel count from 6 to 12 (max on 7e).
Are there any chances to make it work or am I lost with this RX and it only works on the iA6B?
- goebish
- NRF Weirdo
24 Jul 2016 11:00 #52080
by goebish
Maybe I could make it work if you can make some captures on a TX that works with it ...
There is hope and the protocol should not be that different if the LED on the RX goes from fast to slow blinking, at least there's already some sort of communication.
I could buy one of those RX as I still have Alexandro's TGY-i10 TX but I don't think it would bind to a FlySky RX so that wouldn't help.
- joloebig
24 Jul 2016 11:09 #52081
by joloebig
reg
jo
it should work, i talked to some guys on a meeting, the most off are flying flysky; i6 and i10 also both protocols.goebish wrote: I could buy one of those RX as I still have Alexandro's TGY-i10 TX but I don't think it would bind to a FlySky RX so that wouldn't help.
reg
jo
- goebish
- NRF Weirdo
24 Jul 2016 11:13 #52082
by goebish
Which brands are their transmitters ? FlySky or Turnigy ?
I've a Turnigy i10 (Alexandro's), I'm not sure it will bind with a FlySky iA6.
If you're sure the Turnigy TX can bind to a FlySky RX then I'll order one right now.
- joloebig
24 Jul 2016 11:27 - 24 Jul 2016 11:28 #52083
by joloebig
it is 2. hand info,
the guys told me they are using al kinds off rx(tgy bangood,flysky), binding mostly to a TGY i10 running 1.07
alexandro told me simular; he bind a old 3 ch. flykky car rx to i10.
so i'm 90% shure it works
Last edit: 24 Jul 2016 11:28 by joloebig.
- Ryou
24 Jul 2016 12:22 - 24 Jul 2016 12:23 #52084
by Ryou
Replied by Ryou on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hello everyone.
I check the operation of the receiver to have.
FS-A6
FS-IA4B
FS-IA6
FS-IA6B
FS-IA10
Operating in all of the above.
Great job.
I am glad when the 'S.BUS' also become possible, if possible.
FS-A6
FS-IA4B
FS-IA6
FS-IA6B
FS-IA10
Great job.
Last edit: 24 Jul 2016 12:23 by Ryou.
- goebish
- NRF Weirdo
24 Jul 2016 12:29 - 24 Jul 2016 12:29 #52085
by goebish
@joloebig ok I'll get a FS iA6 then (not B ) to try to get it to work in Deviation too.
@Ryou sbus is not possible, those RX can only do PWM, PPM and ibus.
Last edit: 24 Jul 2016 12:29 by goebish.
Time to create page: 2.392 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
