Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- goebish
- NRF Weirdo
22 Apr 2016 12:54 #46982
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- Alexandro
22 Apr 2016 14:46 - 22 Apr 2016 14:48 #46990
by Alexandro
Replied by Alexandro on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Nice , Frankenstein TX
Time is not a Problem !
greeting Alex
-> BTW The RX has Modell match <-
greeting Alex
Last edit: 22 Apr 2016 14:48 by Alexandro.
- victzh
22 Apr 2016 15:02 #46991
by victzh
Replied by victzh on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
What a nice, polite people! They marked the connections so clearly it's a pleasure to solder to such points! A bit more courtesy - and we'd had the protocol itself described fully in a nicely formatted document
Sorry for off-topic, what brand is this battery meter?
- goebish
- NRF Weirdo
22 Apr 2016 15:20 - 22 Apr 2016 16:07 #46992
by goebish
This is a BVM-8S (+/- $15 on ebay), nice battery meter, it even has an external buzzers module to make the programmable alarm louder.
victzh wrote: what brand is this battery meter?
Last edit: 22 Apr 2016 16:07 by goebish.
- goebish
- NRF Weirdo
22 Apr 2016 16:11 - 22 Apr 2016 16:11 #46996
by goebish
I wish the manufacturer was so cooperative, but I don't even dare to ask
victzh wrote: A bit more courtesy - and we'd had the protocol itself described fully in a nicely formatted document
Last edit: 22 Apr 2016 16:11 by goebish.
- goebish
- NRF Weirdo
23 Apr 2016 13:42 - 23 Apr 2016 14:02 #47046
by goebish
Some progress, simple homemade TX (Arduino+A7105) sending packets to a ia10 RX (which RXID and expected TXID / channel sequence is already known), that's kinda cheating but at least that confirms that we can do it with the A7105
Also, looks like the RX is permissive as I don't even send all the packets the stock TX sends at startup ...
Last edit: 23 Apr 2016 14:02 by goebish.
- Fernandez
23 Apr 2016 18:54 #47069
by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Fantastic, it is like digital puzzle for you? Probably feels good when solved.... Full credits from my side!
Any idea abaout the functioning of dual antennas on the tx a diversity switch or two independent parallel stages? What would tx do with diversity? is there difference between A7105 and A7106?
- goebish
- NRF Weirdo
23 Apr 2016 19:10 #47070
by goebish
stinkydiver73 explains how antenna switching works in this thread:
www.deviationtx.com/forum/protocol-devel...4?limitstart=0#44007
Of course that won't be implemented in Deviation as we're using "simple" A7105 modules, without an extra RF switch and only 1 antenna.
There are a few differences between A7105 & A7106, but nothing we really care.
- victzh
23 Apr 2016 19:16 #47071
by victzh
@goebish, congrats!
- goebish
- NRF Weirdo
23 Apr 2016 21:54 - 23 Apr 2016 22:04 #47077
by goebish
Thanks victzh, I owe you, hexfet, PB, midelic ... most of the stuffs I know about this business, all of that was just black magic to me before I registered to deviationtx.com
The protocol is revealing its mysteries ... I think I found how to set PWM refresh rate.
Last edit: 23 Apr 2016 22:04 by goebish.
- dc59
25 Apr 2016 02:50 #47131
by dc59
Replied by dc59 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hi Goebish,
You really did a great job!
- goebish
- NRF Weirdo
25 Apr 2016 23:13 - 25 Apr 2016 23:54 #47191
by goebish
Just an update
- now working on Devo
- Configurable servo refresh rate
- RX voltage telemetry
I believe it deserves its own protocol, not just a FlySky protocol format option as it is quite different and has its own options.
Next step: work on bind stage, knocking on wood, I hope frequency hopping is working à la HiSky.
See you in ~2 weeks now
Last edit: 25 Apr 2016 23:54 by goebish.
- dc59
26 Apr 2016 00:30 #47196
by dc59
26 Apr 2016 02:32 #47204
Replied by hexfet on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Very nice! Enjoy your holiday
- Alexandro
26 Apr 2016 07:57 - 26 Apr 2016 07:58 #47215
by Alexandro
Good Holidays goebish
Last edit: 26 Apr 2016 07:58 by Alexandro.
- Fernandez
26 Apr 2016 08:00 #47216
by Fernandez
Looking good Goebish!! Have a nice holiday enjoy !!
Flysky i-bus serial protocol, recently also compatible with Cleanflight/Betaflight Flightcontrollers.
Full digital system as Deviation what can we say about latency? Would it mean 50Hz samples= <20ms, variable latency? What would be the max samping rate?
How is that working? Is it real samples over the air, or the sample outputrate set at the RX?
With this positive news, I think can order some Rx.......
- Fernandez
26 Apr 2016 09:02 #47218
by Fernandez
Not sure if it is usefull, I came across this for RSSI, it seems that it is sent back to the Tx alos.
www.insidegadgets.com/2015/09/03/adding-...-tgy-i6-transmitter/
- dc59
26 Apr 2016 09:54 #47221
by dc59
Which version of Cleanflight/Betaflight dose support i-BUS ?
Thank you!
Fernandez wrote: Flysky i-bus serial protocol, recently also compatible with Cleanflight/Betaflight Flightcontrollers.
Thank you!
- Fernandez
26 Apr 2016 10:13 #47222
by Fernandez
- dc59
26 Apr 2016 10:39 #47223
by dc59
Thanks a lot.
Fernandez wrote: Off topic/
github.com/borisbstyle/betaflight/releases/
Really stable and recommended B 2.6.1
Thanks a lot.
Time to create page: 0.826 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
