WLtoys Q242G
23 Jan 2016 20:41 #42147 by hexfet
Replied by hexfet on topic WLtoys Q242G
Yes, I was trying to save some code space :oops: Should be fixed now.
23 Jan 2016 20:50 #42148 by SeByDocKy
Replied by SeByDocKy on topic WLtoys Q242G
hexfet wrote: Yes, I was trying to save some code space :oops: Should be fixed now.
Ok working fine now :)
I will just check than rates are the same with the original TX
23 Jan 2016 20:53 #42149 by SeByDocKy
Yes ....rates are less important :( ... It's strange I captured stick mouvements in expert mode ...
23 Jan 2016 21:15 #42151 by hexfet
Okay, test build is updated. May take another iteration after this as it's not clear what bits do what for rates.
23 Jan 2016 21:23 #42152 by SeByDocKy
hexfet wrote: Okay, test build is updated. May take another iteration after this as it's not clear what bits do what for rates.
Ok rates are great now but again drifting forward. I had to apply 22 rear trim to stabilize ....
23 Jan 2016 21:58 #42153 by hexfet
Okay please try again. Should be back to same as before except for what seems to be the rate bit.
23 Jan 2016 22:04 #42154 by SeByDocKy
hexfet wrote: Okay please try again. Should be back to same as before except for what seems to be the rate bit.
Ok :) seems perfect now :) Great Job as usual :)
23 Jan 2016 22:44 #42155 by hexfet
Thanks! I've updated the protocol_q282 pull request with the changes.
24 Jan 2016 17:28 #42173 by SeByDocKy
Demo flight
Thanks again :)
Time to create page: 0.710 seconds
