WLtoys Q242G
23 Jan 2016 20:41 #42147
Replied by hexfet on topic WLtoys Q242G
Yes, I was trying to save some code space
Should be fixed now.
- SeByDocKy
23 Jan 2016 20:50 #42148
by SeByDocKy
Ok working fine now
I will just check than rates are the same with the original TX
Replied by SeByDocKy on topic WLtoys Q242G
hexfet wrote: Yes, I was trying to save some code space
Ok working fine now
- SeByDocKy
23 Jan 2016 20:53 #42149
by SeByDocKy
Yes ....rates are less important
... It's strange I captured stick mouvements in expert mode ...
23 Jan 2016 21:15 #42151
Okay, test build is updated. May take another iteration after this as it's not clear what bits do what for rates.
- SeByDocKy
23 Jan 2016 21:23 #42152
by SeByDocKy
Ok rates are great now but again drifting forward. I had to apply 22 rear trim to stabilize ....
hexfet wrote: Okay, test build is updated. May take another iteration after this as it's not clear what bits do what for rates.
23 Jan 2016 21:58 #42153
Okay please try again. Should be back to same as before except for what seems to be the rate bit.
- SeByDocKy
23 Jan 2016 22:04 #42154
by SeByDocKy
Ok
seems perfect now
Great Job as usual
hexfet wrote: Okay please try again. Should be back to same as before except for what seems to be the rate bit.
Ok
23 Jan 2016 22:44 #42155
Thanks! I've updated the protocol_q282 pull request with the changes.
- SeByDocKy
24 Jan 2016 17:28 #42173
by SeByDocKy
Demo flight
Thanks again
Thanks again
Time to create page: 0.105 seconds
- WLtoys Q242G
