JXD 509 capture
29 Jan 2016 21:18 #42379 by SeByDocKy
JXD 509 capture was created by SeByDocKy
XN297 based, should be more or the same than the WLtoys Q282 but need to add the start/stop engine channel
mon-partage.fr/f/RWVsach6/
30 Jan 2016 04:34 #42394 by hexfet
Replied by hexfet on topic JXD 509 capture
Looks like it should bind with q282 already. Kind of a cross between q282 and q242...
30 Jan 2016 07:12 - 30 Jan 2016 07:12 #42397 by SeByDocKy
Replied by SeByDocKy on topic JXD 509 capture
hexfet wrote: Looks like it should bind with q282 already. Kind of a cross between q282 and q242...
Yes it bind the Q282 but need the "start/stop" channel :) to run motors :)
Last edit: 30 Jan 2016 07:12 by SeByDocKy.
31 Jan 2016 01:10 #42443 by hexfet
Will it bind with Q242? It looks like the video controls should be the same.
With either 242 or 282 you should be able to use channel 12 to start/stop the motors.
31 Jan 2016 07:21 #42455 by SeByDocKy
hexfet wrote: Will it bind with Q242? It looks like the video controls should be the same.
Yes you were right, the CH12 is working to start motor :) !!!
So one more model added ;) (easy job for you this time )
I also captured the fayee FY805 & Eachine H99 if you want :) :P
31 Jan 2016 12:24 #42456 by SeByDocKy
Small demo
31 Jan 2016 16:15 #42461 by hexfet
Nice video :) Thanks for keeping the spreadsheet updated.
Good thing it was easy as next couple of weeks are busy.
22 Mar 2016 06:42 #44968 by bacete2000
Replied by bacete2000 on topic JXD 509 capture
Por favor, alguien puede colgar el archivo, modelo. InI, para devo 7e? , no soy capaz de poner en marcha mi jxd 509g.
Gracias
22 Mar 2016 07:14 #44969 by bacete2000
Good morning, someone would be so kind as to put the model file. JXD ini 509g for devo 7e? I do not get to fly. one aludo and thanks
23 Mar 2016 12:06 #45046 by bacete2000
Es posible archivo .INI pasta empezar a entender la emisora? , soy novato en el tema
Time to create page: 0.047 seconds
