help understanding the 3in1 module functions
11 May 2016 16:45 #48208 by HappyHarry
at the minute we don't fully understand how the 3in1 module handles pa and lna switching for the a7105 and nrf24l01 (it possibly only works for the cc2500 at the minute), is there a way to use a logic analyser to check this function? I have a 3in1 here and my saleae clone analyser I will get back in a few days, so I can look into it if there is a way to do so, but i'd need pointers on information sources that will teach me what to do. so does anyone know if it's possible to do this? if so is there any reading material for the process?
11 May 2016 23:17 #48237 by victzh
It is much easier to ask the developer of the module :-) What exactly would you like to know? I can ask him.
12 May 2016 00:15 #48239 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic help understanding the 3in1 module functions
Hello gentlemen,just wanted to know the cons and adverse effects of installing this module into a devo 10.I got the devo 7e with the stock unmodded cyrf with the nfrl and a7105 installed, all birds with compatibility flys great with more than 300 meters of range with the exception of the
lack of power being taken away from the cyrf do to the diode.The latter reason being my reason to upgrade to the 10.Should I go with the 3in1 or just install the cc2500 stand alone in my devo 10?
12 May 2016 07:41 #48256 by HappyHarry
Replied by HappyHarry on topic help understanding the 3in1 module functions
victzh wrote: It is much easier to ask the developer of the module :-) What exactly would you like to know? I can ask him.
i'm not sure you'll get answers but i'd like to know how the pa/lna switching is handled, has the a7105 pa connection been fixed in the recent boards, also is pa/lna switching enabled for all 3 rf chips yet. there is very little info on these subjects and as some a7105 and nrf24l01 require lna to bind it's important to know
12 May 2016 08:03 #48258 by HappyHarry
C0ckpitvue 777 wrote: Hello gentlemen,just wanted to know the cons and adverse effects of installing this module into a devo 10.I got the devo 7e with the stock unmodded cyrf with the nfrl and a7105 installed, all birds with compatibility flys great with more than 300 meters of range with the exception of the
if you are going with a devo 10 use the 4in1 instead bud
13 May 2016 00:08 #48313 by mwm
Um,. the 10 comes with a full power CYRF module, so you shouldn't need to change it. Only the 7E needs the cyrf power changed.. For the 10, the 3-iin-1 would be the right module assuming all the kinds have been worked out.
Time to create page: 0.081 seconds
