Beken 2421 initialization
- van Zyl
26 May 2016 20:19 #49319
by van Zyl
Beken 2421 initialization was created by van Zyl
I am a noob at this, so please be kind.
I am trying to write the receiver side of the SymaX protocol. In my debugging I resorted to studying the Beken 2421 datasheets. I found what seems be a problem with the initialization of the RF module. (see links at bottom to datasheets)
Here is the code from symax_nrf24l01.c It shows (approximately) correct values for the first 5 registers, but the values for registers 0x0C - 0x0E are reversed.
Which are right?
NRF24L01_WriteRegisterMulti(0x00, (u8 *) "x40x4Bx01xE2", 4);
NRF24L01_WriteRegisterMulti(0x01, (u8 *) "xC0x4Bx00x00", 4);
NRF24L01_WriteRegisterMulti(0x02, (u8 *) "xD0xFCx8Cx02", 4);
NRF24L01_WriteRegisterMulti(0x03, (u8 *) "x99x00x39x21", 4);
NRF24L01_WriteRegisterMulti(0x04, (u8 *) "xF9x96x82x1B", 4);
NRF24L01_WriteRegisterMulti(0x05, (u8 *) "x24x06x7FxA6", 4);
NRF24L01_WriteRegisterMulti(0x0C, (u8 *) "x00x12x73x00", 4);
NRF24L01_WriteRegisterMulti(0x0D, (u8 *) "x46xB4x80x00", 4);
NRF24L01_WriteRegisterMulti(0x0E, (u8 *) "x41x10x04x82x20x08x08xF2x7DxEFxFF", 11);
Datasheet: halckemy.s3.amazonaws.com/uploads/docume...337/Beken-BK2421.pdf
Application notes in Chinese: www.google.com/url?sa=t&rct=j&q=&esrc=s&...m=bv.122852650,d.cWw
Which are right?
26 May 2016 22:07 #49328
Replied by hexfet on topic Beken 2421 initialization
The registers are set to the same values used by the stock transmitter according to the SPI captures in
this thread
. Whether the stock tx or the datasheet is right is not known.
If any are backwards it must not make a difference. I have a Beken chip in my Devo, and it works fine with my Syma X12.
Time to create page: 0.022 seconds
- Beken 2421 initialization
