Cheerson cx-30 with odd behaviour
29 Jul 2016 13:49 #52263 by jjk836
Replied by jjk836 on topic Cheerson cx-30 with odd behaviour
It's a 3 in 1 module. http://de.aliexpress.com/item/High-Quality-CC2500-NRF24L01-A7105-Multi-RF-3-IN-1-Wireless-Module-3-3V-Power-Supply/32658004521.html
On the cx-30 it behaves in the same way as the single nrf24l01 module I had installed before. On the other models it works fine. The module I had before was this one: http://www.ebay.de/itm/NRF24L01-2-4-GHz-Funkmodul-Wireless-Transceiver-Empfaenger-Arduino-Raspberry-Pi-/322197269841?
Both modules work well on my other models. I would never say never but chances are it's not the chip.
My ini file repository bitbucket.org/jjk836/devo10
31 Jul 2016 20:28 #52342 by jjk836
Do you think it could shed some light into the issue if I connect the analyzer to the devo10? (Have been so happy that I managed to close the case ;-)
11 Sep 2016 19:48 #53797 by jjk836
Hexfet,
you were right. The chip wasn't compatible. I now put in a module from banggood www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html which seems to be compatible with the cx-30 with the non-patched version of deviationtx.
The yizan i6s is still not binding. So that seems to be another problem.
Jan
13 Sep 2016 22:28 #53850 by goebish
Replied by goebish on topic Cheerson cx-30 with odd behaviour
jjk836 wrote: The yizan i6s is still not binding. So that seems to be another problem.
Ah ? can you test the (old) version from this post that's supposed to work and report please:
www.deviationtx.com/forum/protocol-devel...pture?start=60#42593
Time to create page: 0.057 seconds
