Eachine E010 inductrix clone data captures
- goebish
- NRF Weirdo
10 Sep 2016 08:53 #53715
by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
You've selected the WLH08 format instead of E010, no wonder it doesn't work
Try with the attached one ...
- Stecozz
10 Sep 2016 08:56 #53716
by Stecozz
Replied by Stecozz on topic Eachine E010 inductrix clone data captures
Thanks for your help goebish
- Stecozz
10 Sep 2016 09:06 #53717
by Stecozz
How do i select the E010 format?
just put loaded your file in the models and it still doesnt bind.
- goebish
- NRF Weirdo
10 Sep 2016 09:11 - 10 Sep 2016 09:12 #53718
by goebish
Highlight "MJXq" in Model setup menu, press enter then select E010 sub-format.
Start from a fresh model, I see some stuffs are missing in your .ini ...
Last edit: 10 Sep 2016 09:12 by goebish.
- Alias_Hendrik
10 Sep 2016 09:13 #53719
by Alias_Hendrik
Replied by Alias_Hendrik on topic Eachine E010 inductrix clone data captures
I fiddled some more but can't get headless to work properly. When i push left hor. trim button the led on the E010 start blinking indicating headless.
As long as the rear of the quad is facing to me it flies but as soon as i turn the E010 for 180 degree the problem starts. Meaning aileron stick to the right i need a lot of stick travel to get it flying in that direction.
But with barely any aileron stick to the left it's shooting left like a rocket and i need full right stick to stop it and i need to keep the stick almost full right to prevent it going further to the left. The same happens with forward and back movement when the quad is turned 180 degrees in headless mode.
I don't know what i'm doing wrong so i gave up. Perhaps someone can share an ini with a correct working headless mode thanks.
- goebish
- NRF Weirdo
10 Sep 2016 09:18 #53720
by goebish
@Alias_Hendrik I think I understand, I should disable dynamic trims while headless is enabled ... I'll fix that.
- Stecozz
10 Sep 2016 09:24 #53721
by Stecozz
my only options are WLH08,X600,X800,H26D?
goebish wrote: Highlight "MJXq" in Model setup menu, press enter then select E010 sub-format.
- goebish
- NRF Weirdo
10 Sep 2016 09:25 - 10 Sep 2016 09:25 #53722
by goebish
That means you haven't flashed the latest .dfu and copied the .mod files (you're running an older version of deviation).
Install the latest nightly.
Last edit: 10 Sep 2016 09:25 by goebish.
- Alias_Hendrik
10 Sep 2016 09:30 #53724
by Alias_Hendrik
Thanks! i had a slight feeling it had something to do with dyntrim added or substracted in a particular direction. So in that case my ini should be ok
I looked at the ini you posted, and for ch3 i noted scalar and scalar min = 150 should i add that to my ini? Thanks.
- goebish
- NRF Weirdo
10 Sep 2016 09:30 #53725
by goebish
@Alias_Hendrik, can you check if this build fixes the issue with headless mode please ?
Devo 7e
Devo 7e
- Stecozz
10 Sep 2016 09:38 #53727
by Stecozz
Sorry about this.
Do i delete all my files and replace the whole lot with the nightly?
What about the debug zip file?
goebish wrote: That means you haven't flashed the latest .dfu and copied the .mod files (you're running an older version of deviation).
Sorry about this.
- William
10 Sep 2016 09:59 #53728
by William
William
Replied by William on topic Eachine E010 inductrix clone data captures
Hello, je doit installer deviation-devo7e-256-v5.0.0-28fd02d.zipdeviation-devo7e-256-v5.0.0-28fd02d.zip or deviation-devo7e-v5.0.0-28fd02d.zipdeviation-devo7e-v5.0.0-28fd02d.zip ?
William
- Stecozz
10 Sep 2016 10:12 #53729
by Stecozz
Be good to have instruction on how to install "nightly builds"
For NooBs
For NooBs
- goebish
- NRF Weirdo
10 Sep 2016 10:15 - 10 Sep 2016 10:18 #53730
by goebish
Nightly builds (and test builds) have nothing special, just install it as you installed deviation on your transmitter initially, flash the .dfu then overwrite the .mod files in the protocol folder.
www.deviationtx.com/downloads-new/category/13-nightly-builds
The debug file is only intended to developers, you don't have to worry about it.
Last edit: 10 Sep 2016 10:18 by goebish.
- goebish
- NRF Weirdo
10 Sep 2016 10:20 #53731
by goebish
@William, if you've a devo 7e with stock MCU then you want the devo7e version, not devo7e-256.
- goebish
- NRF Weirdo
10 Sep 2016 10:21 #53732
by goebish
Hmmm, I feel like a support / help thread should be opened for this (already popular) model and keep this thread for development purposes
- Alias_Hendrik
10 Sep 2016 10:28 #53733
by Alias_Hendrik
Installed the build but the E010 refuses to bind. I checked for the correct version on my 7E and it's installed.
goebish wrote: @Alias_Hendrik, can you check if this build fixes the issue with headless mode please ?
Devo 7e
- William
10 Sep 2016 10:38 #53734
by William
William
oups! the MCU ? j'ai ça nRF24L01 CC2500 a7105 plusieurs rf 3 en 1 module sans fil pour l'émetteur de devo instalé sur ma devo 7e, c'est le MCU?
William
- goebish
- NRF Weirdo
10 Sep 2016 10:40 - 10 Sep 2016 10:46 #53735
by goebish
I noticed that it wouldn't completely bind with some txid (the protocol is not fully cracked, I'm waiting for more captures ...), try with a different fixed transmitter ID.
Disconnect / reconnect battery on the quad between tries because it get stuck when trying to bind with a non working ID.
Devo 7e
Last edit: 10 Sep 2016 10:46 by goebish.
- goebish
- NRF Weirdo
10 Sep 2016 10:43 #53736
by goebish
No, the MCU is the processor of your transmitter (STM32), if it's unmodified then you need the devo7e version, not 256.
Please try to use english on this forum
William wrote: oups! the MCU ? j'ai ça nRF24L01 CC2500 a7105 plusieurs rf 3 en 1 module sans fil pour l'émetteur de devo instalé sur ma devo 7e, c'est le MCU?
Time to create page: 0.613 seconds
- Eachine E010 inductrix clone data captures
