Eachine E010 inductrix clone data captures
10 Sep 2016 10:53 #53737 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
I think I fixed the transmitter ID issue, let me test a bit more then I'll push a new update ;)
10 Sep 2016 10:58 - 10 Sep 2016 11:01 #53738 by Alias_Hendrik
Replied by Alias_Hendrik on topic Eachine E010 inductrix clone data captures
goebish wrote:
Alias_Hendrik wrote:
goebish wrote: @Alias_Hendrik, can you check if this build fixes the issue with headless mode please ?
Devo 7e
Installed the build but the E010 refuses to bind. I checked for the correct version on my 7E and it's installed.
I noticed that it wouldn't completely bind with some txid (the protocol is not fully cracked, I'm waiting for more captures ...), try with a different fixed transmitter ID.
Disconnect / reconnect battery on the quad between tries because it get stuck when trying to bind with a non working ID.
I put some random nr's in and it's ok now ;) Headless mode is working correct in this build thanks! The return to home still doesn't respond always. Meaning when i push rth it sometimes does nothing and sometimes i can see it starts the rth but it stops after a second. Pushing the button 4 a 5 times real quick, it reacts on one of these pushes and it's coming back like it should. In the channel monitor the LH push button for CH10 works each time going from -100 to 100.
Last edit: 10 Sep 2016 11:01 by Alias_Hendrik.
10 Sep 2016 11:03 - 10 Sep 2016 12:08 #53739 by goebish
Cool, I'll still push my txid patch tho ;)
Regarding problem with RTH I suppose it exits this mode because sticks are not perfectly centered, try to recalibrate your sticks and add a small deadband around rudder, aileron and elevator neutral.
Last edit: 10 Sep 2016 12:08 by goebish.
10 Sep 2016 11:04 #53740 by William
Replied by William on topic Eachine E010 inductrix clone data captures
Ok, I try in english but my english is very bad, yes my 7e is original, Thank you for your patience whit me, I really a Noob :lol: now i think i have anderstand.
William
10 Sep 2016 11:05 #53741 by goebish
No problem, your english is good enough ;)
10 Sep 2016 11:14 #53742 by goebish
I updated the test builds with headless and transmitter ID fix
www.dropbox.com/sh/myda7gwpwfhkbw4/AABZS...QEt7BWI1BWDh7Ja?dl=0
10 Sep 2016 16:43 #53749 by Stecozz
Replied by Stecozz on topic Eachine E010 inductrix clone data captures
Still trying haha
Ive wiped the whole drive and replaced it with latest nightly build into my 7e and its now saying "protocol mismatch 0801fc6c and 0801ef18"
what am i doing wrong?
10 Sep 2016 16:47 #53750 by goebish
You've to flash the .dfu and copy the .mod files to the protocol folder.
Your error probably means the dfu doesn't match the .mod files.
10 Sep 2016 16:52 #53751 by Stecozz
goebish wrote: You've to flash the .dfu and copy the .mod files to the protocol folder.
Just wish i was clever enough to know how to do that?
All i did was replace the whole lot for the new build :unsure:
10 Sep 2016 16:55 - 10 Sep 2016 16:57 #53752 by goebish
Just do the same thing than when you first installed deviation (just don't overwrite your setting & model files), nothing more, nothing less.
I suppose that you've only copied the files to the filesystem, but not flashed the .dfu
If you're looking for help for that you're not in the right sub-forum ;)
Last edit: 10 Sep 2016 16:57 by goebish.
10 Sep 2016 17:15 #53753 by Stecozz
Sorry.
Would love a video of how to do this and and how to update models etc after youve already installed deviation.
i give up for now lol..
10 Sep 2016 17:19 #53754 by goebish
Read section 2 of the manual:
www.deviationtx.com/user-manual/user-manual-7e-10
and watch this video
But that's the same thing than installing deviation for the first time ...
10 Sep 2016 17:22 #53755 by William
yes!!! It's ok my devo7e is ok, I can find the E010 in bind protocol , now i waiting to the tiny for test (back order to BG). Thank very much.
William
10 Sep 2016 19:42 #53761 by Stecozz
done the dfu and now can enable E010.
Still wont bind though :(
10 Sep 2016 19:43 #53762 by goebish
Try with a few different transmitter ID.
Disconnect / reconnect the battery on the quad between each try.
10 Sep 2016 19:56 #53764 by Stecozz
goebish wrote: Try with a few different transmitter ID.
Nothing I'm afraid
10 Sep 2016 20:02 #53767 by goebish
Try this version which has an hardcoded id:
www.dropbox.com/s/o3zf621r3m8r01n/deviat...0-b289612#2.zip?dl=1
10 Sep 2016 20:34 #53768 by Alias_Hendrik
goebish wrote: I updated the test builds with headless and transmitter ID fix
I installed the above version, headless is ok too and can bind with a fixed id and also when fixed id is "none".
10 Sep 2016 20:38 #53769 by robocog
Replied by robocog on topic Eachine E010 inductrix clone data captures
Thanks for sorting this guys :D
My e010 arrived today, I had already flashed and copied the files in prep on my 7E so was immediately able to fly it around the house :)
I still am unable to get flip, headless or RTH to work
(I did test flip mode on the TX it shipped with, just to make sure it would and would possibly be the only feature I would want to use with it)
I have 2x extra 3 way switches
I did try and setup the fmode switch to output -100 / 100 on ch6 but flipping it or toggling it has not induced a flip yet
I am using deviation-devo7e-v5.0.0-52c55d7 which I believe is the most recent
I did spot an ini further up the thread and tried it out, but for some odd reason the yaw/rudder didn't work on the quad and when I looked into the ch outputs screen the rudder stick seemed to be acting like a switch
Again... you guys rock !
Regards
Rob
10 Sep 2016 20:45 #53770 by goebish
I just checked on my Devo 10 (same firmware version 52c55d7), flips are working fine, are you sure your switch outputs -100 / 100 on channel 6 ? Can you see it in channel monitor ?
Time to create page: 0.613 seconds
