Eachine E010 inductrix clone data captures
29 Sep 2016 00:20 #54385 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
No that's fine, your txid / channels have been added to the list :)
01 Oct 2016 15:50 - 01 Oct 2016 15:52 #54470 by epilot
Replied by epilot on topic Eachine E010 inductrix clone data captures
As long as I set the power to 1mW I can bind my Devo 10 without issues. I've been flying for a while but realised that with bog standard settings I am flying on low rates. Any suggestions how to increase those and assign to a switch? Someone posted a file, probably on RC Groups but can't find it again, that had all functions programmed. However I get a weird behaviour when I use that file. It will bind and I can fly around but then all of a sudden the motors will start to rev seemingly at random. With the basic model file that does not happen.
Last edit: 01 Oct 2016 15:52 by epilot.
03 Oct 2016 09:46 #54544 by sonnofa
Replied by sonnofa on topic Eachine E010 inductrix clone data captures
Anyone care to help a noob out, trying to get my e010 bound to my 8s and it does bind however the screen is almost completely black therfore I can't see my inputs and such.
04 Oct 2016 14:22 #54587 by William
Replied by William on topic Eachine E010 inductrix clone data captures
Hello goebish, i have my E010 since yesterday, and it's ok for blind to my Devo 7e, the fly it's very good in 30mw but to 100 or 150 mw the tiny have a bad réaction, i say that juste for info because for me it's very nice and 30mw :) .Again great take you for your job.
William
04 Oct 2016 14:26 - 04 Oct 2016 14:37 #54588 by goebish
Yes, this has already been reported, just set it to 10 or 30mW (both are ~80mW actually when using nrf24l01+PA...), that's more than enough for this kind of aircraft ;)
.. but that probably means the voltage regulator in your 7e can't provide enough current for this protocol, this sub-format draws more juice than the other MJXq formats as it runs @ 250kbps vs 1Mbps, thus requiring 4x more time (and current) to transmit a packet.
Last edit: 04 Oct 2016 14:37 by goebish.
06 Oct 2016 19:30 #54680 by plaisthos
Replied by plaisthos on topic Eachine E010 inductrix clone data captures
I also captured mine:
gist.github.com/schwabe/9e8563f1abecbee4660763e798e4ee78
Maybe mine has a useful TX ID for decoding. :)
06 Oct 2016 19:43 #54681 by goebish
Hmmm looks like this is a cx10 capture, not E010 ;)
06 Oct 2016 19:59 #54682 by plaisthos
06 Oct 2016 20:00 #54683 by goebish
Oh sorry, I was lazy and only downloaded / opened / decoded the first one ;)
06 Oct 2016 20:05 #54684 by goebish
Thanks, it's been added to the list .
07 Oct 2016 01:49 #54688 by ugari
Replied by ugari on topic Eachine E010 inductrix clone data captures
ShouId I use nightly build to bind E010 I'm using deviation 5.0.0 ???
09 Oct 2016 09:47 #54744 by goebish
Yes, nightly build, select MJXq protocol and E010 format option.
13 Oct 2016 03:26 #54868 by mr_tucsons
Replied by mr_tucsons on topic Eachine E010 inductrix clone data captures
i had already installed the NRF24L01 module into my devo 8. i also enable it at harware.ini file. i download the the lastest nightly build n e010 file. still i cant find at my transmitter e010 format under mqjx protocol. what seem the problem here?? help
07 Nov 2016 12:13 #55771 by Voggl93
Replied by Voggl93 on topic Eachine E010 inductrix clone data captures
Hi everyone,
I don't know what I am doing wrong but I just can't get my E010 to bind with my Devo7e.
I have installed an NRF24L01 module and it works with an Eachine H8S.
I do have the latest nightly build installed and I chose the E010 in the model menu.
I have also tried serveral other Transmitter IDs and some older nightly build versions.
I really hope you can help me because the provided "Transmitter" ´just sucks :cheer: :silly:
Greetings
07 Nov 2016 20:30 #55779 by ketsa
Replied by ketsa on topic Eachine E010 inductrix clone data captures
Captured a bind with my TX.
First time I used a logic analyzer... tell me if something's wrong.
I captured with sigrok/pulseview, was unable to connect saleae Logic to my analyzer.
raw file : mega.nz/#!bpdWjABQ!kummASmxbweEplsSBtdlpSVaaRUbw_oTBAS5dvS-Euk
sigrok file : mega.nz/#!jtlSkQJY!iR0mLEv84bNrexxksFGffiQft--WJ6e1H4hdNMAMyTg
Hope it helps.
07 Nov 2016 23:03 #55784 by hexfet
Replied by hexfet on topic Eachine E010 inductrix clone data captures
E010
txid: ee b3
channels: 39 3e 49 4e
09 Nov 2016 18:30 #55821 by victzh
Replied by victzh on topic Eachine E010 inductrix clone data captures
Hey, goebish, is it easy to solder to the quad itself?
09 Nov 2016 18:30 #55822 by goebish
That's not possible, MCU+RF are in the same chip :(
09 Nov 2016 19:43 #55824 by victzh
Sad. One of the tricks I applied is to program arbitrary id and watch what channel the receiver starts listen to. You can recover the hopping sequence relatively easy.
09 Dec 2016 15:58 #56709 by SodaAnt
Replied by SodaAnt on topic Eachine E010 inductrix clone data captures
I'm having a similar issue on my 10e. The quad will bind at 1mW, but will cut out control every few seconds, so it can get kind of dangerous to fly. Not quite sure what can be done to increase the current to the module.
Time to create page: 0.999 seconds
