Eachine E010 inductrix clone data captures
- goebish
- NRF Weirdo
01 Jan 2017 17:11 - 01 Jan 2017 17:12 #57428
by goebish
No, that's not possible with the nrf24l01.
Replied by goebish on topic Eachine E010 inductrix clone data captures
Fernandez wrote: Would it be possible to add a frequency offset shift into the protocol option? Like the Deviation Frsky protocol has option for that, as some cc2500 were off and unusable.
By trial and error the offset to be estimated? Put Tx at low power, Change to min bind, change to max bind, enter value in the middle?
Last edit: 01 Jan 2017 17:12 by goebish.
- goebish
- NRF Weirdo
01 Jan 2017 18:07 #57432
by goebish
... unfortunately
- TinuZ
14 Jan 2017 09:48 #57931
by TinuZ
Replied by TinuZ on topic Eachine E010 inductrix clone data captures
Well,
Seems my reply from two weeks ago did not get through so here is the comparison/results of Taranis based flights:
I have been flying the E010 exclusively with my other devo7e (discrete modules) and my Taranis (multimodule) without any issues.
The 4-in-1 RF stage on the multimodule for module bay TX's and on the Devo daughterboard are the same, so that is why it strikes me as odd to see it only on Devo happening.
I didn't want to do the soldering job suggested in the other thread @goebish linked to (interesting, thanks!) so I contacted BG support and they were so kind to dispatch a new (supposedly 'fixed') version. It did not arrive yet, so no result on that.
Once I have that one I will try the fix suggested in the other thread, just to make sure that it was indeed the problem they encountered and fixed.
Thanks a lot so far!
- povlhp
27 Jan 2017 15:55 #58434
by povlhp
Replied by povlhp on topic Eachine E010 inductrix clone data captures
Playing a bit more with my E010 today. Firmware on the Devo 10 w/ 4in1 probably 2 months old. 5.0.0-cca3757
It will bind fine, BUT the LEDs keep blinking, like low battery. Turn off and try with stock Tx and all OK.
It is set for fixed id 123456, 12 channels. Anything to change ? Using a downloaded profile
- goebish
- NRF Weirdo
27 Jan 2017 15:58 #58435
by goebish
I suppose it's blinking because it misses a lot of packets. Try with a different fixed ID so it uses different frequencies, also try with lowered output power.
Possible fix if everything fails: www.deviationtx.com/forum/protocol-devel...ures?start=220#57424
- povlhp
27 Jan 2017 21:03 #58449
by povlhp
Any way I can calidate my antenna connection on the Devo 10 ?
Or an idea about other ID ? Is it always 6 digits ?
Well, just bound to a FlySky iA6B. 100uW. Walked to another room, so shortest path is 10cm steel inforced concrete, and other way is bouncing off multiple walls. Keeps the bind. When I turn off TX the Rx starts blinking. So my high-gain antenna seems to work.
So what you are saying is, that it likely is a clone chip on my 4in1 module ? Am I better off with the old 3in1 ? (I have one, never mounted)
I tried everything from 100uW to 100mW.
Is there anything I can do to help troubleshoot ? I don't have much equipment for this, only clone logic analyzer (used to help hack Flysky proto for sensors, and for my iBus2PPM to get better understanding), and my SDR is the standard RTLSDR, so not going to 2.4GHz. Not sure if 1.2GHz spectrum.
I have a clone H8 - Locally given away as Q8, I have an UDI 818A as well, any way to see/guess what protocol it is using ? To see if I can test the NRF24L01 on any of these.
I am not so much of a hardware guy.
- goebish
- NRF Weirdo
27 Jan 2017 21:09 #58450
by goebish
Just try a few arbitrary IDs, length doesn't matter.
The problem is not related to the clone chip, but to an inaccurate crystal for the nrf24l01, replacing its loading capacitors seems to fix the issue. However, I'm not sure this is YOUR issue.
For the Q8 and 818A, just try with every nrf24l01 protocols and format options. If nothing works then post some dumps of the stock transmitters.
- povlhp
01 Feb 2017 11:16 #58608
by povlhp
Did not come further. Just got an idea. If I have swapped 2 radios, either by wire or in hardware.cfg, would the wrong radio then work good enough to cause this behaviour ? Or are the radios so different that it would just completely not work ?
And another thought, frequency shifting a bit is not possible, as you reported. But as I can see the channel table seems to allow selecting a channel with a 1MHz resolution. So it should be possible to shift all channels 1MHz up or down ? I did not look at the source code, so I am not sure. Not too much into this low level stuff.
But to me it seems possible to add/subtract one to RF_CH, unless that value is just a seed to some frequency hopping ?
Take this line 258 in mjxq_nrf24l01.c
NRF24L01_WriteReg(NRF24L01_05_RF_CH, rf_channels[rf_chan++ / 2]);
Shouldn't it be possible to add/subtract one to the value here ?
Then possible create 2 more targets - E010Above / E010Below.
Is it worth for me to try - Just with +1 / -1 ? Since there is a docker build container, it should be easy to try just hard-modding my own firmware.
- ajtank
01 Feb 2017 14:30 #58614
by ajtank
The LEDs will blink if you enter headless mode. You can also try calibrating the gyroscope: both sticks bottom left.
Replied by ajtank on topic Eachine E010 inductrix clone data captures
povlhp wrote: Playing a bit more with my E010 today. Firmware on the Devo 10 w/ 4in1 probably 2 months old. 5.0.0-cca3757
- povlhp
01 Feb 2017 20:42 #58625
by povlhp
Even with LEDs blinking, calibrating gyroscope works.
Did another test today, and now it seems to work. Did not fly, only bind test.
Started at 30mW, all OK. At 100mW I get the blinking again. 30mW and 10mW will make the blinking stop.
Since headless mode is one of the switches, there is a chance that I never had any issues, just the wrong FMODE, as I used a downloaded model where FMODE is used for headless/RTH. Something I would never use anyway
- ajtank
02 Feb 2017 02:00 - 02 Feb 2017 04:36 #58636
by ajtank
Some hobbyists also reported that their quad did not work at high transmit power. The root cause is not yet known. I however cannot reproduce this issue with several 4-in-1 modules.
Did you connect the radio module with long wires? Although it may not help but you can try shortening the wires or re-routing them further away from the antenna, etc.
Last edit: 02 Feb 2017 04:36 by ajtank.
- povlhp
02 Feb 2017 07:30 #58645
by povlhp
As I told earlier, now it works. Likely it was the FMOD switch in headless mode.
Will see if I can get the time to try again during lunch break.
Could the 100mW issue be caused by the fake chip?
- ajtank
02 Feb 2017 08:17 #58646
by ajtank
I cannot reproduce the 100mW issue regardless of the chip, clone or genuine.
- goebish
- NRF Weirdo
02 Feb 2017 11:32 #58651
by goebish
I'm almost sure that replacing the 2 capacitors that are located around the nrf24l01 oscillator would fix the issue.
There's nothing we can do in software.
- povlhp
02 Feb 2017 11:50 #58652
by povlhp
It was likely the FMOD switch that caused the blinking. Flew 3 batteries around office space with plaster walls without any issues. Switching FMOD I could get the blinking again, and erratic flight behaviour (aka headless mode). Maybe this is what others are seeing as well. A high value on channel 6 (?) causing headless mode = blinking.
Still, moving 1MHz up/down would be doable. But it might be too big a step. But still only 0.05% - But I don't seem to have that problem, sp I will not do more on that.
- dodosaurus
02 Feb 2017 21:35 - 02 Feb 2017 21:55 #58670
by dodosaurus
Replied by dodosaurus on topic Eachine E010 inductrix clone data captures
Hellо.
What version of deviation must i use to bind my Devo 7e (nrf chip only) to Eachine E010? I've tried the 5.0.0 and no luck. None of the nightly builds seems to do the trick.
Edit: Oops my bad. Had forgotten to turn of nrf chip on in confiig.ini. Will try it tomorrow.
Last edit: 02 Feb 2017 21:55 by dodosaurus.
- goebish
- NRF Weirdo
02 Feb 2017 21:36 #58671
by goebish
Use a nightly build, select MJXq protocol with E010 format option.
- Yiming.exe
03 Feb 2017 08:04 #58691
by Yiming.exe
Replied by Yiming.exe on topic Eachine E010 inductrix clone data captures
Well I have read through and tried everything(i think). Different ID, all the protocols, different ini, different craft types, different channels but I still cannot bind. Devo 7E, 30/1 nightly, Nrf no pa from online. Works with syma clone and eachine h8. I have not been able to bind to xn297 chips before either.
- goebish
- NRF Weirdo
03 Feb 2017 12:01 - 03 Feb 2017 12:35 #58696
by goebish
Well, I'm a bit fed up of always repeating the same thing:
- first make sure you've selected the proper protocol (MJXq) and format option (E010)
- 250kbps xn297L protocols such as E010 require an accurate crystal oscillator circuit, I suppose you're using a cheap $1 nrf24 board (no PA), try with this one instead:
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
Last edit: 03 Feb 2017 12:35 by goebish.
- Yiming.exe
06 Feb 2017 07:31 - 06 Feb 2017 07:35 #58803
by Yiming.exe
I have tried the e010 format and all other protocols. If I find the pinout will this one work?
www.banggood.com/Multiprotocol-TX-Module...8.html?utm_design=19
I was just trying to confirm that it would be the module rather than some setting. Sorry if I missed a previous post that says what would cause a problem.
Last edit: 06 Feb 2017 07:35 by Yiming.exe.
Time to create page: 0.157 seconds
- Eachine E010 inductrix clone data captures
