JXD 506 (Potentially JJRC H28WH)
04 Oct 2016 04:49 - 14 Oct 2016 01:30 #54568 by ajtank
JXD 506 (Potentially JJRC H28WH) was created by ajtank
JXD 506 is a gigantic variant of JXD 510. It features altitude hold as well as camera up/down via the transmitter (throttle trim buttons). I am able to bind it using V202 protocol. Light (ch5), Photo (ch7) and Video (ch8) are found to work. I am unable to take off after attempting some WLtoys' common operations on the sticks.
The stock transmitter uses a start/stop button to start the motors. I can then apply throttle to take off and centre throttle to maintain height. Pressing start/stop button again will make the quad to descend but motors will not stop completely. Pressing another emergency button will shut down the motors fastly and quad can finally land.
I have made 2 captures here . Capture starts after binding is completed.
1) press throttle trim+ to make camera move up and trim- to make camera move down
2) start button, throttle up, throttle centre, start button again, emergency stop button
Appreciate any help on this quad, thank you.
Last edit: 14 Oct 2016 01:30 by ajtank. Reason: typo
04 Oct 2016 06:51 - 04 Oct 2016 06:53 #54571 by ajtank
Replied by ajtank on topic JXD 506
I also got another quad JJRC H28WH which has similar features as the JRX 506. After some quick testing, It seems that both models use the same protocol and the stock transmitters can be swapped. There are only some minor differences in the button mappings.
Results for H28WH: ch5, 7, 8 are working using Devo 10. Needs specific buttons on stock transmitter to start and stop the motors which is same as JXD 506.
Last edit: 04 Oct 2016 06:53 by ajtank. Reason: typo
04 Oct 2016 07:39 #54574 by ajtank
Replied by ajtank on topic JXD 506 (Potentially JJRC H28WH)
Out of curiosity I tested another quad i8H by YiZhan. All 3 stock transmitters seem to be exchangeable, i8H does not feature camera movement and the throttle trims are real though. i8H uses both-sticks-down-and-outward as emergency stop and this also works on both the JXD and JJRC.
12 Oct 2016 18:03 #54859 by goebish
Replied by goebish on topic JXD 506 (Potentially JJRC H28WH)
I'll take a look at that, shouldn't be hard ...
Also, for what you've asked me in PM, you can now buy me a beer:
www.patreon.com/goebish
No promise are made though ;)
12 Oct 2016 21:57 - 12 Oct 2016 22:10 #54861 by goebish
Try this test build for Devo 10:
www.dropbox.com/s/winiiisla5vbs1x/deviat...0.0-9e1e225.zip?dl=0
It has a JXD-506 format option for V202 protocol.
Channel 10: arm / disarm (has to be toggled)
Channel 11: emergency stop (maybe it should be modified to just work as with stock TX ? let me know ...)
Channel 12: gimbal control, low = down, center = neutral, high = up
Please report :)
Last edit: 12 Oct 2016 22:10 by goebish.
13 Oct 2016 16:17 #54891 by ajtank
goebish wrote: Try this test build for Devo 10:
Please report :)
Unfortunately I still cannot arm the quad.
What is the expected toggled values for channel 10? 100/0 or 100/-100?
What is the expected idle value and enabled value for channel 11? 0 and 100 respectively?
13 Oct 2016 16:23 - 13 Oct 2016 16:27 #54892 by goebish
Ok, I notice another difference in the format of the packet (no wonder it doesn't work as it is as the "arm" bit is misplaced), I'll post another test build later, going to the pub now ;)
expected toggle is -100/100/-100
Last edit: 13 Oct 2016 16:27 by goebish.
14 Oct 2016 01:09 #54902 by ajtank
Good to know I did not made a wrong test. I actually have tried different toggle values before asking. I am a newbie in RC and just started using deviation 2 weeks ago. This is also my first time using a radio with mixer functions. A lot of trials and a lot of fun too.
15 Oct 2016 11:46 #54966 by ajtank
goebish wrote: Ok, I notice another difference in the format of the packet (no wonder it doesn't work as it is as the "arm" bit is misplaced), I'll post another test build later, going to the pub now ;)
I also tested ch12 and the camera did not move at -100, 0 and 100.
ch11 could not be tested since I couldn't arm the quad, thanks.
15 Oct 2016 11:48 #54967 by goebish
That's normal, the gimbal flag is misplaced as well, I'm currently working on a fix, test build coming soon ;)
15 Oct 2016 11:57 #54968 by goebish
Test build for Devo 10 updated:
www.dropbox.com/s/w3bb9ic1rrbn84g/deviat...0.0-9e1e225.zip?dl=0
Please try again :)
16 Oct 2016 01:38 - 16 Oct 2016 04:07 #54995 by ajtank
goebish wrote: Test build for Devo 10 updated:
Please try again :)
Good news. The new build works for ch10 to ch12. It works for JXD-506 as well as JJRC H28WH and Yizhan i8h (no camera gimbal).
The stock transmitters have the throttle stick always centred, I have to centre the Devo 10 throttle before arming the quad otherwise disarm will happen almost immediately. This is a bit tricky. The older V202 models, e.g. Yizhan Tarantula x6 or WLToys Q212, allows a few seconds for you to centre the throttle after arming. For the above new models, you need to centre the throttle before arming.
The response of the camera gimbal is a bit sluggish. There is a delay before it starts moving. However this is the same for the stock transmitters.
Thanks again Goebish and have a great weekend.
Last edit: 16 Oct 2016 04:07 by ajtank. Reason: Supplementary information
16 Oct 2016 10:35 - 16 Oct 2016 12:57 #55000 by goebish
Cool, I'll make a pull request then so it's in the nightly soon :)
I'll also add the channel mapping for this sub-format in the documentation and state that throttle stick needs to be centered to arm.
Last edit: 16 Oct 2016 12:57 by goebish.
24 Oct 2016 13:33 - 24 Oct 2016 13:34 #55328 by ajtank
Whilst the last test build works on all the models, the RTH has been taken out due to limited channels.
Is it possible to create another subformat, say, H28WH, to put back RTH by swapping out the Emergency Stop?
Another suggestion is to modify existing JXD506 subformat since the Emergency Stop can also be activated by both sticks down and upward.
I let you choose to keep only 1 subformat or create a new one, thank you.
Last edit: 24 Oct 2016 13:34 by ajtank.
24 Oct 2016 13:38 #55329 by goebish
I think I'll make it work as on stock transmitter, emergency = both sticks bottom and outward (I've to remember to state how it works in the user manual and wiki).
That will free up one channel for RTH.
24 Oct 2016 13:44 - 24 Oct 2016 13:45 #55330 by goebish
Well, not sure that's a good idea to make it work as on stock transmitter as it won't work if you setup lower rates in Deviation.
Does the JXD-506 have a RTH feature or not ?
Last edit: 24 Oct 2016 13:45 by goebish.
24 Oct 2016 14:02 #55331 by ajtank
Yes JXD-506 also has RTH feature.
24 Oct 2016 14:03 #55332 by goebish
Ok, so that's better to make it work as on stock transmitter, I'll check what I can do.
24 Oct 2016 14:46 #55338 by goebish
I realize that I need a capture with the RTH flag.
24 Oct 2016 15:14 #55339 by ajtank
Uploaded. One is at low rate and another one in full rate.
Time to create page: 0.405 seconds
