CX 10D Traces
- goebish
- NRF Weirdo
19 Dec 2016 13:31 - 19 Dec 2016 14:03 #56984
by goebish
Replied by goebish on topic CX 10D Traces
... for the CX10WD, looks like the ID / RF algo is exactly the same than for the WLToys Q303, but with the same payload size & format than the CX10D.
Does it have altitude hold and take-off/landing buttons as well ?
Last edit: 19 Dec 2016 14:03 by goebish.
- ajtank
20 Dec 2016 01:22 #57025
by ajtank
Replied by ajtank on topic CX 10D Traces
Yes CX10WD has altitude hold (cannot be disabled) as well as take off and descend buttons. It supports fpv and also can be controlled by wifi.
- goebish
- NRF Weirdo
08 Jan 2017 01:18 #57668
by goebish
Good news:
www.deviationtx.com/forum/protocol-devel...-cx35?start=60#57666
So the CX10D is next on the list, id / rf mapping is already cracked, only have to implement the different packet format (easy...).
- goebish
- NRF Weirdo
15 Jan 2017 13:57 #57974
by goebish
I started working on the D, expect a test build soon
- goebish
- NRF Weirdo
15 Jan 2017 18:31 - 15 Jan 2017 19:03 #57992
by goebish
First test builds for CX10D, select Q303 protocol with CX10D format option:
www.dropbox.com/sh/zmbdc0t3q0u30on/AADEb...aMLWyCwhgj1egWa?dl=0
sources
Some channels might be reversed and/or swapped, please report.
I haven't figured out how take off / land buttons are working, I'll need more dumps for that, first check if the test build binds and works, though I'm not sure you can stop the motors without a land channel.
Also, as for the "original" CX10 protocol, it might be better to implement rates on a channel instead of using highest rate permanently... To my understanding the 3rd rate (as in the test build) is a "special" mode and might not be very fun to fly ? Correct me if I'm wrong.
sources
Last edit: 15 Jan 2017 19:03 by goebish.
- goebish
- NRF Weirdo
16 Jan 2017 00:13 - 16 Jan 2017 00:23 #58010
by goebish
I just added a CX10WD format option as well, ajtank, if you want to test ... same as for the CX10D, I need more dumps for take off / land / flip / video / snapshot buttons.
Last edit: 16 Jan 2017 00:23 by goebish.
- Stefan_Z
16 Jan 2017 00:26 #58012
by Stefan_Z
Replied by Stefan_Z on topic CX 10D Traces
Thanks for figuring it out so far!
I will try to make time for some more captures and also the new build install.
- goebish
- NRF Weirdo
16 Jan 2017 00:29 #58014
by goebish
I need 2 captures, the quad doesn't need to be powered on.
- switch tx on, bind, press take off button 5 times
- switch tx on, bind, press land button 5 times
- ajtank
16 Jan 2017 16:07 - 16 Jan 2017 16:07 #58040
by ajtank
I have uploaded the captures of the CX-10WD
here.
Rate button 5 times, change of rate = 1(power up) =>2=>3=>1=>2=>3
There is no button for video or photo, these features are controlled by WiFi.
There is no headless mode or RTH. The 2 sticks are always centred.
Last edit: 16 Jan 2017 16:07 by ajtank.
- goebish
- NRF Weirdo
16 Jan 2017 16:08 #58042
by goebish
Thanks !
Have you checked the test build, does it bind ?
- ajtank
16 Jan 2017 16:15 #58043
by ajtank
Oh yes the CX-10WD can bind.
- goebish
- NRF Weirdo
- ajtank
16 Jan 2017 16:30 #58045
by ajtank
Just like CX-35, I tested different ID's and all could bind without problem.
- goebish
- NRF Weirdo
16 Jan 2017 16:39 - 16 Jan 2017 16:42 #58047
by goebish
This one is using the same Tx ID / RF channel mapping than the Q303 Tx actually, but it's using a different bitrate and almost the same packet format than CX10D.
Last edit: 16 Jan 2017 16:42 by goebish.
- goebish
- NRF Weirdo
16 Jan 2017 17:14 #58048
by goebish
Updated the test build, channels for CX10WD:
Channel 5: land / take off
Channel 6: flip
Channel 6: flip
- hine
17 Jan 2017 12:30 #58077
by hine
Replied by hine on topic CX 10D Traces
Hi, goebish.
I tested your test build on my DEVO7E today.
My DEVO7E can bind CX-10WD!
But I CX-10WD cannnot take off.
My Channel Mixer Setting is:
5-HOLD: Simple
Src: HOLD1
Curve: Min/Max(or Zero/Max)
Ch6: Simple
Src: FMODE1
When HOLD switch turn to 1, Some propellers move just a little only once.
Is my Channel Mixer setting wrong?
5-HOLD: Simple
Src: HOLD1
Ch6: Simple
Src: FMODE1
- goebish
- NRF Weirdo
17 Jan 2017 13:09 - 17 Jan 2017 14:18 #58078
by goebish
That's only a test build, I'm not sure it works
Your setup seems Ok.
ajtank, can you confirm this behavior ?
The previous dumps were not clear because the Tx was already switched on when you started the captures, so some flags were already set ...
If the previous test build doesn't work please capture again, but switch the Tx off between each capture.
- tx on, bind, take off button (only once), continue to capture for a few seconds
- tx on, bind, take off button 5 times, wait ~1 second between each press
- tx on, bind, take off button (only once), wait a few seconds then land button (only once)
- tx on, bind, take off button (only once), wait a few seconds then land button 5 times, wait ~1 second between each press
- tx on, bind, land button 5 times, wait ~1 second between each press
Last edit: 17 Jan 2017 14:18 by goebish.
- ajtank
17 Jan 2017 14:25 #58079
by ajtank
Sorry I shall redo the captures a few hours later.
The test build behaves strangely. I can take off only via a special procedure:
a) turn transmitter on and go to reinit menu
b) turn quad on
c) hit reinit to bind
d) set throttle to 100% then activate take off button
By the way the rudder and elevator are reversed. The land button did not seem to work. I lost a propeller and before I find it I cannot fly
b) turn quad on
- goebish
- NRF Weirdo
17 Jan 2017 14:27 #58080
by goebish
Ok, I should be able to fix that once I've the extra captures.
- hine
17 Jan 2017 15:15 #58081
by hine
Yaeh!
i can take off via ajtank's procedure.
And, the settings for rudder and elevator are reversed too.
The Land button does not work. Turning the HOLD switch 0 to 1 and 1 to 0 are both 'Take off Button'.
Time to create page: 0.209 seconds
- CX 10D Traces
