CX 10D Traces
18 Jan 2017 20:36 #58136 by Gurzo
Replied by Gurzo on topic CX 10D Traces
Fantastic! I have 2 x cx 10wd and a cx 10d. Works all perfect! Thanks!
18 Jan 2017 21:05 #58142 by goebish
Replied by goebish on topic CX 10D Traces
Ah cool, you're the first person to test the CX10D :)
Can you try auto flip (channel 6) on both please ?
19 Jan 2017 13:16 - 19 Jan 2017 13:18 #58179 by ajtank
Replied by ajtank on topic CX 10D Traces
Goebish I found my problem. The flip actually works. I have forgotten that I have set 3 rates for elevator and aileron. Flip will work when the rate is over 80%.
Sorry for the wrong alert. Please accept a newbie's apology :)
On the stock transmitter, flip works even if I do not increase the rate. Perhaps it has automatically changed the rate when the flip command is activated.
Last edit: 19 Jan 2017 13:18 by ajtank.
19 Jan 2017 13:17 #58180 by goebish
No problem, so ... code cleanup then pull request :)
19 Jan 2017 13:34 #58181 by goebish
ajtank wrote: On the stock transmitter, flip works even if I do not increase the rate. Perhaps it has automatically changed the rate when the flip command is activated.
No, that's because the protocol is permanently set to high rate, and the FC requires that the stick is moved > 80% to engage flip.
That's one of the issues of not implementing rates as on stock Tx ...
19 Jan 2017 13:37 - 19 Jan 2017 13:38 #58182 by ajtank
So does the rate button on the stock transmitter actually change the throttle rate?
Last edit: 19 Jan 2017 13:38 by ajtank.
19 Jan 2017 13:38 - 19 Jan 2017 13:59 #58183 by goebish
No, it changes the maximum angle and yaw rate of the quad (FC side), sticks still have full range even in low rate mode on stock Tx.
Last edit: 19 Jan 2017 13:59 by goebish.
19 Jan 2017 13:40 - 19 Jan 2017 13:41 #58184 by ajtank
Thank you for the explanation. Looks like I need to start learning how to decode the SPI capture. I know too little how the quad operates.
Last edit: 19 Jan 2017 13:41 by ajtank.
19 Jan 2017 13:48 #58185 by Stefan_Z
Replied by Stefan_Z on topic CX 10D Traces
Is there anything left to capture?
Sorry I was busy the last days, no chance to whip out the analyzer…
19 Jan 2017 13:49 #58186 by goebish
No, looks like everything is working :)
19 Jan 2017 13:59 #58187 by Stefan_Z
goebish wrote: No, looks like everything is working :)
Cool beans!
I need to install what now exactly? The next nightly?
Also will all those ne protocols be integrated into the next stable releases? or are we already running out of space?
19 Jan 2017 14:01 #58188 by goebish
For now you can install the test build:
www.dropbox.com/sh/zmbdc0t3q0u30on/AADEb...aMLWyCwhgj1egWa?dl=0
Then it should be in the nightly in 1-2 days ...
It should be in the next "stable" release as well.
19 Jan 2017 14:27 #58190 by goebish
19 Jan 2017 15:52 #58191 by Gurzo
CH6 Works well! In both. (cx10wd and cx10d). Good flips.:)
19 Jan 2017 16:49 #58194 by FDR
Replied by FDR on topic CX 10D Traces
Merged.
07 Feb 2017 07:02 #58852 by plaisthos
Replied by plaisthos on topic CX 10D Traces
I took me way too long to finally test the CX10D and my friends CX10WD. I did them however (the proted multi code) and the work fine. Thanks very much for reverse engineering the protocol!
17 Feb 2017 18:34 #59237 by cmpang
Replied by cmpang on topic CX 10D Traces
goebish wrote: For now you can install the test build:
I just got a CX10wd, installed the test build but not able to bind.
The question is what is the binding procedure and the channel config (mapping)?
cmPang
17 Feb 2017 18:37 #59240 by goebish
Default mapping (AETR), Q303 protocol, CX10WD format option, test build is not required anymore, you can install a nightly build.
ajtank, can you confirm that this protocol is working ?
17 Feb 2017 18:42 #59241 by cmpang
thanks for you quick reply. i now seems able to bind (changed from fadt to slow led blinking).
but not to arm by following the stock (moving the throttle stick up and down) tx procedure
how about other channels for flip and othets?
17 Feb 2017 18:45 #59242 by goebish
I think this is because this protocol also has auto take off / land.
Channel 5 has 3 positions (auto land / normal / auto take off), I think it should be set to "normal" (0) if you want to arm manually.
Flip is on channel 6, as usual.
If you can't get it to work, just wait for ajtank to post his .ini file ;)
Time to create page: 0.303 seconds
