CX 10D Traces
13 Apr 2017 11:20 #61422 by goebish
Replied by goebish on topic CX 10D Traces
No idea, I do not have this machine myself, maybe plaisthos can tell, if he's still reading this thread.
13 Apr 2017 11:32 #61425 by Chimera
Replied by Chimera on topic CX 10D Traces
I really appreciate your hard work to implement protocols you don't even use, that's one of the reasons I bought a logic analyzer so I can give back and help the community that has helped me.
13 Apr 2017 13:59 #61430 by plaisthos
Replied by plaisthos on topic CX 10D Traces
In my remote the XN297 was on a small daughter board that had only like 6 connections, so I just dumped all of them. Cannot check anymore because I throw away my remote.
gist.github.com/schwabe/9e8563f1abecbee4...ghter_board_cx10-jpg
13 Apr 2017 17:43 #61436 by Chimera
ok yeah that's very different to mine, I got the pins mapped to the bigger IC and will solder jumpers tonight. Is there any special mode in Logic that I'm supposed to capture on, or is it just a case of turning on the TX and saving what goes through pins 1-4?
13 Apr 2017 18:24 #61438 by goebish
Just capture at 16 MHz, no particular settings.
Start capture before switching the transmitter on.
14 Apr 2017 10:47 #61451 by Chimera
Hopefully I did this right, there's a settings mismatch error at the beginning that I couldn't get rid of
14 Apr 2017 10:50 - 14 Apr 2017 10:58 #61453 by goebish
Something is wrong, there's no CSN, or maybe it's shorted with SCK, or that's not the good pin.
Your capture:
What it should look like:
Last edit: 14 Apr 2017 10:58 by goebish.
14 Apr 2017 11:05 #61454 by goebish
Also, please don't post your capture files directly on the forum, use dropbox or google drive or ... then give a shared link.
14 Apr 2017 21:31 #61482 by Chimera
Well, this project just ended abruptly as I somehow managed to remove one of the legs from the "big" IC and now the Tx won't work at all (power light just flashes, no beep). Unfortunately that means there's now no chance of my CX10 ever flying again, since my Devo won't bind with it and I don't have the original Tx to use (and I'm out the cost of the logic analyzer). Not a good day...
14 Apr 2017 21:45 #61483 by goebish
Sorry for your loss :(
My advice is to practice soldering on a scrap board with similar pitched ICs before doing it on a "valuable" board if you're not used to this kind of stuff.
Now your best bet is to hope someone has the same revision as yours and dump it someday ...
14 Apr 2017 21:51 - 14 Apr 2017 21:52 #61484 by Chimera
as much as I hate to spend more money, this board looks identical (except for the build date) - www.ebay.com/itm/Cheerson-CX-10WD-CX10WD...9:g:ORgAAOSwYXVY0Dsa
edit : nevermind, not identical
Last edit: 14 Apr 2017 21:52 by Chimera.
14 Apr 2017 21:55 - 14 Apr 2017 21:59 #61485 by goebish
Looks like this is a D board (not WD), but not the same than plaisthos ...
As usual, Cheerson is using different hardware and software for each batch :P
Last edit: 14 Apr 2017 21:59 by goebish.
07 Feb 2018 18:25 #67433 by bonx
Replied by bonx on topic CX 10D Traces
I have several little drones (tozo, drocon, visuo, etc) and i started to modify my devo12s with deviation.
I paired with success a CX10 blue version, but i have no success with the others.
I started to look deeper with a CX10D. As i'm unable to bind it, i suppose that maybe the one i have use a slightly different protocol.
I solder required pins on my remote and connected to a fx2 usb chip.
Then i used sigrock la to capture datas.
Datas seems correct, but i don't know what to do with it.
The only things i found are (if i'm not wrong):
ID : BE 5F 34 12
TX: 2B 14 28 40 25 3D 22 3D 22 3A 1F 37 1C 34 19 31 16 2E -> 24Mhz
Sigrock software analyze datas, but does not seem to export analysed data.
It can export captured data in VCD format, can it help ?
I'm really interested in understanding how it works and in changing all my remote by the devo.
Regards
20 May 2018 16:14 #69341 by DPyro
Replied by DPyro on topic CX 10D Traces
What is the proper button to launch the quad on the devo 7e? I can bind but unable to do anything else. I tried the trim buttons on the transmitter.
20 May 2018 17:00 #69342 by goebish
Map a switch to channel 5 for auto take off / land.
Or use stick gesture:
Stefan_Z wrote: By the way - there IS a way to manually control the motors with the original remote.
Start motors: left stick -> left-bottom + right stick -> right-bottom
Stop motors: left stick -> left-bottom + right stick -> right-bottom (for 2 seconds)
31 Jul 2018 10:56 #70005 by armelfelipe
Replied by armelfelipe on topic CX 10D Traces
I`ve just tried to binf my CX-10D with Devo 7E using the protocol Q303 with both CX10 and CX10W variants with no success. I`ve used nightly build cc06d0 firmware instead the test builds avaiable in this thread.
The quad`s lights remains blinking quickly meaning no binding. Is there some bind procedure diferent to do that rather than just switch on the model and then pressing the button "bind" on transmitter?
Or Should I prefer try the test build avaiable in this thread instead the newer nightly build?
31 Jul 2018 11:03 #70006 by goebish
Seems the newer cx10d is using yet another protocol :(
Can you open the transmitter to check what's inside please ?
31 Jul 2018 11:11 #70008 by armelfelipe
plaisthos wrote: In my remote the XN297 was on a small daughter board that had only like 6 connections, so I just dumped all of them. Cannot check anymore because I throw away my remote.
My stock receiver is simmilar i showed by @plaisthos, except the code printed on board is JG-CX1011TX-4
31 Jul 2018 11:26 #70009 by goebish
Ok, so that's just a different protocol, as usual with the CX10s, each batch is using a new protocol ...
If you're willing to dump what happens on the SPI bus I should be able to add the protocol.
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
Also, seems there's yet another new CX10 that's not using a nrf24l01 or xn297 at all, but has an "all in one" MCU+RF :(
Time to create page: 0.297 seconds
