Mjx Bugs 3
24 May 2018 22:52 #69401 by DPyro
Replied by DPyro on topic Mjx Bugs 3
I'm not getting a fixed id on a bugs 3 mini.
25 May 2018 14:34 #69405 by Exiter
Replied by Exiter on topic Mjx Bugs 3
The Black and Silver
26 May 2018 04:39 #69413 by JayDrone
Replied by JayDrone on topic Mjx Bugs 3
ok so i have it on the black and silver model I can get a fixed id number and have tryed it on 2 diff bugs 3s I have both come up with a negitive fixed id number and the toggles wont do anything any sugjestions please
26 May 2018 05:27 #69414 by JayDrone
UPDATE got it situated I have it bound to the mjx bugs drocon 3 as well as a 1st gen bugs 3 will be binding to many others I have a full line up of them
26 May 2018 17:47 #69421 by JayDrone
ok I have bugs on the jumper thank you -- is there any wat to increase the pitching as it seems to be same or less than stock controller -- or is it possable to create a new file to put on t8sg for much greater pitching SAY a turbo bugs 3 protocol -- ??
26 May 2018 18:51 #69422 by mmakai
Replied by mmakai on topic Mjx Bugs 3
In a previous post hexfet decided to not work on different speed modes (at least in the current state of development), that can be handled in the mixer. Those some weeks while hexfet returns to bugs 3 protocol development is a good opportunity to gather possible problems of the current implementation from the testers.
27 May 2018 01:59 #69427 by JayDrone
the drone flys well but i think added speed or pitch values would be nice -- sure i tryed 125% and just didnt seem to pick up that much pitching idk
29 May 2018 01:52 #69451 by davdrone1
Replied by davdrone1 on topic Mjx Bugs 3
Hi Guys,
My original Bugs 6 binds using the Bugs3 protocol. Turns out I made a transcription error entering the Tx ID with an earlier build.
I detected this using the auto lookup version.
Jaydrone has just put up a video demonstration that the new Bugs 8 Pro will also bind with the Bugs3 protocol.
Getting more useful every day ....
Time flies like a banana
29 May 2018 02:10 #69452 by JayDrone
yes the bugs 8 pro i just put on it --
I did hover test works well the lvc on the drone also works on the drone as to be expected and loss of connection from t8sg alarm will also sound i will do flight video in some time
30 May 2018 00:51 #69469 by DPyro
If it's working on all these other versions am I doing something wrong on the bugs 3 mini?
30 May 2018 00:53 #69470 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Does anyone know Where do I solder the jumper wire to take captures for the bugs 3 mini?
30 May 2018 00:54 #69471 by JayDrone
no ur not the mini and the bugs 3h are not on the same protocol and wil not work with the t8sg off of this dfu file
01 Jun 2018 05:22 #69494 by C0ckpitvue 777
I'm trying to find the ground to solder the rest of the jumper wires to take captures of the b3 mini but I can't find the ground,if anybody can find the ground from the pics by the RF chip traces,can you please mark it in the photo,thanks in advance.
01 Jun 2018 11:15 #69500 by DPyro
Right where it says GND.
01 Jun 2018 12:39 #69502 by C0ckpitvue 777
Thanks but that wasn't it,that's the ground for the battery.I found it using the multimeter and will u pload the captures later.
01 Jun 2018 12:58 #69503 by goebish
Replied by goebish on topic Mjx Bugs 3
Ground is common, you could have soldered to battery - ;)
01 Jun 2018 16:53 #69508 by C0ckpitvue 777
Wow,I never knew that,thanks appreciate it.
01 Jun 2018 17:33 #69509 by goebish
By the way, I've been lurking this thread, very good job hexfet! That's not an easy one ...
01 Jun 2018 23:35 #69510 by C0ckpitvue 777
I just took this capture of the b3 mini bind sequence,would like to know if it's good so I can proceed with the captures,if anyone with experience in reading captures look at them it will be greatly appreciated.
www.mediafire.com/file/kw0tkodqbtrv622/T...0on%20Bind.logicdata
02 Jun 2018 22:52 #69523 by hexfet
Replied by hexfet on topic Mjx Bugs 3
Can't download from that link. Clicking the green button opens a pop-under and never starts a download. If you put it in a .zip you can probably upload it here.
For the control travel we can revisit the driven trims and see if the problem is just wrong directions. Someone please post a bugs3 model file so I can see which channels are reversed.
mmakai, nice work on the rxid mapping. Not sure what's best for the memory requirement. Probably okay if it's just not added to the limited-memory builds.
Time to create page: 0.323 seconds
