Mjx Bugs 3
- C0ckpitvue 777
01 Feb 2018 01:03 #67328
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Thank you Hexfet but the link is sending me to the main page where only the options on the left are showing up,I would also like to contribute to your patreon for helping out the community,
- davdrone1
- davdrone1
01 Feb 2018 01:17 #67329
by davdrone1
Time flies like a banana
Replied by davdrone1 on topic Mjx Bugs 3
You can get to it via Downloads, Test Builds, [hexfet]protocol_bugs3.
I'll download the version for the Jumper. Exciting!
01 Feb 2018 01:18 - 01 Feb 2018 01:26 #67330
Replied by hexfet on topic Mjx Bugs 3
The test builds will remain in the
same place
as the first link. I must've mis-copied the link, but seem to have lost the ability to edit my posts - but there was a delete button.
The deleted post said test builds are updated. Found some test code I'd left in that would prevent binding.
Thank you for the kind offer but I do this because I like to
edit: now there's an edit button...maybe some maintenance going on
Last edit: 01 Feb 2018 01:26 by hexfet.
- C0ckpitvue 777
01 Feb 2018 01:27 #67331
by C0ckpitvue 777
I appreciate your great generosity hexfet and if I can help with anything just let me know bro.I am forever grateful for you and every other guru that contributes.
- C0ckpitvue 777
01 Feb 2018 01:44 #67332
by C0ckpitvue 777
I tried with the test build,still not binding.I tried all fine frequencies -300 through +300 to no avail,maybe someone would like to give the Jumper a shot with the 8888397 build.
- davdrone1
- davdrone1
01 Feb 2018 01:59 #67333
by davdrone1
Ready to blow the dust off my Win XP machine to flash the test build to my Jumper. Will report results as soon as I have them. Fingers crossed!
- C0ckpitvue 777
01 Feb 2018 02:07 #67334
by C0ckpitvue 777
Thank you Dave.
01 Feb 2018 02:09 #67335
Okay, thanks for testing. Need some time with the A7105 datasheet as it's my first time using it. Should have something to try later tonight or tomorrow.
- C0ckpitvue 777
01 Feb 2018 02:13 #67336
by C0ckpitvue 777
Thanks Hexfet,I probably get a new bugs 3, this 1 is pretty crashed up the shell is broke and 1 motor is down but I am willing to donate it to deviation and pay for the shipping if it's reasonable if you feel you need it..
- davdrone1
- davdrone1
01 Feb 2018 02:38 #67337
by davdrone1
Really appreciate your effort in this hexfet.
I've tried to bind with both the Bugs 3's and the Bugs 6, without success. Gave them all a few minutes at 30mW to bind.
All 3 are in good nick, and fly well with standard Controllers.
C0ckpitvue, I don't understand your comment "I tried all fine frequencies -300 through +300 to no avail."
Is there something else I can do with the Jumper setup to test this?
- C0ckpitvue 777
01 Feb 2018 02:48 #67339
by C0ckpitvue 777
I don't know how the jumper is set up but on the devo 10 when you highlight the bugs 3 press enter, the freq fine option pops up,what you do is scroll the frequencies slowly both ways down- and up+ and see if it binds to any of those frequencies,You can scroll 5 at a time and try to bind EX:245,250 ,255 -200-205 etc all the way until you hit the max where you can't go no more,I had to do that with the futaba protocol to get my xk x251 to bind.
- davdrone1
- davdrone1
01 Feb 2018 03:09 #67341
by davdrone1
Thanks - as the expression goes, "... and you're going to learn something today." I hadn't noticed the "Freq Tune" option after I'd accepted "Bugs 3" before.
I didn't need it for the Eachine E011 or the Hubsan X4 107L. I think I'll wait until the next version before I give it a shot.
Like your Devo 10, I can set values from -300 to +300.
- C0ckpitvue 777
01 Feb 2018 03:20 #67342
by C0ckpitvue 777
The first picture is the bugs 3 option you press enter on the next picture is the frequency fine screen it takes you to.
- davdrone1
- davdrone1
01 Feb 2018 03:31 #67343
by davdrone1
Thanks again - I get exactly the same screens on my Jumper.
- C0ckpitvue 777
01 Feb 2018 03:34 #67345
by C0ckpitvue 777
You're welcome.Did you scroll the fine frequencies and try to bind it to the quad?
- davdrone1
- davdrone1
01 Feb 2018 03:52 #67346
by davdrone1
Since hexfet is working on a new test version, I'll hold off until that is ready before I try fine tuning the frequency.
I Know the crystal in the Eachine E010 had problems with frequency drift.
Since I have 3 Bugs that all work with each others controllers, I'm hoping that I should not need to fine tune.
01 Feb 2018 04:03 #67347
Test builds
are updated. The A7105 initialization is now much closer to what the captures show, even though that means writing some values the datasheet says are not valid...
yes, having the equipment in hand is much easier. I will send you a pm.C0ckpitvue 777 wrote: Thanks Hexfet,I probably get a new bugs 3, this 1 is pretty crashed up the shell is broke and 1 motor is down but I am willing to donate it to deviation and pay for the shipping if it's reasonable if you feel you need it..
- davdrone1
- davdrone1
01 Feb 2018 05:02 #67348
by davdrone1
I seems to have damaged the usb connector on the Jumper T8SG.
I won't be able to load and test new versions supporting the Bugs 3 until I fix it.
I'll be back as soon as I sort it out. Not a good time for this ... Sorry guys.
- C0ckpitvue 777
01 Feb 2018 08:50 #67352
by C0ckpitvue 777
Sorry to hear that Dave,I just want to really thank you for your efforts and willingness to help.I will be shipping hexfet the bugs 3 on Friday,hopefully everything will be fixed on your jumper by the time this is deviated.
- SeByDocKy
01 Feb 2018 10:33 #67353
by SeByDocKy
Replied by SeByDocKy on topic Mjx Bugs 3
Stupid question, but was the Bug3 bind procedure proceed before to capture data ? (as far I remember with this one, you have press & hold the red button while turning the radio and then the quad .... something like this)
I can help also to test.... I have the MJX Bugs3 around the corder ....
Time to create page: 0.289 seconds
- Mjx Bugs 3
