Furibee F36 protocol attempt
07 Apr 2017 08:57 #61234 by yets
Replied by yets on topic Furibee F36 protocol attempt
That's a shame as the stock controller is awful.
07 Apr 2017 10:34 #61236 by SirDomsen
Replied by SirDomsen on topic Furibee F36 protocol attempt
I wonder all the time how to get hands on one of these datasheets. I mean, the developers of those quads obviously should have them. Maybe it's possible to get the datasheet if ordering a bunch of those mcus? Assuming a datasheet would help to reverse engineer the protocol or make the whole compatible with Silverware for example - which means no need for reverse engineering the protocol anymore... Deviation compatibility is given then anyway...
07 Apr 2017 17:37 #61244 by magic_marty
Replied by magic_marty on topic Furibee F36 protocol attempt
Best option currently is simply replace the fc with the E010 control board it is nearly the exact same thing and is deviation compatible...
07 Apr 2017 17:55 #61246 by SirDomsen
Of course - but that isn't the same. Then the board rocked you and not vice versa ;)
07 Apr 2017 18:48 #61248 by wasp09
Replied by wasp09 on topic Furibee F36 protocol attempt
goebish wrote: I wouldn't count on it anytime soon ;)
My Jan 15 order of F36 is still no show, got refunded after dispute. With no deviation support I don't think I would reorder the F36.
Perhaps I'll spend that money to beef up motors and battery for my H36.
Please remember you still have a H20H protocol waiting for you to finish. :P
10 Apr 2017 10:18 #61335 by DIGGIDY
Replied by DIGGIDY on topic Furibee F36 protocol attempt
Stupid question as I'm no expert in any of this, but this thread says the Furibee F36 has or shares the same TX board as the Eachine H8 mini, although it does look like a it may be a slightly different version, so is it possible they are using the same protocol?
www.deviationtx.com/forum/model-requests...-f36-needs-deviation
10 Apr 2017 10:28 #61336 by goebish
Replied by goebish on topic Furibee F36 protocol attempt
No they're not the same at all.
The H8 mini is using a XN297 while the F36 has an unknown RF core that can't be emulated with a nrf24l01.
05 May 2017 14:27 - 05 May 2017 14:29 #62031 by wasp09
May 5 here. My Jan 15 order of F36 has not arrived. It has already been listed as Expired on SG Post according to 17track. However suddenly CanadaPost updated its tracking not available timestamp this morning. Perhaps there is still a chance that I would need the F36 protocol 110 days after order. :dry:
BTW I have ordered an E011 to fill in the void. It is on its way via epacket. It should be faster than going through SG I hope.
Last edit: 05 May 2017 14:29 by wasp09.
05 May 2017 14:33 #62032 by goebish
I gave up on the F36, it will be pretty hard to crack without knowing which RF core it's using, and even with that I'm not sure it could be emulated with one of the 4 usual modules.
I didn't had much time to work on new protocols for the last 2 months, I should be back on track soon ;)
05 May 2017 22:00 #62049 by wasp09
Too bad. You give up when I finally receive my F36 ordered 110 days ago. :(
Plan B would be merging it with my H36 if I cannot stand the stock TX any more. I suppose it won't be too difficult transplanting the H36 FC into the F36 body.
Quick test by attaching a piece of AA battery (almost 14g) to the stock F36 showed that it could still take off. I should be able to use a bigger battery after mounting the FPV camera.
08 May 2017 18:55 #62165 by UABMaddog
Replied by UABMaddog on topic Furibee F36 protocol attempt
Goebish, anything I can do to help? I have my analyzer and should have my F36 by the end of the week.
I am finally getting into the protocol analyzing side of things.....I am a glutton for punishment...LOL
Right now I have a bit of personal time to invest in trying to get the F36 in Deviation......sure would love to fly it with my Devo 7E.......
08 May 2017 19:04 - 08 May 2017 19:05 #62166 by goebish
A logic analyzer is useless for this machine as the MCU+RF are in the same IC (no external spi bus to dump...).
I was able to dump data over the air with an HackRF ( see previous page ) but I'm not able to make sense of it.
Last edit: 08 May 2017 19:05 by goebish.
08 May 2017 19:08 #62167 by UABMaddog
Now this has me very interested.....will have to get my radio/EE geek buddies in on this......Furibee F36, you will assimilated, resistance is futile......LOL
Will let you know when I get this in the RF lab and see if they can get some sense of it.
08 May 2017 19:48 #62171 by bikemike
Replied by bikemike on topic Furibee F36 protocol attempt
Good luck but I think this one isn't worth the effort. It can't be emulated with an nrf24l01+ and there are much better options out now. The Eachine E011 and Boldclash BWHOOP B-03 both use Bayang protocol and can be flashed with custom firmware.
08 May 2017 23:23 #62181 by xxx
Replied by xxx on topic Furibee F36 protocol attempt
For the challenge!
I wanted to get back to this, but suddenly I am in the middle of other things. The LT8900 did arrive, but it's kind of late
silverxxx
11 May 2017 00:24 #62225 by UABMaddog
I just got my Eachine 011, and it seems an aweful lot like the F36 and will see about getting it working with my Devo 7e once I get the 3in1 module installed.
11 May 2017 14:24 - 16 May 2017 03:30 #62234 by wasp09
My E011 has been in Vancouver Customs since yesterday. I should get it within a week. :)
It would fight for my 25mW AIO camera against my existing H36 and F36. I guess the F36 FC would be out since there is little hope on getting this protocol hacked out. E011 should have most power and FC should have been supported under bayang_nrf24l01.
The E011 arrived today. I ordered a mode 2 but I received a mode 1. I kept running it the wrong way as the sticks are reversed. I could not control it by crossing my hands. :ohmy: Had to fly it using my devo 10 right away.
The build quality of the E011 isn't that good. It came with loose and out of balanced props. The frame seems the weakest comparing to F36 and H36. I have also swapped the FCs of F36 and H36. In a sense I have more than enough to carry my FPV camera around. I can live without F36 protocol for now.
Thanks for attempting.
Last edit: 16 May 2017 03:30 by wasp09.
27 May 2017 07:57 #62597 by martonmiklos
Replied by martonmiklos on topic Furibee F36 protocol attempt
Hi guys,
First of all thank you for your all efforts in the reverse engineering of this beast!
If my understanding is correct the main issue is the fact that the MCU/RF piece is unknown.
If someone has least two dead boards or receiever ICs it might be useful to contact with zeptobars:
zeptobars.com/en/support-us
to see if they would have a willingness to decap and scan them.
It might show some directions about the chip/MCU type.
27 May 2017 16:52 #62608 by martonmiklos
Hi bikemike!
Could you please check which pins of the receiever IC is GND, VCC and which pins are wired to the SCL, SDA testpads and to the antenna?
A quick google search with TSSOP24 2.4GHz MCU lead me to this IC:
www.nst-ic.com/f/1/1702115145.pdf
Could you please check if the pinout of this could match the IC's pinout on the board?
Thanks in advance! (My device is still on it's way from China, but I definitely would like to fly with a normal TX at some point.)
27 May 2017 23:35 #62616 by xxx
the pins do seem to match.
silverxxx
Time to create page: 0.426 seconds
