Nihui U807 with XN297L
17 Feb 2017 07:13 - 17 Feb 2017 07:48 #59223 by youngpatrick
Nihui U807 with XN297L was created by youngpatrick
Need help for protocol of my new Nihui U807 quadcopter. It cannot bind with YD-717(Nihui) protocol with Devo 10 nightly build.
Last edit: 17 Feb 2017 07:48 by youngpatrick. Reason: Add photo of stock transmitter
17 Feb 2017 07:26 - 17 Feb 2017 07:26 #59224 by ajtank
Replied by ajtank on topic Nihui U807 with XN297L
According to the info here , U807 uses Flysky protocol or A7105 module. Are you sure your quad uses XN297L ?
Last edit: 17 Feb 2017 07:26 by ajtank.
17 Feb 2017 07:50 #59225 by youngpatrick
Replied by youngpatrick on topic Nihui U807 with XN297L
I have also binded the quadcopter with Flysky protocol (wltoys extension v6x6) but it failed :\
02 Jul 2017 01:19 #63242 by etoyoc
Replied by etoyoc on topic Nihui U807 with XN297L
I did just get a new U807 and it has the same markings on the PCB. I have an older U807 which binds fine to my devo. This one won't. I tried using the transmitter that came with the U807 and it will not work with the old U807, but will work with the new U807, so I would say that the new revision uses a different protocol. Did you ever come up with something that would work?
02 Jul 2017 16:48 - 02 Jul 2017 16:49 #63249 by etoyoc
Looks like it says XN297L to me. Actually, it looks like XN297LCU, so maybe that is a different beast altogether.
Last edit: 02 Jul 2017 16:49 by etoyoc.
03 Jul 2017 01:09 - 03 Jul 2017 01:10 #63252 by captjack01
Replied by captjack01 on topic Nihui U807 with XN297L
looks like bad solder joint on pins in circle above it on led
Last edit: 03 Jul 2017 01:10 by captjack01.
03 Jul 2017 13:04 - 03 Jul 2017 13:05 #63262 by etoyoc
more than adequate solder on the opposite side of the board, but yeah, not hardly any solder on this side. All 5 of the LED's are soldered with one pin not soldered on this side of the board. Soldering on the other side looks like something I would have done. Perhaps hand soldered and they just tacked the LED down on this side on one pin and flipped it over to solder both pins on the other side.
Last edit: 03 Jul 2017 13:05 by etoyoc.
01 Aug 2017 15:18 #63665 by youngpatrick
Nothing I can do for binding my U807 quad with the stock transmitter. Because I am a Mode 1 flyer (My Devo 10 setup in mode 1 also) and that is why I ask for the new deviation firmware to bind it.
PS: Sorry for my lateeeeee reply.
04 Sep 2017 10:44 #64161 by goebish
Replied by goebish on topic Nihui U807 with XN297L
If it doesn't bind with any of the existing protocols + format options, we can't do anything without a dump of the stock Tx ;)
Time to create page: 0.373 seconds
