Protocols as a submodule?
02 Apr 2017 01:28 #61046
Protocols as a submodule? was created by mwm
Now that we have (unfortunately in my opinion) moved from hg to git, we might as well try and leverage some of the features of git.
In particular, the submodule feature makes it possible to push parts of the project into different repositories and manage their state separately from the rest of the project. While there are a number of things that I think might benefit from this, the one I think wins the most would be the protocols folder.
The downside is that you have to manage the state separately. An extra command to update to the latest versions in the build process. Similarly to push your changes back, branch, etc.
The upside is that it's now easy to work with different versions of the protocols and the rest of the project. So the build of the last release code with new protocols (something which I feel is of great value to the community) is easy. Similarly, if you're interested in working on protocol code but would rather stay with the release build - that's easy too.
Finally, and possibly most importantly, people working on other projects that use the protocol code - like the DIY mutlimodule - would be able to check out just the protocol code. i'm not sure how feasible sharing the code between the two now would be, but the ultimate goal here is to make it possible for such projects to use the protocols as a library/submodule/etc.
I don't really do much work on protocols so can't do much beyond set up the submodule. I'd be happy to do that if any of the people who do work on protocols is interested in seeing it.
- victzh
02 Apr 2017 03:50 #61047
by victzh
Replied by victzh on topic Protocols as a submodule?
I do support this in principle but there are many particular details we should figure out.
First, should it be done under the same group, deviationtx? I believe yes, but there are other people from RCGroups (@planger and @midelic) whom you mentioned in your post, who are also developing protocols and interested in them without Deviation. As their protocols are almost verbatim duplicate of ours we'd benefit from this effort, and some development was done in this direction, but as far as I understand not completed.
Second, how about Travis integration and nightly builds. I know too little about it to figure out how easy it is to retain CI builds and nightlies upon check in into a module.
02 Apr 2017 08:41 #61055
Replied by mwm on topic Protocols as a submodule?
We can add external collaborators to a repository with write permission. I've created a Protocols repository and invited @midelic to verify this is possible.
The hash you have checked out in the submodule is (well, should be) stored in the main repository. If you make changes to the submodule (pull, edit/commit), you need to commit in the main as well to record the hash. Similarly, you need to push both sets of changes to their respective remotes. Once that's done, the change in the main repository should trigger a build just like any other change.
Getting travis to update the submodules before the build requires adding the appropriate git command to the pre-installs script in the yaml file:
before_install:
- git submodule update --init --recursiveDo not ask me questions via PM. Ask in the forums, where I'll answer if I can.
02 Apr 2017 18:44 #61085
Replied by FDR on topic Protocols as a submodule?
I don't think these technical things (like how we compile the nightly builds) are the most problematic part of a separate protocol library.
The interface to them is much more challenging.
Now they are integrated into the fw, with different calls and interrupt handlers, they use globals for their settings and/or data exchange.
How would you solve that without too much overhead, not to hurt the critical timing used in the protocols.
Besides that every project use them quite differently, some of them don't even use STM32 and libopencm3 as a platform.
For example AFAIK Midelic is working with AVR...
- victzh
02 Apr 2017 19:46 #61092
by victzh
The protocol interface surface is quite limited. A protocol has only one exported function and uses very well defined set of externals to read the channels and to call the radio. Atmel AVR8 peculiarities are solved as a set of macros to mark progmem. And protocol code does not deal with hardware directly, so libopencm3 or any other hardware support library is completely irrelevant for this part of code, fortunately.
The only problem is telemetry, unfortunately is has very weak abstraction on protocol level, unlike the channels. We need to think about telemetry for sure.
02 Apr 2017 20:41 #61096
Do you mean the PROTO_Cmds function?
While not directly, but it still deals with with hardware through some abstraction layers, like the RF chip functions or the clock handling, which need to be equalized in the using projects, like the before mentioned Channels array as well.
The problem with the telemetry is that it can have very different value types, otherwise it could be handled as an output counterpart for the Channels.
Do we have VARIANTs?
(just kidding...)
- victzh
02 Apr 2017 23:39 #61101
by victzh
Yes, protocols call the RF chip functions and they must be implemented outside of this module, as they are in midelic/pascal's code now.
Clock - we don't call any clock functions in protocol code, we just return required timeout in microseconds, so no dependency on clock.
Telemetry - yes, there are many value types, but the same is true about Channels - they're normalized to -10000..10000 range, but they can represent many actual protocol ranges. I would like to see Telemetry as just filling out the telemetry array in some detailed enough mapping (maybe floats, not integers) and then some kind of mixer which parse these values, maps them into sensible ones and display. The same flexibility as now in channel mixer settings.
03 Apr 2017 04:14 #61104
I mean I saw that they reset and set the timer to the timing they use (with a function of course), and even specify callback functions...
I'm not sure you can easily normalize telemetry values, at least not all, like for example the GPS data.
Other problem, that you don't know their number in advance
- victzh
03 Apr 2017 05:33 #61106
by victzh
Yea, timer - but it is always expressed in microseconds, and uses two functions CLOCK_StartTimer and CLOCK_StopTimer. They do it once in a lifecycle of protocol - at initialization (maybe call stop timer on deinit, but it's not necessary as far as I understand).
So right now the src/protocol/spi which contains RF chip drivers should be moved somewhere. Also support files src/protocol/protocol.c and src/protocol/Makefile.inc do not belong to the protocol module.
iface_*.h files are also Deviation-dependent - they contain Deviation's types like u8, u16 etc.
Telemetry - now we have several telemetry types, but what if all values representable in these types just live by themselves. Futaba's TXs have several types for GPS, temp etc. which represent corresponding instruments connected to the receiver. You can assign a type to a telemetry channel (or a block of channels in case of complex data) and they'll be deciphered from the channel(s).
03 Apr 2017 08:08 #61108
I presume we can't hold place for all possible telemetry values, so the different values need to be identified with an enumerated value type, like "RX voltage", "Temperature1", "Air speed", etc.
Each value type should determine the data type of the value, so yes, we can leave the values as they are, and leave that to the code, which will interpret it, however there still can be incompatible data type, like a string for example, which takes more space then the standard 4 or 8 bytes used by the numeric types, unless we use pointers directly to the receiver buffer, which might be dangerous, since it will be updated asynchronously.
03 Apr 2017 09:49 #61111
The telemetry system is really in need of reorganization - it's all ad hoc on a per-protocol basis now. But this isn't the place to talk about it. So I'll just note that we don't use floats now, and that's probably a good thing since we don't have floating point hardware. Also, I'd like to see things set up with ranges instead of types, in large part so we can sanely add telemetry values to the mixers as percentages of those ranges.
03 Apr 2017 11:34 #61114
While I generally agree, how do you percentize a GPS coordinate?
I think for most numbers a propery choosen fixed point format is fine...
What if would make the percentage conversion configurable, i.e. only those telemetry values could be used, which are assigned with a configurable absolute value.
For example, I have the battery voltage from my 3s battery, so I choose 12.6 (=4.2*3) as 100% for it. But if I had a 2s battery, I could choose 8.4 instead...
- Fernandez
03 Apr 2017 15:36 - 03 Apr 2017 15:41 #61123
by Fernandez
Replied by Fernandez on topic Protocols as a submodule?
And what if general telemetry field are just a nr as Tfield 1-100?
Then we need some kind of "ini" to define the telemetry field and label for each, Tfield 1 is volt 1, Tfied 2 is temp 1 etc etc. depending per protocol.
Is it really needed to decode, display all those telemetry variables in the protocol? If protocol is defined, could we not, just select scroll true the list as defined in the ini, (so per protocol there may be a smaller or bigger list), and user defines pick the values of interest and the Tx only read use those telemetry fields as user selected ? Other telemetry values not of interest are just discarded?
All a bit of topic but some related whishes for me:
a) I like to see some time thresholds on alarms and better use of telemetry to prevent too many alerts. So if telemetry event, V bat is Below 3.7V for more then 2sec (adjustable), only then alert.
b) I would like some very simple statistics; min-max values on telemetry fields and or an event counter, f.i. to see how many time RSSI was below threshold as set etc.
This just could be a handy fast check after each flight, may be discarded at power down.
Last edit: 03 Apr 2017 15:41 by Fernandez.
Time to create page: 0.111 seconds
- Protocols as a submodule?
