IRDRONE Ghost x5 Wifi Camera (XN297LBX) capture
21 Oct 2017 15:49 - 21 Oct 2017 15:53 #65164 by Elric
Thank you for telling me if this drone can have a protocol in deviationtx.
To arm, use the throttle up and down.
Cature attached:
1drv.ms/u/s!AuNBpmXL1y0Rg8sJ9yLfWYBb47uAwQ
- OFF
- power with pairing
- throttle up and down (2 times)
- handle to translate left right (2 times)
- forward backward (2 times)
- flip
- headless
- return to home
IRDRONE Gost x5 picture:
Drone 1339 picture :
Last edit: 21 Oct 2017 15:53 by Elric.
21 Oct 2017 19:59 - 21 Oct 2017 20:13 #65169 by goebish
There are only some bind and data packets in the capture, no init parameters, please start capturing before powering the transmitter on.
There's also some garbage, check the probes connection (use short wires) and perhaps lower capture bitrate a notch.
Last edit: 21 Oct 2017 20:13 by goebish.
21 Oct 2017 20:31 #65170 by goebish
Even with missing parts I can see it's a variant of the Bayang protocol, pretty similar to the X16 AH sub-format but not exactly.
I'm not sure it will work, but you should try a test build from this thread (this protocol is not in nightly yet):
www.deviationtx.com/forum/protocol-devel...ersion-altitude-hold
21 Oct 2017 20:38 #65171 by Elric
8Mhz capture ... dupond 4cm
21 Oct 2017 20:52 #65172 by goebish
Thanks, that's perfect :)
www.dropbox.com/s/cuvb28wkrofe6ii/irdrone_x5_2.txt?dl=0
I confirm that's a Bayang protocol variant, please test with X16 AH format option, it might work though they're not exactly the same.
21 Oct 2017 20:55 #65173 by Elric
TEST OK with Bayang X16 AH but throttle is not good.
the throttle stick half blinks the leds of the drone and the propellers do not turn anymore.
On the other hand at low speed, the drone moves forward and backwards and goes to the right and to the left.
21 Oct 2017 20:59 - 21 Oct 2017 21:10 #65174 by goebish
Great, I'll wait for the X16 AH protocol to be merged into master (during next week ?) then I'll make the necessary changes for this one. I'll probably need more captures ...
Last edit: 21 Oct 2017 21:10 by goebish.
21 Oct 2017 21:02 #65175 by Elric
21 Oct 2017 21:27 #65176 by goebish
I see you've posted in the X16 AH thread, do you have one ?
The more testers the faster it will get merged ;)
21 Oct 2017 21:38 #65177 by Elric
I have a X21 being delivered for three weeks .. Chinese post is not very fast for large packages.
21 Oct 2017 22:01 - 21 Oct 2017 22:32 #65178 by goebish
Elric wrote: TEST OK with Bayang X16 AH but throttle is not good.
Can you try to set channel 11 low / high ?
edit: that probably won't change anything.
Last edit: 21 Oct 2017 22:32 by goebish.
21 Oct 2017 22:33 #65180 by goebish
Here's a test build with IRDRONE format for Bayang protocol:
www.dropbox.com/sh/yh1uf360bpdmjue/AAB7M...bXEFTz77YbqRJsa?dl=0
Please check if that's better with that.
21 Oct 2017 23:13 #65181 by goebish
Also, can you make a capture with the different rates please ?
22 Oct 2017 06:59 - 22 Oct 2017 07:02 #65186 by Elric
File Attachment:
File Name: model10.ini
File Size:4 KB
With the Bayang - IRDRONE protocol, everything works super well.
CH6: 360 ° flips: ok => but I have to test it in the open air. because in my house, the ceiling is there: o)
CH7: Photo: the four leds of the drone flash once for taking pictures. but my camera is a wifi model. so no picture on the SD card even with a normal Syma camera. But this must be normal because you need the IRDrone camera. And even with the Android app, the photo's upload it to the smartphone.
CH8: Video: the two leds on the back of the drone blink while the movie camera. it only works with the normal Syma camera.
CH9: Heatless mode: ok. all the leds of the drone flash during this mode.
CH10: Return to home: ok: all leds of the drone flash during this mode. The CH9 must be deactivated to deactivate it or use the broomsticks.
CH11 : does not work on this drone
I give you my model.ini because I do not know how to set the dual rate. On this drone, there are three speeds. I have the impression that the drone is at the fastest speed by default.
Luckily, I have a VISUO XS809-W-HD-G (2MB wifi camera with altitude hold and android application) that also works with this protocol Bayang X16 (hold altitude)
I think all the game VISUO should work
XS809 H, H-C-VGA, H-C-HD, H-W-VGA and H-W-HD.
Last edit: 22 Oct 2017 07:02 by Elric.
22 Oct 2017 08:10 #65187 by FDR
Elric wrote: I give you my model.ini because I do not know how to set the dual rate. On this drone, there are three speeds. I have the impression that the drone is at the fastest speed by default.
That's normal.
We usually don't use the built in dual rates but program it in the TX...
22 Oct 2017 09:59 #65190 by goebish
Thanks for testing!
I'll make a pull request once Moeder has made one for the X16 AH protocol.
22 Oct 2017 10:54 - 22 Oct 2017 10:58 #65191 by goebish
Elric wrote: Luckily, I have a VISUO XS809-W-HD-G (2MB wifi camera with altitude hold and android application) that also works with this protocol Bayang X16 (hold altitude)
Thanks for the info, I'll add them to the compatibility spreadsheet once the protocol is in the nightly build.
docs.google.com/spreadsheet/ccc?key=0Any...kE&usp=sharing#gid=0
Last edit: 22 Oct 2017 10:58 by goebish.
22 Oct 2017 11:27 #65193 by Elric
Bayang Irdrone CH6 flips tests OK.
22 Oct 2017 15:02 #65203 by Moeder
goebish wrote: Thanks for the info, I'll add them to the compatibility spreadsheet once the protocol is in the nightly build.
I thought we are now using the wiki for that...
Supported models
22 Oct 2017 15:19 #65206 by goebish
Yes we are, but I still maintain the old spreadsheet as I find it easier to read (and to edit!).
I know I've to make a pass on the wiki and manual, their protocols / sub-protocols list is not updated, but I've to admit that's something I hate to do and I'm lazy ;)
Time to create page: 1.076 seconds
