FrSky Negative LRSSI
24 Oct 2017 23:30 #65235 by ben1977
FrSky Negative LRSSI was created by ben1977
I just realized that I can get some telemetry information on my Eachine Flying Frog (Q90) , with the FrSky protocol.
Especially the "LRSSI" information that can be used for telemetry alarm if the signal becomes weak.
I have noticed that the LRSSI is expressed with negative values on my Devo10 telemetry monitor screen, it is about -40dB when the quad is close, and can go to -85dB if the distance becomes important.
The problem is that I've only managed to set telemetry alarms about LRSSI with choice between < or > (which is fine) but only with positive values (which is not good in my case, since LRSSI is always negative :-( ).
Is there a way to set it or a trick to avoid this problem ?
Thank you
25 Oct 2017 02:26 #65240 by hexfet
Replied by hexfet on topic FrSky Negative LRSSI
This is due to a wrong min/max limits for LRSSI in the code. I've made a PR with a fix. Test build for Devo 10 is here .
25 Oct 2017 06:15 #65250 by ben1977
Replied by ben1977 on topic FrSky Negative LRSSI
Just tested it now, and it works GREAT !
Thank you very much !!!!
Time to create page: 0.195 seconds
