Bugs 3 mini
22 Mar 2019 19:24 #73514 by goebish
Replied by goebish on topic Bugs 3 mini
I'm not sure but try with Channel 10.
23 Mar 2019 14:57 #73517 by ncfom
Replied by ncfom on topic Bugs 3 mini
Thanks for the suggestion .
I tried channel 10 on a switch for altitude hold, but no joy.
Channels 1-6 all work as they should . AETR, arm and lights
I have a Devo 7e.
25 Mar 2019 10:43 #73543 by goebish
Have you tried channels 7, 8 and 9 ?
I've implemented all the flags available on the Bugs 3 mini transmitter that C0ckpitvue 777 sent me, I believe the 3H is using the same transmitter, but maybe I'm wrong and it has an extra flag.
Do you have a logic analyzer ?
25 Mar 2019 13:08 #73546 by goebish
Also, make sure your firmware is up to date, I recently fixed an issue that affected channels 7, 8 and 9.
25 Mar 2019 14:48 #73547 by ncfom
In my first post I asked for info on the bugs 3h assuming it would be the same for my eachine ex 2h as everything else works the same. I have tried channels 7,8,9, and 10. No joy
Firmware devo 7e v5.0.0-d21bf92
AH is not a necessity for me
Thank You for help
13 Apr 2019 23:41 #73874 by jbuck
Replied by jbuck on topic Bugs 3 mini
Just curious, is there a way to increase the rates for pitch and roll on the bugs 3 mini? I have it working fine but it doesn't have the crazy pitch and roll the regular deviated bugs 3 has. I have the jumper v2 plus and increased all rates to 125%
14 Apr 2019 08:58 - 14 Apr 2019 10:01 #73876 by goebish
I just made a test build with dynamic trims for Bugs3Mini protocol (same as Bugs3), please check if that's better like that:
www.dropbox.com/sh/ifli03dyvafr64n/AAD5K...zRFuCsyBjc-vcZa?dl=0
Max rate for this protocol is 100%, don't set it to 125%, that will only add some dead zones at the end of stick travel ...
Last edit: 14 Apr 2019 10:01 by goebish.
14 Apr 2019 13:02 - 14 Apr 2019 13:13 #73880 by goebish
@ncfom we now have a method to dump xn297 transmitters that doesn't involve using a logic analyzer nor a SDR device ( see here ) , would you like to help finding the missing flag for altitude hold on Bugs 3H ?
Last edit: 14 Apr 2019 13:13 by goebish.
14 Apr 2019 13:15 #73881 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
goebish wrote: I just made a test build with dynamic trims for Bugs3Mini protocol (same as Bugs3), please check if that's better like that:
Is this the reason it hesitates and pops out of pitch at full throttle?
14 Apr 2019 13:16 #73882 by goebish
No idea, would you like a test build with dynamic trims ? for which transmitter ?
14 Apr 2019 13:24 #73883 by C0ckpitvue 777
Devo 10
14 Apr 2019 13:31 #73884 by goebish
Ok, dropbox folder updated, let me know if it's faster ;)
14 Apr 2019 14:06 #73886 by C0ckpitvue 777
Thank you Goebish,as soon as It stop raining outside I'll test and report back..
14 Apr 2019 17:42 #73889 by C0ckpitvue 777
I was almost cited by the F.A.A for excessive speeds,I can confirm Goebish some how added rocket fuel into the diet of this bugs 3 mini.I just got to adjust the yaw and pitch trims to get it more stable..Thanks once again Goebish...
14 Apr 2019 19:49 #73890 by goebish
Thanks for testing!
15 Apr 2019 11:13 #73894 by jbuck
Thanks goebish,I will reflash and try again this evening. Good tip on not using 125% for rates. Is this typical or just for some protocols? It just makes you "think" you're going 25% faster haha
15 Apr 2019 11:42 - 15 Apr 2019 11:43 #73896 by goebish
It is common to most "toy grade" protocols, typically protocols for which a standalone RX does not exist.
Last edit: 15 Apr 2019 11:43 by goebish.
16 Apr 2019 01:19 #73909 by jbuck
I am still pretty much a noob at this updating process. I am not sure what to do once I open the dropbox and click on the jumper v2 plus. Which file do I need to update with in DFU mode? Maybe I need to do more research and figure out what to do
16 Apr 2019 01:27 - 16 Apr 2019 01:30 #73910 by C0ckpitvue 777
I have the devo 10 and I just update the dfu file in the folder,with the defuse tool
Last edit: 16 Apr 2019 01:30 by C0ckpitvue 777.
16 Apr 2019 01:32 #73911 by C0ckpitvue 777
I was wondering if there's a way to transition from acro to angle in flight w/out restarting the bind process like Hexet did with the Bugs 8 pro..
Time to create page: 0.304 seconds
