Bugs 3 mini
- DPyro
- goebish
- NRF Weirdo
07 Oct 2018 20:05 - 08 Oct 2018 07:45 #71220
by goebish
Ok, so you got a reply from the quad but it doesn't bind (probably wrong final address), more work is required ...
Now I've to simulate the reply of the quad with an arduino+nrf24 to try to understand how rxid affects address and/or hopping sequence.
That's interesting that C0ckpitvue 777 and I have Rx that can be used with the same addresses/frequencies despite different IDs.
Replied by goebish on topic Bugs 3 mini
DPyro wrote: I selected bind, turned the quad on and then it went back to menu. RX ID changes from 0 to -29664
Last edit: 08 Oct 2018 07:45 by goebish.
- C0ckpitvue 777
07 Oct 2018 20:06 #71221
by C0ckpitvue 777
I also had a problem with the first time trying to update,re download and reinstall,I already know,lol.
Replied by C0ckpitvue 777 on topic Bugs 3 mini
DPyro wrote: No, they blink.
- DPyro
07 Oct 2018 20:07 - 07 Oct 2018 20:17 #71222
by DPyro
Replied by DPyro on topic Bugs 3 mini
Well not even the control it came with is binding now...
EDIT: Had to turn quad on first then controller while holding red button.
Last edit: 07 Oct 2018 20:17 by DPyro.
- goebish
- NRF Weirdo
07 Oct 2018 20:10 #71223
by goebish
@DPyro, just to confirm, it doesn't bind, but deviation exits the "binding" dialog when a battery is connected to the quad ?
- DPyro
07 Oct 2018 20:18 #71224
by DPyro
Yesgoebish wrote: @DPyro, just to confirm, it doesn't bind, but deviation exits the "binding" dialog when a battery is connected to the quad ?
- C0ckpitvue 777
07 Oct 2018 22:14 #71225
by C0ckpitvue 777
Maybe Seby can give a sample if not to occupied...
- goebish
- NRF Weirdo
08 Oct 2018 06:28 - 08 Oct 2018 10:25 #71226
by goebish
I don't need any more bind sequence for now, I've to build a rig that simulates the reply of the Rx to the Tx during bind to understand how rxid affects final address and channel hopping. I suppose hexfet did the same for the Bugs3 (remember the spreadsheet?
I've to understand how the checksum that's sent by the quad in bind reply & telemetry packets is computed first:packets sent by 2 different RX, 1st byte is the checksum, 2nd and 3rd bytes are rxid.
I don't get it yet.
CD 83 1D 00 00 00 00 00 00 00 00 C0 00 00 00 00
2C 83 1D 5F 00 00 00 00 00 00 00 C0 00 00 00 00
30 83 1D 63 00 00 00 00 00 00 00 C0 00 00 00 00
2E 83 1D 61 00 00 00 00 00 00 00 C0 00 00 00 00
31 83 1D 64 00 00 00 00 00 00 00 C0 00 00 00 00
2F 83 1D 62 00 00 00 00 00 00 00 C0 00 00 00 00
32 83 1D 65 00 00 00 00 00 00 00 C0 00 00 00 00
91 68 FC 00 00 00 00 00 00 00 00 C0 00 00 00 00
92 68 FC 01 00 00 00 00 00 00 00 C0 00 00 00 00
AD 68 FC 1C 00 00 00 00 00 00 00 C0 00 00 00 00
E4 68 FC 53 00 00 00 00 00 00 00 C0 00 00 00 00
E3 68 FC 52 00 00 00 00 00 00 00 C0 00 00 00 00
E8 68 FC 57 00 00 00 00 00 00 00 C0 00 00 00 00
F3 68 FC 62 00 00 00 00 00 00 00 C0 00 00 00 00
F4 68 FC 63 00 00 00 00 00 00 00 C0 00 00 00 00I don't get it yet.
Last edit: 08 Oct 2018 10:25 by goebish.
- goebish
- NRF Weirdo
08 Oct 2018 10:36 - 08 Oct 2018 23:18 #71227
by goebish
Ok got it!
rx packet checksum = (0x6d + sum of packet[1:15]) & 0xff;
(same "magic number" as tx packet but used with sum of bytes instead of xoring)
Now to build a rig with stock tx+arduino+nrf24 when time allows ...
edit: 0x6d is the 'm' of "mjxRC" which is the bind address converted to ASCII actually
Last edit: 08 Oct 2018 23:18 by goebish.
08 Oct 2018 16:15 #71229
Replied by hexfet on topic Bugs 3 mini
Yes. My rig was a devo10 running protocol code that emulated a bugs3 receiver, stock tx, and a Cypress prototyping stick.goebish wrote: I don't need any more bind sequence for now, I've to build a rig that simulates the reply of the Rx to the Tx during bind to understand how rxid affects final address and channel hopping. I suppose hexfet did the same for the Bugs3 (remember the spreadsheet?
- goebish
- NRF Weirdo
09 Oct 2018 10:56 - 09 Oct 2018 15:08 #71231
by goebish
Rig is up and running, spitting out rxid / address pairs at the impressive rate of around 3 per second (out of 65536)
First 3 bytes of the address are easy to guess (2nd byte is constant, I suppose that's a byproduct of the txid, but we don't care), and 2 last bytes often repeat, it shouldn't be that hard to crack (ie easier than the Bugs3 ?...).
Arduino code, if anyone is curious: gist.github.com/goebish/71fa5b6568e200438bf2090d50692480
Last edit: 09 Oct 2018 15:08 by goebish.
- goebish
- NRF Weirdo
09 Oct 2018 17:35 #71234
by goebish
Still running, 50% done, 3 hours to go.
- C0ckpitvue 777
09 Oct 2018 19:25 #71235
by C0ckpitvue 777
Awesome job Goebish,you definitely know your stuff,if I can help with anything else please let me know.☺️
- goebish
- NRF Weirdo
09 Oct 2018 20:03 #71236
by goebish
I want everyone to be able to bind first (even if a spreadsheet is required for 1st bind at first...) then I've to thoroughly understand the flags (modes ...), that's not the case yet, I've to make more captures or watch packets in realtime.
- goebish
- NRF Weirdo
09 Oct 2018 22:57 - 09 Oct 2018 23:33 #71237
by goebish
New test builds available (7e & 10):
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
How it works (seems complicated but that's not...):
- start with no battery in the quad
- select Bugs3Mini protocol then press bind
- connect a battery to the quad
- wait for the bind dialog to exit then disconnect the battery for now
- go to the protocol options dialog then write down the "RX Id" value
- switch off transmitter
- go to bit.ly/bugs3mini_rxid
- find your RX Id in the green column (rxid s16)
- write down the corresponding value from the blue column (address[3:4] s16)
- connect your transmitter as an USB drive
- open the models/modelsxx.ini file in a text editor (under Windows, use notepad++ for exemple, not the builtin notepad, it does corrupt end of lines ...)
- under the [protocol_opts] section, fill the Address= field with the value from the blue column
- save and disconnect USB
Et voilà, it should bind now
You can now check that channel 5 controls leds.
source: github.com/goebish/deviation/blob/protoc...bugs3mini_nrf24l01.c
Now we've to try to make sense of this spreadsheet so we don't need it anymore ...
Last edit: 09 Oct 2018 23:33 by goebish.
- DPyro
09 Oct 2018 23:15 #71238
by DPyro
Devo7e crashes and reboots after pressing bind.
- goebish
- NRF Weirdo
09 Oct 2018 23:20 #71239
by goebish
I do not have a 7e but it works on my t8sg v2+ and 7e emu.
Have you flashed the dfu and copied the new protocols folder to the filesystem ?
- goebish
- NRF Weirdo
09 Oct 2018 23:29 #71240
by goebish
I've just rebuilt and uploaded the 7e firmware just in case ...
- DPyro
- goebish
- NRF Weirdo
09 Oct 2018 23:41 #71242
by goebish
That's weird, pressing bind doesn't do much more than before, it only grabs the RX Id.
C0ckpitvue 777 can you check on your 7e please ?
Time to create page: 0.082 seconds
- Bugs 3 mini
