Bugs 3 mini
09 Oct 2018 23:57 #71243 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
It works for me but I did have the same problem at a time,dypro my fix was to use another model file,I replaced a model file I no longer use but that was the fix,@Goebish,I am going to do your procedure with both 7E and 10 right now,I will report back in a few.To be clear it's only a bind and not arming yet,correct?
09 Oct 2018 23:59 - 10 Oct 2018 00:10 #71244 by goebish
Replied by goebish on topic Bugs 3 mini
Correct, arming is not implemented yet (that would be dangerous as payload isn't 100% understood yet, we're dealing with a brushless, safety first ;)), only leds on channel 5.
Last edit: 10 Oct 2018 00:10 by goebish.
10 Oct 2018 00:48 #71245 by DPyro
Replied by DPyro on topic Bugs 3 mini
I formatted fresh and it's still not working.
10 Oct 2018 00:57 #71246 by C0ckpitvue 777
The Bugs 3 Mini successfully bound to both 7e and 10 via your step by step with 1 exception for the devo 10
- open the models/modelsxx.ini file in a text editor (under Windows, use notepad++ for exemple, not the builtin notepad, it does corrupt end of lines ...)
- under the [protocol_opts] section, fill the Address= field with the value from the blue column.
I didn't see the address field in the devo 10 model/protocol,so I did it from the protocol option screen on the transmitter.
10 Oct 2018 00:58 #71247 by C0ckpitvue 777
What are you getting Dypro?Did you try to bind another model that uses the nfr24?
10 Oct 2018 01:16 #71249 by DPyro
C0ckpitvue 777 wrote: What are you getting Dypro?Did you try to bind another model that uses the nfr24?
It just reboots when I click bind.
10 Oct 2018 01:22 #71250 by C0ckpitvue 777
Did you try another model file?When I was getting that I just tried a model I didn't use anymore scrolled to the bugs 3 mini protocol and bind,afterwards I changed the name and replaced it with the bugs 3 mini,,
10 Oct 2018 01:25 - 10 Oct 2018 01:28 #71251 by DPyro
C0ckpitvue 777 wrote: Did you try another model file?When I was getting that I just tried a model I didn't use anymore scrolled to the bugs 3 mini protocol and bind,afterwards I changed the name and replaced it with the bugs 3 mini,,
Just uses a blank model from the download. Can you share your model file?
EDIT: I don't even see [protocol_opts] in model ini
Last edit: 10 Oct 2018 01:28 by DPyro.
10 Oct 2018 01:26 #71252 by goebish
I noticed I forgot something in the code, I'm not sure it would have caused a crash, but download again and retry ...
10 Oct 2018 01:33 #71253 by goebish
I confirm I had a crash if I smashed the bind button, but the version I just uploaded has fixed it.
10 Oct 2018 01:36 #71254 by DPyro
goebish wrote: I noticed I forgot something in the code, I'm not sure it would have caused a crash, but download again and retry ...
Working now and bound.
10 Oct 2018 01:39 #71255 by C0ckpitvue 777
File Attachment:
File Name: model20.ini
File Size:24 KB
10 Oct 2018 01:42 #71256 by C0ckpitvue 777
Excellent....
10 Oct 2018 01:42 - 10 Oct 2018 01:43 #71257 by goebish
DPyro wrote: Working now and bound.
Yeah!!! :evil:
Next step: analyze the payload then it should be flyable ...
Having to use a spreadsheet for initial bind is not ideal, but better than nothing for now ...
Last edit: 10 Oct 2018 01:43 by goebish.
10 Oct 2018 01:52 #71258 by C0ckpitvue 777
You're the man bro.....Thank you for your hard work.
10 Oct 2018 17:54 - 10 Oct 2018 18:17 #71260 by goebish
I started analyzing the payload and I've a question, the arm and picture switches seems to have short and long press duration options, I couldn't find a manual online, can someone explains how they work please ?
Last edit: 10 Oct 2018 18:17 by goebish.
10 Oct 2018 18:29 #71261 by C0ckpitvue 777
goebish wrote: I started analyzing the payload and I've a question, the arm and picture switches seems to have short and long press duration options, I couldn't find a manual online, can someone explains how they work please ?
Short press=Arm
Long Press=Disarm
Photo short press= Photo
Photo Long press=Video
only when mjx camera is pugged into fpv port
10 Oct 2018 18:38 - 10 Oct 2018 18:38 #71262 by goebish
Ok, thanks, and what about the switch that's hard to push next to throttle, I suppose this is angle/acro mode ? And the switch on the back, is it for flips ?
Last edit: 10 Oct 2018 18:38 by goebish.
10 Oct 2018 18:56 - 10 Oct 2018 19:50 #71263 by C0ckpitvue 777
goebish wrote: Ok, thanks, and what about the switch that's hard to push next to throttle, I suppose this is angle/acro mode ? And the switch on the back, is it for flips ?
I believe you're talking about the flight Mode button between angle/acro.
www.mediafire.com/view/jqhz8b5a01ddh6y/I...%255B2%255D.jpg/file
Here is a link for the manual for the b3 mini..
www.firstquadcopter.com/download/mjx-bug...ser-manual-download/
Last edit: 10 Oct 2018 19:50 by C0ckpitvue 777.
10 Oct 2018 20:50 - 10 Oct 2018 20:52 #71266 by goebish
New build:
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
Channel mapping is the same than Bugs3 protocol:
ARM CHANNEL5
LED CHANNEL6
FLIP CHANNEL7
PICTURE CHANNEL8
VIDEO CHANNEL9
ANGLE CHANNEL10
Please test without propellers first!!!
Last edit: 10 Oct 2018 20:52 by goebish.
Time to create page: 0.292 seconds
