protocol for WL Heli V911-s
- hazemay
24 Jan 2020 17:26 #75805
by hazemay
Replied by hazemay on topic protocol for WL Heli V911-s
I found this topic, I want let my DEVO8S connected with my V911s.
I tried deviation-devo8-v5.0.0-0c4b4c0, deviation-devo8-v5.0.0-7fb7de1, deviation-devo8-v5.0.0-ee7176e
All these FW failed, I want use DEVO8S to control my V911s.
Please help me.
Please help me.
- Mack775
24 Jan 2020 20:51 #75806
by Mack775
Replied by Mack775 on topic protocol for WL Heli V911-s
www.deviationtx.com/forum/builds/6407-de...-protocols?start=480
Try this one works for me on the 8s but don't have the 11s but worth a try.
- hazemay
25 Jan 2020 02:57 #75808
by hazemay
Frustrating, I still can't succeed.
I tried it on deviation-devo8-v5.0.0-2019-10-29,
my hardware.ini is
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
is any information I need provide?
my hardware.ini is
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- Mack775
26 Jan 2020 17:48 #75820
by Mack775
[modules]
:enable-cyrf6936 = B12
;has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
That is it I think. I do not use the cc2500 on my 8s have very little that needs it. I use the nrf24l01 on A14 spot it important to me. If this is wrong you will have an error on startup screen.
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- hazemay
28 Jan 2020 07:30 #75831
by hazemay
I checked in my devo8s, and connect cable as 2401 to a15, 2500 to A14(TCK), 7105 to A13(tms). My question is "2401 connect to A15" is workable?
- Mack775
30 Jan 2020 00:51 #75853
by Mack775
www.deviationtx.com/forum/3-feedback-que...e-install-on-devo-8s
Read this, I have never heard of A15 and I have flashed about 20 devo's but that does not mean there isn't one.
- hazemay
02 Feb 2020 19:02 #75873
by hazemay
Thanks, I solved this issue.
My 4in1 module is old version.
thanks for your help.
- Sidwellmu
05 May 2020 10:38 #76228
by Sidwellmu
Replied by Sidwellmu on topic protocol for WL Heli V911-s for Jumper T8SG Plus
I would like to bind my T8SG with WLToys V911s, which protocol to use?
please assist.
please assist.
- Mack775
05 May 2020 19:31 #76232
by Mack775
Replied by Mack775 on topic protocol for WL Heli V911-s for Jumper T8SG Plus
- Sidwellmu
06 May 2020 07:33 #76239
by Sidwellmu
Thanks, it worked
- flotux
18 Jun 2020 17:57 #76500
by flotux
Replied by flotux on topic protocol for WL Heli V911-s for Jumper T8SG Plus
Is there a chance to implement the V911S "sub protocol" for the Eachine E119 helicopter? It has been implemented into the
DIY-Multiprotocol-TX-Module
with the following commits:
https://github.com/pascallanger/DIY-Multiprotocol-TX-Module/commit/693f9f58eb7da3254fc86e93b112b51890ec9bc2#diff-7a07c3af3b6626e17d5147f73e2e14a5
https://github.com/pascallanger/DIY-Multiprotocol-TX-Module/commit/68a6af0eb5159e113ac324b26fa86d3e02380555#diff-7a07c3af3b6626e17d5147f73e2e14a5
If you need someone to test please let me know. Of course you can use a Futaba S-FHSS satellite receiver. But that adds some weight. It would be better to use the integrade receiver.
- monty1235
25 Jul 2020 06:27 - 25 Jul 2020 06:29 #76611
by monty1235
Replied by monty1235 on topic protocol for WL Heli V911-s
Hi, I am unsuccessful in binding my WL Heli V911S. I am using Jumper T8SG Plus with deviation-t8sg_v2-v5.0.0-48d7be1. I have tried the V911S protocol with a few fixed IDs (123456, 888888, 999999). I could not figure out how to adjust the frequency for the V911S protocol, so I have not tried that. Does anyone have any tips or ideals for trying to get mine to bind? Thanks!
Last edit: 25 Jul 2020 06:29 by monty1235.
- cmpang
25 Sep 2020 15:29 #76827
by cmpang
I upgraded my T8SG carbon edition using the v2 (no plus) version and get a white screen. Please help
cmPang
Replied by cmpang on topic protocol for WL Heli V911-s
goebish wrote: @BirdBarber, @old4570, I converted the V911S protocol to use the CC2500 instead of the NRF24L01, that should fix your issues.
Test builds available here:
www.dropbox.com/sh/7k5f9f62ifucnd7/AACN4...pU_AMWWIKzdXOTa?dl=0
Please test & report
cmPang
- blackmoon
18 May 2022 15:10 #77988
by blackmoon
Replied by blackmoon on topic protocol for WL Heli V911-s
Would it be possible to update the protocol so it supports the latest XK (Wltoys) planes namely A220 A210 A260 ?
I tried with the latest build from Hexfet (thx btw to continuing to provide nightly builds) no joy.
I tried with a OpenTX from a friend and it works well.
If it isn't to much work, could someone port the changes made by Pascal to deviation ?
Thx !
Thx !
Time to create page: 0.117 seconds
- protocol for WL Heli V911-s
