C-17 Transport
- goebish
- NRF Weirdo
19 Apr 2019 13:48 - 19 Apr 2019 14:07 #74005
by goebish
Replied by goebish on topic C-17 Transport
Seems fine on my end (I can receive the packets with XN297 dump running on another transmitter). Maybe fine-tune is not enough, I'll add coarse tune, and if it still doesn't work we'll try to fiddle with gfsk deviation.
Last edit: 19 Apr 2019 14:07 by goebish.
- planger
19 Apr 2019 13:54 #74006
by planger
If you are trying to adjust outside of the bind interval, it won't do a bind...
Replied by planger on topic C-17 Transport
Are you really able to tune during bind? I thought on the devo that there was a popup on the screen while binding?goebish wrote: Tuning can be set in realtime, no need to restart the radio.
- goebish
- NRF Weirdo
19 Apr 2019 14:01 - 19 Apr 2019 14:13 #74007
by goebish
Sorry, I only meant he doesn't have to restart the radio.
Set tune, try bind, repeat
Last edit: 19 Apr 2019 14:13 by goebish.
- goebish
- NRF Weirdo
19 Apr 2019 14:57 - 19 Apr 2019 16:41 #74008
by goebish
@Fer, I updated the Devo 10 build with a Freq-Coarse setting, try steps 1 by 1, if this is really the problem I believe only a couple of clicks should be necessary (change carrier frequency in 100 kHz steps, no more than +/-5 clicks, that wouldn't make sense).
I'm not sure carrier frequency is the problem tho, fine-tune already allows +/-200 kHz which should be more than enough given it works with (some) nrf24l01 ... try it then we'll try with different gfsk deviation.
It's also using the same ID/Channel as a stock transmitter, just in case ...
Last edit: 19 Apr 2019 16:41 by goebish.
- Fer
19 Apr 2019 16:40 #74009
by Fer
Replied by Fer on topic C-17 Transport
The file is the same, the same link as before?
Also, you mean i change freq in steps of 100 (say -127, -50, 0, 50, +127 should be ok), and then for each Freq, i change Freq-Coarse one by one?
- goebish
- NRF Weirdo
19 Apr 2019 16:42 - 19 Apr 2019 16:45 #74010
by goebish
Same link as before, the devo 10 build has been updated. (revision 231bb33)
Yes that's ok for the procedure
Last edit: 19 Apr 2019 16:45 by goebish.
- Fer
19 Apr 2019 17:13 #74012
by Fer
Well, i tried Frequencies -127, -50, and for those i tried Freq-Coarse from -127 to +127 but not one by one, only steps of 10. Checking each frequency- coarse one by one from -127 to +127 would take 255 bind attempts for only one Frequency, and up to 1270 attempts in total. Am i right? If this is the case, it wil take a lot of time to check all those (unless i get lucky).
- goebish
- NRF Weirdo
19 Apr 2019 17:16 #74013
by goebish
Only need to test Freq-Coarse from -5 to 5, in steps of 1, not from -127 to 127
- Fer
19 Apr 2019 17:30 #74014
by Fer
Ooppssss... I missed that info
goebish wrote: Only need to test Freq-Coarse from -5 to 5, in steps of 1, not from -127 to 127
- Fer
19 Apr 2019 17:40 #74015
by Fer
Tried -127, -50, 0, +50, +127 and for each of them Freq Coarse -5 to 5 and still no joy. I may be doing something wrong... I wish i could beam the plane to you, for you could easily find out what is going on.
- goebish
- NRF Weirdo
19 Apr 2019 18:05 #74016
by goebish
Ok, probably the problem isn't the carrier then, I'll make a version with adjustable gfsk frequency deviation later.
- goebish
- NRF Weirdo
19 Apr 2019 20:15 - 19 Apr 2019 20:29 #74017
by goebish
Build updated (c45cc8b) with a "Deviation" setting ranging from -2 to 5 (100 to 190 kHz).
According to the datasheets:
NRF24L01 fsk deviation @ 250 kbps = 160 kHz (setting = +3)
XN297L fsk deviation @ 250 kbps = 125 kHz (setting = 0) to 150 kHz (setting = +2)
Coarse setting removed, I believe it's not useful.
Last edit: 19 Apr 2019 20:29 by goebish.
- Fer
19 Apr 2019 21:11 #74019
by Fer
Installed latest update, tried -127, -60, 0, 60, 127 with -2 to +5, no success. I would feel so much better if there was another one with the same V2 version to test too, because now if i am doing something wrong, i put you in trouble for nothing. After failing to bind, i turned on its own tx, it binds ok. I am willing to keep trying if you believe there are other things we could try.
- goebish
- NRF Weirdo
19 Apr 2019 21:30 #74020
by goebish
Probably a stupid question but are you sure this cc2500 module is working fine ?
I suppose Pascal will be able to do more tests in a few weeks.
- Fer
19 Apr 2019 21:51 - 19 Apr 2019 21:54 #74021
by Fer
Yes the module works fine, because i think that is what XK K110 and K120 is using, and X100 quad i think. Those work fine.
But, to rule that out, tommorow i will update the 3in1 DEVO i got. I will try with that too.
Unfortunatelly the one that has the original NRF doesn't have a CC2500 installed.
Last edit: 19 Apr 2019 21:54 by Fer.
- goebish
- NRF Weirdo
19 Apr 2019 22:14 - 19 Apr 2019 22:43 #74022
by goebish
I confirm the Futaba S-FHSS protocol is using cc2500, your module is working fine.
Just out of curiosity, can you run the protocol on a transmitter and XN297 Dump on another one and check for which parameters (freq/deviation) you get the best reception on channel 22 (most stable "Valid CRC found!") ?
No hurry
No hurry
Last edit: 19 Apr 2019 22:43 by goebish.
- Fer
20 Apr 2019 11:31 #74027
by Fer
I installed the firmware on the other DEVO 10, the one with the 3in1 and still didn't work.
For the other thing you say, do i need two DEVO's to do the job? Because the one with the 4in1 and the other with the 3in1 don't bind at all, while the one that binds doesn't have a CC2500. It binds with the "old" code using the NRF. I am not sure i understand what you want me to do. Give me some more instructions and i will try it.
- goebish
- NRF Weirdo
20 Apr 2019 11:32 #74028
by goebish
Just hold on for now, I think Pascal will have to do some tests when he has a chance.
- goebish
- NRF Weirdo
20 Apr 2019 11:50 #74029
by goebish
Have you tried to decrease Tx power ?
Could be that the Rx is swamped though I doubt this Rx has a LNA ...
- Fer
20 Apr 2019 14:09 #74034
by Fer
I performed another test with 10mw of power, still the same. Besides, i remember having tested it with the NRF and it would bind no matter how many mw of output i had chosen. Ok, i will hold for now, and wait.
Time to create page: 0.906 seconds
- C-17 Transport
