Frsky R9M lite
- is fpv
29 Jan 2019 01:38 #72599
by is fpv
Frsky R9M lite was created by is fpv
hi i was thinking to add frsky r9m lite to my devo 10, any ideas how to connect all the 8 pins on r9m lite to devo 10?
29 Jan 2019 02:45 #72601
Replied by hexfet on topic Frsky R9M lite
Picture of the
X-Lite transmitter bay pinout
. Couldn't find a picture of the module with pinout. The "first" five pins are the same pinout as the JR connector on the T8+. I like the picture because "first" could be either end.
Three connections are needed to the trainer port on the Devo10.
- trainer port tip to R9M PXX pin (PXX_OUT in picture)
- trainer port ring to R9M S.Port pin
- trainer port sleeve to R9M GND pin
The R9M Lite manual doesn't list max input voltage and don't know if the X-Lite pin labeled 6V is regulated or not. The power is up to you
- is fpv
29 Jan 2019 03:24 #72602
by is fpv
Replied by is fpv on topic Frsky R9M lite
so it only take 4 pin to connect to r9m lite. is it going to disable my voice output?
29 Jan 2019 03:47 - 29 Jan 2019 03:47 #72603
Correct. In the devo10 the same uart is used for both serial output and voice. Voice is disabled when a serial protocol is in use.
Last edit: 29 Jan 2019 03:47 by hexfet.
- is fpv
29 Jan 2019 11:51 #72608
by is fpv
how about binding procedure. does it have fixed id?
29 Jan 2019 12:53 #72609
Yes, zero to 63. There's more information in the user manual in the PXX protocol section.
- is fpv
29 Jan 2019 14:24 #72610
by is fpv
i think there's a bug on the latest firmware for devo 10. i just upgraded tx firmware to the latest one. i've seen the new protocol but i haven't tried it yet cause suddenly my tx restart it self with this latest firmware.i have to figure it out first.
Time to create page: 0.120 seconds
- Frsky R9M lite
