Cheerson CX10A has new another board.
- song1116
27 Feb 2019 01:54 #73032
by song1116
Cheerson CX10A has new another board. was created by song1116
Hello..
A couple of days ago I bought CX10A and I tried to bind it using IR8M.
I have tried CX10 -> Green and Blue also.
However I couldn't bind it.
So I have torn down CX10A and Transmitter.
Can you please take a look pictures below?
Is it possible to bind this CX10A using IR8M?
If possible, what protocol should I set?
Thanks for helping me..
- song1116
27 Feb 2019 09:35 #73040
by song1116
Replied by song1116 on topic Cheerson CX10A has new another board.
Today I have set all of the Q303 options but failed.
Is there any idea?
Is there any idea?
- goebish
- NRF Weirdo
27 Feb 2019 10:22 - 27 Feb 2019 10:41 #73042
by goebish
Replied by goebish on topic Cheerson CX10A has new another board.
It's probably using yet another protocol, as usual with Cheerson ... (CX10-A is supposed to use the CX10 "Blue" protocol)
I think it's using a XNS1042 MCU with builtin xn297l transceiver (SOIC-16, antenna connected to IC pin #1 in the transmitter), there's a chance it can be reverse engineered and added to Deviation but it can't be done with a logic analyzer, someone would have to send one to a developer for analysis.
Last edit: 27 Feb 2019 10:41 by goebish.
- song1116
28 Feb 2019 00:36 #73054
by song1116
Thanks a lot.. goebish.
To verify if the recent CX10 and CX10A have used same protocol, I placed an order of CX10 from Banggood.
It will take a time.. after receiving, I will report it here..
BTW If I want to send sample,should I send sample to who and where?
Is there any developer to help this issue?
- goebish
- NRF Weirdo
28 Feb 2019 01:41 - 28 Feb 2019 02:13 #73057
by goebish
I'm a protocol dev and I've the required hardware, you can send me a PM.
Note that I believe the TX is using a XNS1042 (and Cheerson has always used nrf24l01 compatible transceivers so far) but I can't be sure, so there's no guaranty.
Last edit: 28 Feb 2019 02:13 by goebish.
- song1116
28 Feb 2019 02:17 #73058
by song1116
I see. I understand..
Anyway. let me check first if the recent CX10 and CX10a have same transmitter and receiver..
And then I would like to ask you if you don't mind..
Thanks a lot for helping us.. =)
- goebish
- NRF Weirdo
28 Feb 2019 02:21 #73059
by goebish
No problem.
If you PM me please post here as well because email notification doesn't work for PMs and I don't always check.
- song1116
28 Feb 2019 02:23 #73060
by song1116
Yes sir.. I will... =)
- Moeder
08 Apr 2019 06:24 #73734
by Moeder
Replied by Moeder on topic Cheerson CX10A has new another board.
Do you still have the quad? If yes, could I give you a test build which will dump tx data for us?
- song1116
08 Apr 2019 09:19 #73735
by song1116
Yes. I still have it. due to the freight charge, I couldn't send it to PM.
Anyway what I should do? please let me know.
I will follow up and send it back to you. Thanks..
FYI, my transmitter is iRangeX iRX-IR8M.
- goebish
- NRF Weirdo
08 Apr 2019 09:45 - 08 Apr 2019 10:06 #73736
by goebish
Hi song1116,
Here is a test build that includes the new XN297 Dump feature.
First we'll check if this transmitter is using a XN297 compatible transceiver.
Download and flash this build to your IR8M:
www.dropbox.com/sh/857qdhte2dwmdmy/AAC0e...zL6VTrp0f1x9EJa?dl=0
On your transmitter, go to model menu / model setup then select a blank model and set it to "XN297 Dump" protocol.
Go to the Transmitter menu then XN297 Dump
Turn on scan by setting mode to 1 Mbps (Off -> 1 Mbps) then highlight < Ch 0 > and press ENT to start scanning.
Turn on your CX10A transmitter.
If valid packets are detected it should show "Valid CRC found!" on the bottom on the screen.
If nothing is found, try 250 K mode instead of 1 Mbps.
example with a Bayang transmitter:
Last edit: 08 Apr 2019 10:06 by goebish.
- Moeder
08 Apr 2019 10:19 - 08 Apr 2019 10:36 #73737
by Moeder
Thanks for making the build, goebish. I suggest not having the transmitters as close to each other as in the video, as this will likely give some false channels besides the correct ones (difference is usually a little flickering between valid and invalid packets on bleeding channels).
Last edit: 08 Apr 2019 10:36 by Moeder.
- song1116
09 Apr 2019 00:48 #73739
by song1116
Got it.. I am going to flash it and test then report it to you soon.
Thanks..
Thanks..
- song1116
09 Apr 2019 01:16 #73740
by song1116
Hi goebish and Moeder,
I am sorry for bad news.
This firmware didn't detect any valid packet. it did continuous scaning..
Please take a look attached pictures.
If there is anything that I can do, please let me know.. I will do with my pleasure.
Thanks..
Best Regards,
Keith
Thanks..
Best Regards,
Keith
- goebish
- NRF Weirdo
09 Apr 2019 08:55 #73744
by goebish
Ok, that's not a XN297 / XNS1042 then
That might be a HS6200 but a SDR device is required to check that.
- song1116
10 Apr 2019 02:15 #73755
by song1116
Thanks..
- pzcato
22 Aug 2019 16:28 #74964
by pzcato
Replied by pzcato on topic Cheerson CX10A has new another board.
Any updates on this?
I have 4 of these little quads, it would be great to see deviated.
- goebish
- NRF Weirdo
22 Aug 2019 16:43 #74965
by goebish
No update, send one to me or Pascal so we can check the RF signal with SDR, but there's no guaranty we can make it work with Deviation or MPM.
- pzcato
24 Aug 2019 00:33 #74972
by pzcato
I'd really appreciate that!
Where can I find your contact details?
PS. Thanks for doing stuff life this, your protocol developments have inspired so many people (young and old!) to get into this stuff. Amazing, inspiring stuff!
- goebish
- NRF Weirdo
24 Aug 2019 06:20 #74975
by goebish
PM sent.
Time to create page: 0.244 seconds
- Cheerson CX10A has new another board.
