Jumper T8SG V2 Plus and Crossfire
- Hans-Udo
13 Dec 2019 16:04 #75574
by Hans-Udo
Replied by Hans-Udo on topic Jumper T8SG V2 Plus and Crossfire
Hi Konatsu, I did not remove the first pin. I took it just so as it was.
- Konatsu
13 Dec 2019 16:29 - 13 Dec 2019 16:38 #75575
by Konatsu
I did restore that pin, but behavior is the same;/
Replied by Konatsu on topic Jumper T8SG V2 Plus and Crossfire
Hans-Udo wrote: Hi Konatsu, I did not remove the first pin. I took it just so as it was.
Last edit: 13 Dec 2019 16:38 by Konatsu. Reason: new video link
- Hans-Udo
13 Dec 2019 17:37 #75576
by Hans-Udo
you have to push the button on the crossfire module for binding. the button in the middle of the LED.
- Konatsu
13 Dec 2019 17:48 #75577
by Konatsu
And how can i configure it after binding?Hans-Udo wrote: you have to push the button on the crossfire module for binding. the button in the middle of the LED.
- Hans-Udo
14 Dec 2019 09:53 #75584
by Hans-Udo
after binding you can configure it normaly in model and mixer menu
- Konatsu
18 Dec 2019 16:29 - 18 Dec 2019 18:34 #75599
by Konatsu
I can't. CRSF menu is not working. RX is only working when i change it to PPM ;/
On deviation-t8sg_v2_plus-v5.0.0-e0ab3bc i can enter CRSF menu but it is empty
Update
I've removed pin 1 and it is now working on this build.
Update
Last edit: 18 Dec 2019 18:34 by Konatsu.
- Denis
19 Dec 2019 05:54 - 19 Dec 2019 05:55 #75601
by Denis
did you do the last night build? deviation-t8sg_v2_plus-v5.0.0-2b4606e. (18.12.2019) Does crossfire work with her?
Replied by Denis on topic Jumper T8SG V2 Plus and Crossfire
Konatsu wrote: I can't. CRSF menu is not working. RX is only working when i change it to PPM ;/
Update
Last edit: 19 Dec 2019 05:55 by Denis.
- Konatsu
19 Dec 2019 16:03 #75602
by Konatsu
I've installed deviation-t8sg_v2_plus-v5.0.0-2b4606e but i can't get into CRSF menu. Nothing is happening when i press enter on it.
19 Dec 2019 16:37 #75603
Replied by vlad_vy on topic Jumper T8SG V2 Plus and Crossfire
It doesn't implemented in nightly builds. PR #840
19 Dec 2019 16:56 #75604
PR #840 merged, you can test it with next nightly build.
- Denis
19 Dec 2019 22:29 #75605
by Denis
how to enable rssi?
vlad_vy wrote: PR #840 merged, you can test it with next nightly build.
how to enable rssi?
- Konatsu
21 Dec 2019 09:50 #75608
by Konatsu
OK, everything is working on latest build deviation-t8sg_v2_plus-v5.0.0-1ec5369
Thank all for help
Thank all for help
- Grajek
05 Jan 2020 01:43 #75662
by Grajek
Replied by Grajek on topic Jumper T8SG V2 Plus and Crossfire
Can you bind with the Jumper T8SG V2 plus, Crossfire Micro TX and nano Rx? Is there a binding feature within Deviation? Everything Im finding says you have to bind on another Transmitter first. I don't have a Taranis. Could I buy the Crossfire TX Lite and wire it and bind?
- Konatsu
05 Jan 2020 07:30 #75665
by Konatsu
Now you can do all this things from menu on t8sg. Also you can change vtx settings by Smart audio
- Konatsu
05 Jan 2020 08:56 - 05 Jan 2020 08:57 #75666
by Konatsu
Last edit: 05 Jan 2020 08:57 by Konatsu.
- Frazam
14 Jan 2020 03:09 #75707
by Frazam
Does this mean after the hardware mod and inserting the crossfire module, the t8sg v2 plus has full functionality?
I ask because i have a t8sg v2 plus carbon on the way but after reading about the limited crossfire support, I'm thinking if I should return it and get the t16 instead. I'd rather not cause I like the smaller size of the t8sg carbon, but if crossfire has limited functions I'll have no choice. I'd rather pay a little extra to have full functionality than be crippled. Thanks.
Btw, I joined specifically to learn more about crossfire compatibility.
Replied by Frazam on topic Jumper T8SG V2 Plus and Crossfire
Konatsu wrote: Now you can do all this things from menu on t8sg. Also you can change vtx settings by Smart audio
- Denis
22 Jan 2020 14:44 #75796
by Denis
Should vtx be tbs, or any other manufacturer?Konatsu wrote: Now you can do all this things from menu on t8sg. Also you can change vtx settings by Smart audio
- Konatsu
22 Jan 2020 16:43 #75797
by Konatsu
Any other supporting Smart Audio. I was using akk fx3-ultimate
- WhoopassFPV
26 Jan 2020 18:11 #75821
by WhoopassFPV
Replied by WhoopassFPV on topic Jumper T8SG V2 Plus and Crossfire
Would someone kindly post complete and EXACT processes with connecting T8SG V2 Plus and crossfire micro tx please.
From start, to finish including this so-called "hardware mod" (if it's necessary) which no one here directly links to.
Simply plugging in the crossfire module brings ZERO results and also no power going to the crossfire micro tx, in my case.
The module works if I plug in USB, then LED lights and breaths.
***Giving me a link to a video showing it working for someone else doesn't really provide a solution. (thanks for Nix Team Blacksheep)
Thanks in advance!
Thanks in advance!
- Konatsu
29 Jan 2020 08:42 #75847
by Konatsu
Just remove first top pin and connect lower part of this pin to lower part of last pin. Make sure that You are on latest build and id should work fine
Time to create page: 0.306 seconds
- Jumper T8SG V2 Plus and Crossfire
