Devo 12S Throttle stick? Cant turn on TX
- 304runner
07 Apr 2014 14:31 #22200
by 304runner
Devo 12S Throttle stick? Cant turn on TX was created by 304runner
Hello, I have a devo 12s and its set up to fly a DJi F550. I have been using it for about 3 weeks and its my first RC toy. I was stuffing around with some random alarm setting to ensure I couldn't have my throttle hold and manual mode switch enabled when turning on the TX.
I turned the unit off and then attempted to turn it back on again but now I get the "throttle stick" warning and my throttle is all the way down?
I have tried all switches and combinations but still cant get past that warning.
Is there a way to reset it completely?
07 Apr 2014 14:38 #22201
Replied by FDR on topic Devo 12S Throttle stick? Cant turn on TX
You are using the stock firmware, arent't you?
- 304runner
07 Apr 2014 14:50 - 07 Apr 2014 15:18 #22202
by 304runner
Replied by 304runner on topic Devo 12S Throttle stick? Cant turn on TX
Yes, just what came with it.
I just upgraded with the DefuSe program and file from the Walkera website but it seems to have kept all the old settings, so I'm still locked out
Last edit: 07 Apr 2014 15:18 by 304runner.
07 Apr 2014 16:14 #22203
Then other then set all switches to zero position and lower both sticks, your only chance is to connect the tx to DfuSe, backup the model files, and overwrite the currently selected one with an empty model file, or at least with a known good one...
- 304runner
08 Apr 2014 00:22 - 08 Apr 2014 01:19 #22223
by 304runner
Ok all sorted, I figured out how to erase it all.
Its unlocked now.
Thanks for your help.
Its unlocked now.
Last edit: 08 Apr 2014 01:19 by 304runner.
Stock Firmware Help
- Devo 12S Throttle stick? Cant turn on TX
