Devo 7 screen blank
- ovostick
14 Dec 2014 15:22 #26970
by ovostick
Devo 7 screen blank was created by ovostick
Hi everyone, not sure where to put this in the forum so i'm sorry if it's in the wrong place.
i could really use some help, i have a Devo 7 control and i got it today
And ive used about 2 times and it's worked fine and then just now i turned it on and there was no screen, it still functions fine but i dont have anything displaying on the screen just the backlight :'(
any help would be really appreciated.
- mikemacwillie
14 Dec 2014 19:50 #26978
by mikemacwillie
Replied by mikemacwillie on topic Devo 7 screen blank
Try putting it into USB mode and re-loading the filesystem.
- ovostick
14 Dec 2014 20:05 #26980
by ovostick
Replied by ovostick on topic Devo 7 screen blank
I would but i dont have the usb to 3.5mm jack to update / plug it into my computer AND cause i cant see anything on the screen i dont know how to put it into usb mode
- Daryoon
14 Dec 2014 21:06 #26982
by Daryoon
Replied by Daryoon on topic Devo 7 screen blank
Devo 7 or Devo 7e?
Devo 7 can't be flashed to use Deviation.
- ovostick
14 Dec 2014 21:13 #26984
by ovostick
Devo 7, i'm thinking of just flying with it until i can buy a devo 10.
everything still works fine and dandy until i need to change a setting on it haha, does the devo 10 bind with the genuis cp version 2?
- Daryoon
14 Dec 2014 21:20 #26985
by Daryoon
Yes, the Devo 10 is a great radio.
This whole forum is for support of Deviation opensource firmware.
Which is supported for the Devo 6s, 7e, 8, 8s, 10, 12.
So many will not have any experience with the Devo 7 unfortunately.
- ovostick
14 Dec 2014 21:22 #26986
by ovostick
Ahh my bad, that's awesome though. i think ill go the route of the devo 10 then thanks haha.
also i assume the LCD module in my devo 7 decided to seize existing
Thanks guys
Thanks guys
- Indigo
24 Dec 2014 01:00 - 24 Dec 2014 10:11 #27186
by Indigo
Replied by Indigo on topic Devo 7 screen blank
This might be the solution to your problem:
Fresh Install has Blank White Screen on Reboot? (Dev7e)
See also:
How to upgrade Devo TX to Deviation Firmware
NOTE:
On the official release version 4.0.1, USB drive mode is activated from 3rd item on main menu like in the how to videos.
However, in the more recent monthly builds eg. v4.0.1-92e1705 (Aug 1 nightly), USB drive mode is activated by holding down ENT button while you power on the transmitter. This new method will apply to all future releases.
See also:
NOTE:
Last edit: 24 Dec 2014 10:11 by Indigo.
- ThomasC
24 Dec 2014 08:55 #27194
by ThomasC
Replied by ThomasC on topic Devo 7 screen blank
In case it's truly a Devo7 (I own one myself): blank screen is a hardware problem. Try pressing down EXT while powering on - the display must show -UPGRADE- (separated into two lines). In case it doesn't show up anything, you have a hardware problem. There's no config change on the Devo7 that can cause the display to fail.
Have success
ThomasC
Have success
ThomasC
Time to create page: 0.302 seconds
Stock Firmware Help
- Devo 7 screen blank
