Devo 7 stuck in upgrade after updating
28 Mar 2015 02:29 #30343 by cwmize
I was upgrading my Devo7 tx ant it now is frozen in upgrade. Help!
28 Mar 2015 06:06 #30346 by Block137
Replied by Block137 on topic Devo 7 stuck in upgrade after updating
What version you're updating to?
28 Mar 2015 09:35 #30353 by Indigo
Replied by Indigo on topic Devo 7 stuck in upgrade after updating
After flashing firmware, did you then put it in USB mode (power on while holding ENT button) and upload the protocol directory? (Devo7e requirement)
You might need to reload the entire file-system. Create a backup first especially the model directory containing you model files.
If all else fails, just power up while holding down EXT button and flash it again with a good version. 4.01
28 Mar 2015 10:58 #30355 by mwm
Replied by mwm on topic Devo 7 stuck in upgrade after updating
And if you can't get it to power up in upgrade mode, try unplugging the battery for a bit before you power it back on.
28 Mar 2015 13:05 #30361 by SirDomsen
Replied by SirDomsen on topic Devo 7 stuck in upgrade after updating
Devo7 is not compatible with deviation! Try flashing the original firmware file 0.5A. You can download it from walkerafans.de
Greetz
SirDomsen
Time to create page: 0.045 seconds
