Program Update
14 May 2015 17:55 #32566 by Zamjustice
Program Update was created by Zamjustice
I've had a Devo 8S for about 3 years and have previously installed the relevant Deviation firmware. As I was still new to the Hobby I battled a bit with geting my head around the interface, so decided to revert back. The issue i have is that i can't get the TX to go into the "Program Update" mode. When i hold down the EXT button and power on i get USB Mode. Not sure what i'm doing wrong so any advice would be helpful.
14 May 2015 23:16 #32591 by mwm
Replied by mwm on topic Program Update
A mistake I make all to often is holding the ENT button - which starts the USB interface - and not the the EXT button to go into update mode. Just to be sure, double check that.
Does the drive you've got show up as formatted? If not, then you may be starting with no buttons held, and it's going into USB mode because the drive isn't formatted. That could be a number of issues.
Time to create page: 0.057 seconds
