DEVO 12 problem
11 Jun 2015 15:56 #33841 by matyasvane
DEVO 12 problem was created by matyasvane
I have problem with my transmitter - DEVO 12, I set on my transmitter on Throttle stick = 0, and when i start my transmitter, it say "Warning Throttle Stick" and i dont get EXT etc.
Please advise me what to do, Thank very much.
11 Jun 2015 16:24 #33842 by mwm
Replied by mwm on topic DEVO 12 problem
This is a Safety warning (not the safety feature of the throttle channel). Check your mixer to make sure the channels are in the right order - that the throttle stick is actually going to the throttle channel.
If that's the case, then you'll need to mount the Tx as a USB drive, edit the model file (don't use Notepad on windows, but Notepad++ is ok. Not sure what else is broken on Windows, but everything on a Mac, Linux or Unix system works fine), and find the [Safety] section where it says "Auto=min" and change it to say Ch#=min, where the # is the channel number your throttle is on.
11 Jun 2015 16:35 #33848 by matyasvane
Replied by matyasvane on topic DEVO 12 problem
I make this problem so:
In run transmitter i set minimum throttle ( Warning throttle stick ) at ZERO
I shutdown transmitter
I start transmitter and this problem has been created
Transmitter is not now run and no connect with PC
See photo scontent-cdg2-1.xx.fbcdn.net/hphotos-xft...880a30ec&oe=557BDA16
11 Jun 2015 16:59 #33852 by FDR
Replied by FDR on topic DEVO 12 problem
So you are using the stock Walkera firmware.
Ensure that the flight mode switch is in the normal position.
If it doesn't solve the issue, than you are probably in the wrong mode, so try to lower the elevator stick to minimum.
If that helps check which mode is set in the transmitter...
12 Jun 2015 15:28 #33924 by matyasvane
FDR wrote: So you are using the stock Walkera firmware.
here is my problem..
12 Jun 2015 16:16 #33931 by FDR
Yes, I understood the same.
Have you tried to lower the elevator stick too as I had suggested?
12 Jun 2015 18:03 - 12 Jun 2015 18:05 #33943 by matyasvane
FDR wrote: Yes, I understood the same.
Yes exactly, what should I do please? :/.. Throttle
Last edit: 12 Jun 2015 18:05 by matyasvane.
12 Jun 2015 18:40 #33944 by FDR
Just do the same with the right stick (the elevator), as you did with the left stick (the throttle).
The reason is that if the transmitter is in Mode 1 after the upgrade, the right stick is the throttle, which is in middle position...
The other possible reason is if your flight mode switch is not in the "normal" position, because then the throttle value is not at the minimum, so scheck the FMODE switch also...
12 Jun 2015 18:56 - 12 Jun 2015 19:02 #33948 by matyasvane
FDR wrote: Just do the same with the right stick (the elevator), as you did with the left stick (the throttle).
I do not understand you can not do video please? :/
I can not enter into the menu, I have here a warning throttle and get started, exit deal, krizek the display can not be pushed
Last edit: 12 Jun 2015 19:02 by matyasvane.
12 Jun 2015 19:10 #33949 by FDR
Prostě udělat to samé s pravou páčkou (výtah), jak jste to udělali s levou tyč (plyn) .v důvodem je, že v případě, že vysílač je v režimu 1, po upgradu, pravá hůl je plyn, který je v middle pozice ... druhý možný důvod je, pokud váš přepínač režimu letu není v
(Google translate is my friend... ;) )
12 Jun 2015 19:21 #33951 by matyasvane
FDR wrote: Prostě udělat to samé s pravou páčkou (výtah), jak jste to udělali s levou tyč (plyn) .v důvodem je, že v případě, že vysílač je v režimu 1, po upgradu, pravá hůl je plyn, který je v middle pozice ... druhý možný důvod je, pokud váš přepínač režimu letu není v
I tried to understand it but I do not understand this
12 Jun 2015 19:31 #33955 by FDR
Sorry, but I can't explain it any simpler...
13 Jun 2015 10:00 #33997 by matyasvane
FDR wrote: Sorry, but I can't explain it any simpler...
No change..
20 Jun 2015 11:44 #34396 by matyasvane
dump
20 Jun 2015 11:52 #34397 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 12 problem
I don't know what else to say then. if you have tried moving both sticks and you still see 'Throttle Stick', it is likely there is something wrong with your Tx. You could open the cover and see if all the connectors are attached.
You could also try installing Deviation and see what message it gives you (even if you decide togo back to Walkera once your issue is resolved)
Time to create page: 0.736 seconds
